Coolant Level
Discussion in '2nd Gen Tundras (2007-2013)' started by Theghost37, Sep 30, 2019.
  1. Sep 30, 2019 at 3:51 PM
    Theghost37
    Theghost37 [OP] New Member
    Michael
    Downeast Maine
    2008 Tundra TRD 4x4 5.7
    So my new to me tundra I got last month has @121k it’s a 2008.
    And it’s my daily driver and I’ve had to add @ a cup of coolant every day just to keep it to the full line.
    Kinda hoping it’s not head gasket. Any suggestions for troubleshooting?
    Mountun Goat likes this.
  2. Sep 30, 2019 at 4:19 PM
    Theghost37
    Michael
    Downeast Maine
    Alright... I’ll change radiator cap... oil has @2500k miles on it and looks brand new and it’s right on the line. Yes it’s 5.7.
    I’ll check around water pump for leaks and leak stains.
    GODZILLA and Mountun Goat like this.
  3. Sep 30, 2019 at 5:36 PM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
  4. Oct 1, 2019 at 10:20 AM
    Dr_Al
    Dr_Al New Member
    Al
    Where are you adding the coolant? Through the radiator cap or is the reservoir what's dropping? It should pull in fluid if needed from the reservoir and if too full send it out to the reservoir. If it was me, since they are cheap, I would replace the radiator cap with a Toyota brand cap. The cap holds the pressure and if weak it'll let some bleed off.
    JohnLakeman, Viking and Mountun Goat like this.
  5. Oct 1, 2019 at 2:05 PM
    Viking
    Viking New Member
    Jerry
    2007 metalic brown double cab Tundra
    Aftermarket radiator caps as well as other non-OEM parts can be problematic, I've seen this with my Samurai's, OEM stuff has always worked out better for me. Trying to save a buck can end up being costly, found that out the hard way.
  6. Oct 2, 2019 at 3:07 AM
    Theghost37
    Michael
    Downeast Maine
    Alright will do.
    I really hate the sweet smell of coolant .
    Was orange .... then I put in green now it’s a Monster color
  7. Oct 2, 2019 at 3:37 AM
    GODZILLA Hail to the King, Baby.
    Wyoming
    2023 Solar Octane TRD Pro TACOMA, 2022 Honda CB500X
    Trying not to mod it
    I hope that was the same type of coolant. Different companies will use different colors, and as long as it's the same type you are ok. There are different types that if mixed will turn to a sludge, though.
  8. Oct 2, 2019 at 3:47 AM
    SgtNewundies
    SgtNewundies New Member
    Eric
    You have to use the correct coolant as Toyota is specific about the formula. You can use the premixed Toyota Long Life which is pink or Zerex Asian which is also pink. Sounds like a drain and refill is in order. I would do another one within 20000 miles. Wrong coolant can cause problems.
  9. Oct 2, 2019 at 5:51 AM
    Theghost37
    Michael
    Downeast Maine
    I used prestone
  10. Oct 2, 2019 at 7:45 AM
    15whtrd
    15whtrd Mr. Blonde
    That’s fine as long as you got all the other stuff out. I hear you don’t want to mix. Also it’s supposedly not as long lasting, so plan on changing it sooner. Although most people don’t LOL
  11. Oct 2, 2019 at 8:04 AM
    Theghost37
    Michael
    Downeast Maine
    No I just been adding prestone since I bought the truck used last month. Don’t really even have half gallon prestone in it so far. And I’ve been adding to the reservoir. This my first tundra so I didn’t know coolant had to be oem. Never had to deal with coolant issue on Toyota before. Now you all got me worried I should take to dealer and get coolant flushed. I’m not gonna do that my self cause I’m not good at burping.
  12. Oct 2, 2019 at 8:08 AM
    15whtrd
    15whtrd Mr. Blonde
    I’ve just heard that green and pink don’t mix well. Maybe someone else could chime in. But if your truck already had pink Toyota OEM it’s best to stick with that. But I think you should wait to see if the coolant level finally stabilizes before you go having the system drained and refilled. Hate to pay for that twice.
  13. Oct 2, 2019 at 8:36 AM
    sundance
    sundance New Member
    Drain and refill. If you refill slowly, you will not have to "burp it".
    Use the Aisin fluid. You can get it for about $15 at rockauto
    If you do have a leak, it is probably leaking a little at the water pump.
  14. Oct 2, 2019 at 8:39 AM
    7.62Tundra
    7.62Tundra Chromeaphilliac
    SA Texis
    2015 5.7 Crewcab
    I had a similar issue. I couldn't hold the level and it would drop to the bottom of the reservoir. I changed a hose but still no luck. Dealer said to bring it in because sometimes if the water pump is leaking you won't see it because it evaporates. Took to the dealer with no evidence of leaking and it pressure tested fine. Basically had a huge air bubble in it. Run your heater and top off and keep filling. Eventually mine started holding the proper level 1/2 way in the reservoir.
  15. Oct 2, 2019 at 8:45 AM
    Racingjohndeere55
    Racingjohndeere55 New Member
    I had this same thought. Checking under the hood on my 2011 the coolant reservoir tank was low. Wasn't at the add line but just a little low for my taist. So I topped off with the pink stuff and then checked it a few days later, it was back down again. Long story short, it likes it just about at the add mark and stays there consistently.
    TundraNationalist likes this.
  16. Nov 19, 2019 at 3:52 PM
    TundraNationalist
    TundraNationalist New Member
    2008 BASED CrewMax 4.7L
    Mine is low in the reservoir as well. I seems full when I open the radiator cap. I guess I’m not too worried about it for now. I’ll grab a bottle of pink Toyota coolant.
  17. Nov 20, 2019 at 11:01 AM
    oogabooga289
    oogabooga289 New Member
    I had a similar issue, too. My reservoir was almost completely empty after sitting overnight. Just the tiniest sliver of coolant at the bottom of the reservoir. I topped it off with the Toyota pink stuff to about where the reservoir has that step. You know the one. Where there is that overhang midway between full and low.
    I checked a couple days later, and it dropped all the way back down to the tiniest sliver - the level before I added any. There were no puddles, sweet smells, or glaringly obvious pink crystals to be found. I added even more to almost the full line, and it finally held. So. I have no idea where the stuff goes.
  18. Nov 20, 2019 at 1:52 PM
    Racingjohndeere55
    Coolant topper fairies... or bigfoot not sure:rofl:
  19. Nov 27, 2019 at 8:54 AM
    jduane
    jduane New Member
    jc
    check to see if you have coolant running down back of block passengers side heater by pass leaking under intake just had mine repaired reservoir will go down have to keep topping it off
  20. Nov 27, 2019 at 9:42 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    I was just looking at the manual in my Camry today.
    It said “use ethylene glycol based coolant only and not alcohol based.”
    Essentially, you want to top off red coolant with red coolant and green with green.
    OP, you can get red “Asian vehicle” coolant at any of the parts stores. It’s called Zerex. Or go buy toyota oem.
    Since you already mixed them I would definitely get a flush done. If you’re not good at burping then yeah, the dealer can do it. May as well have them flush the brakes while your at it if you don’t know the service history of the truck.
    https://www.google.com/amp/s/tap.fr...uto-professionals/mix-different-types-coolant
    15whtrd[QUOTED] likes this.
  21. Nov 27, 2019 at 10:12 PM
    14tundra
    14tundra On Wisconsin!
    WI
    2014 Platinum Crewmax 4x4 5.7L 1G3
    Had this same issue in my 2014 with 5.7L. Will check it again after topping her off. Hope it’s not an issue. Have oil change coming up so local shop can advise.
  22. Jan 18, 2020 at 6:42 AM
    Theghost37
    Michael
    Downeast Maine
    Update today
    At Toyota dealer here in Maine and getting new radiator @$609 installed
  23. Jan 18, 2020 at 7:13 AM
    TundraNationalist
    Geez sounds expensive. So they confirmed the radiator itself was leaking?
  24. Jan 18, 2020 at 7:41 AM
    Theghost37
    Michael
    Downeast Maine
    Yes they did a pressure test first.
    I could see a little fluid on radiator before I came to dealer.... Napa radiator 320$ Toyota radiator 256$....
  25. Jan 19, 2020 at 7:23 AM
    Theghost37
    Michael
    Downeast Maine
    And I got my RCI skid plate installed by dealer , inspection sticker, etc
