Sequoia Console Swap
Discussion in '1st Gen Tundras (2000-2006)' started by fctry, Nov 1, 2019.
  1. Nov 1, 2019 at 12:02 PM
    fctry
    fctry [OP] New Member
    2002 Tundra SR5
    There's a local guy parting out an 04 Sequoia with some good prices, contemplating trying to retrofit the center console and power seats into my 02. I found one old tundrasolutions thread about it but all the pics are dead. Any thoughts?
    Here's the console
    because_wumbo-truck likes this.
  2. Nov 1, 2019 at 12:49 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    I say do it. For science!
    TX-TRD1stGEN likes this.
  3. Nov 1, 2019 at 1:04 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    it physically fits. but im still trying to figure out the bracket situation. its likely not a true plug and play swap from what ive seen in my 05 reg cab
  4. Nov 1, 2019 at 7:10 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    For $55 I would try it. That's a good deal.
    revtune and because_wumbo-truck like this.
  5. Nov 22, 2019 at 7:22 PM
    Markiezee68
    Markiezee68 New Member
    2001 Tundra SR5
    I did it...Found a console from an 04 sequoia and replaced the small console in my 01 SR5. Found the brackets on line. The rear bracket went in like a champ but the front didn't. The carpet was covering where the mounting holes would be. I didn't cut the carpet to find out if the holes were there but its solid with the rear mount
    SouthPaw, revtune and TX-TRD1stGEN like this.
  6. Nov 22, 2019 at 8:31 PM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    Any pictures??
  7. Nov 22, 2019 at 8:58 PM
    Markiezee68
    2001 Tundra SR5
    Here ya go...I made a hole for the floor vents up front. Thought about small speaker covers but found they restricted the air flow.
    2wdx556, FirstGenVol, bmf4069 and 3 others like this.
  8. Oct 16, 2020 at 3:03 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    I am working on this upgrade right now. Does anyone know what brackets are needed to swap? I found a few part numbers, but wasn't sure if some are proven to work or not work. Plugging in the outlets on the side is going to take a little rewiring, but so far, so good.
  9. Oct 16, 2020 at 8:29 PM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    I did the swap from a 2005-ish DC. It’s about 80% plug and play. As @Markiezee68 mentioned, I was only able to utilize the rear bracket as the front was covered by carpet. I also had to snip off the connectors off the cig outlets and replace them with standard spade connectors for them to plug into the truck side. Other than that, it was extremely easy and well worth it in my opinion.
    https://www.tundras.com/threads/southpaw’s-2000-tundra-build.53510/page-2#post-1653677
    I still need to order the seat warmer blanks but for now it works.
  10. Oct 16, 2020 at 8:37 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    I love it already, of course right now there aren't any bolts securing it. I'll have to post pics, but it has blanks for rocker switches in the front for lights (and locker one day). And, I'm diggin the carbon cupholders with the grey interior. I'm looking into what brackets I need to get, or if I can slide back my existing bracket in the back. I think I'm going to try and stretch the existing cig lighter wiring and just pull the ones out of my old console and pop those into the new location. I think the wiring will reach. Otherwise I might follow your lead.
  11. Oct 16, 2020 at 8:42 PM
    SouthPaw
    2000 Limited 4x4 AC
    IIRC, the DC/Sequoia cig lighter harness is attached to a clip on the console. If you remove that, it gives you about 2-3 inches of slack which is just enough to make it work with your truck side wiring. Like I said, I chopped the ends off and put spades on the console side to slide them into the female truck side connectors.
