Door panel rattles
Discussion in '2.5 Gen Tundras (2014-2021)' started by Rubberdown, Oct 14, 2019.
  1. Oct 14, 2019 at 1:54 PM
    Rubberdown
    Rubberdown [OP] Spilling my guts here.
    so.... the panel that holds the door lock and window switches is rattling more than I can stand with the stereo playing. It’s just not tight enough to prevent rattles. Anyone experienced this and fixed? I searched but didn’t see anything.
  2. Oct 14, 2019 at 2:06 PM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    Pop it off and see if the clips are in the right spot... May have to buy new clips
  3. Oct 14, 2019 at 2:22 PM
    vl184009
    vl184009 Cheers Boys!
    Vicky
    Southern, Ca.
    2016 MGM CM SR5 4x4 w/Tow Pkg
    OR18TRD[QUOTED] likes this.
  4. Oct 14, 2019 at 4:00 PM
    Rubberdown
    Popped both sides off. The clips are all there and in the right spot. Does it on both sides.
    OR18TRD likes this.
  5. Oct 14, 2019 at 4:30 PM
    TundraLaw
    TundraLaw New Member
    Northern Nevada
    24 limited hybrid offroad
    I have just accepted the Toyota rattle lol. My entire truck rattles going over any bump in the road. Weird how my 2017 didnt rattle at all, but my 2019 appears to really have some QC issues.
    Rob's Inferno likes this.
  6. Oct 14, 2019 at 4:38 PM
    Rubberdown
    Ordered the tape. Hope it helps.
    BTBAKER and OR18TRD like this.
  7. Oct 14, 2019 at 5:33 PM
    Highsierraguy
    Highsierraguy New Member
    Nor Cal
    Keep us posted, I was literally just thinking how annoying both doors were as I was driving home this evening.
  8. Oct 14, 2019 at 6:12 PM
    Rubberdown
    Only rattles in the truck.
  9. Oct 17, 2019 at 5:53 PM
    Rubberdown
    Ok. I got the hush mat tape in. Worked great on the buttons. Now I can hear the silver trim rattle. If I pull the door panel does that silver trim just unscrew or is it plastic welded or something?
    OR18TRD likes this.
  10. Oct 18, 2019 at 7:36 PM
    mundra
    mundra New Member
    Ormond Beach, Florida
    2019 platinum 4x4
    315/70/17 Ridge Grapplers on Rock Warrior Wheels, Tinted windows,remote start,tech12volts audio upgrade w/2-10" subs, console charger, more to come soon.
    Chasing dash rattle or sounds like dash/firewall rattle since 500 miles
    OR18TRD likes this.
  11. Nov 23, 2019 at 4:14 AM
    Tundy Chuck
    Tundy Chuck New Member
    Charles
    2016 Black Tundra Limited
    Man, I am so happy this post exists. I’ll buy some now. Is it easy to pop off the panel with the window switches/ door locks without completely marring the panel? I am fairly... special when it comes to things like that.
  12. Feb 11, 2020 at 7:14 PM
    AluminumFoyle
    AluminumFoyle New Member
    Germantown TN
    Late to this thread, did you ever find a fix for this? Originally in my 1794, the window control panel was super loose and would rattle like hell when i had the volume up above 25, i bought some hush tape and that fixed this part from rattling but now i think my same silver trim along the bottom of the arm rest is what is rattling now. when i stick my arm or leg against it it goes away,
    BTBAKER likes this.
  13. Feb 11, 2020 at 7:19 PM
    BTBAKER
    BTBAKER DIFFERENT NAME. SAME JUNK.
    Brad
    Castle Rock
    2023 Ram Rebel
    NOLA Tundra likes this.
  14. May 1, 2020 at 11:00 AM
    Rubberdown
    Welp. I have tried everything. Bout to epoxy the silver piece to the black door panel. This panel design is a joke.
  15. May 1, 2020 at 12:43 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    You got to foam the shit out of it! Lol
    MaxMB, Rocko9999 and jtwags like this.
  16. May 1, 2020 at 1:03 PM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    jtwags likes this.
  17. Jan 5, 2021 at 8:57 PM
    Ladicius
    Ladicius New Member
    2014 MGM Platinum
    Did it work? What foam did you use?
    Toyotoholic[QUOTED] likes this.
  18. Jan 5, 2021 at 11:03 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    I mostly used open cell packaging foam, some acoustic foam too, and it works extremely well. You have to cut, place, glue, and tuck everything so it clears attachment points and secures the panel with a cush spring of foam... Thus never vibrating into a rattle.
    Took me a while to get it perfect, but it is perfectly silent with zero rattles.
    Rocko9999 likes this.
  19. Jan 6, 2021 at 6:06 AM
    TrexTundra
    TrexTundra Live Free or Die Tryin
    Trevor
    Idaho
    2017 Black Tundra Platinum
    **Work in progress** 3/1 Procomp Nitro leveling kit 285/70/18 Nitto Ridge Grapplers 18x9 Black Fuel Vapors +1 offset Led Headlight/fog lights Will be removing chrome and Plastidip black
    My 17 platinum does the same exact thing. Drove me nuts, actually thought I had blown speakers it rattled so bad but come to find out it was both driver and passenger door locks rattling. I did a quick easy fix with electrical tape. I basically kept sticking little pieces of electrical tape together making the lock switch fit just a little snugger in there. Did so making sure the lock still works fine and doesn’t have to over work to lock and unlock. You can’t even see the tape. I didn’t think it was going to work but so far zero rattle! I stuck the tape to the inside of the door housing where the door lock sits. Can’t see it and makes it just snug enough to not rattle. I prefer to Jimmy rig things anyway makes things more exciting!!
  20. Jan 6, 2021 at 1:29 PM
    ljburns
    ljburns New Member
    Cab noises drive me crazy. I fixed that issue by taking the switch panel off and sticking felt to all the areas that might vibrate. I also use car wash sponges in the dash. I tear pieces off and tuff them in areas that the sound is coming from. Works pretty well.
    TrexTundra likes this.
  21. Jan 6, 2021 at 4:08 PM
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    Incredible i have 2021 and cant stand rattles. 2500 miles and zero rattles except the back seat belts if they are cocked when taken off.
  22. Jan 6, 2021 at 4:47 PM
    ljburns
    ljburns New Member
    Mine was like that new, and is still like that in the summer after tracking a few of them down. The winter, that is a different story. Everything loosens up after a while and the cold weather makes the gremlins come out of hiding.
  23. Jan 6, 2021 at 6:16 PM
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    Solutions to rattles include sticky sided felt, fabric tape. I did have one in my Tundra it was horrible when someone sat in the back seat. Long story short it was one of the front bolts seat frame bolts, in end I just left snug, tightened bolt, didn't help, insulated washers, didn't help. In end when bolt was loose noise ceased when tight it creaked bad, lol. Other than than zero noises.
  24. Jan 7, 2021 at 4:25 PM
    Ladicius
    Ladicius New Member
    2014 MGM Platinum
    It looks like the entire thing is covered, that's pretty substantial. Think it was all needed? (Trying to gauge what I need to purchase).
    Toyotoholic[QUOTED] and ljburns like this.
  25. Jan 7, 2021 at 5:07 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Oh I definitely went for overkill.
    You really only need address the points of contact and anything that might be loose or become loose. I'm a little nuts when it comes to the acoustic treatment of all of the trucks surfaces. This amount of foam is necessary to me due to the audio system and my zero tolerance for any noise or rattles, especially the doors. I would safely say you could use just a few pieces for each door, mostly around the switches and cables, and around the speaker.
    Ladicius[QUOTED] likes this.
  26. Jan 7, 2021 at 5:17 PM
    Ladicius
    Ladicius New Member
    2014 MGM Platinum
    Thanks for the guidance!
  27. Jan 7, 2021 at 5:29 PM
    Rob's Inferno
    Rob's Inferno New Member
    2017 SR5 crewmax 4x4 Inferno
    My 17 is a rattle box.doors dash you name it
  28. Jan 7, 2021 at 8:09 PM
    Ladicius
    Ladicius New Member
    2014 MGM Platinum
    Did anyone find that the panel clips themselves vibrate/rattle?
