Shock boots or roost shields
Discussion in 'Suspension' started by triplej23, Apr 12, 2018.
  1. Apr 12, 2018 at 11:33 AM
    triplej23
    triplej23 [OP] New Member
    2013 Tundra TRD
    Putting fox rear shocks on tundra. Not sure if I should use boots or roost shields. I’ve read that on the Tacoma the roost shield on passenger side will not work. Not sure if the same for tundras.
  2. Apr 12, 2018 at 3:27 PM
    Vizsla
    Vizsla 2 = 2.5
    I vote for the roost shields, used them on 2 trucks, fit fine(passenger side must face back, it should and shaft is protected by the rear end in front). Functional and dress it up a bit as well. Wish they made them for 2.5” shocks, using boots on them, but not crazy about it.
  3. Apr 12, 2018 at 5:32 PM
    Whitewhale
    Whitewhale New Member
    Kyle
    The Berkshires
    16' white limited
    I have roost shields on the wife's fj. I'm not a boot fan
  4. Apr 15, 2018 at 8:30 AM
    Tundra4us
    Tundra4us New Member
    "D"
    Correct. They will not work on thre passenger side of the Tundra. But, you can make them work by "notching" the lower portion around the rear shock mounting bracket. I did....
    Black Wolf likes this.
  5. Nov 10, 2019 at 11:20 PM
    Flyinryank
    Flyinryank New Member
    Las Vegas, NV
    White 2015 CM 4x4
    Who put shock boots on their 5160s?
    I have killed one with rocks gouging the shaft and eating up the body seal.
  6. Nov 10, 2019 at 11:47 PM
    I made my own roost shields from the old Toyota TRD shock covers. Cut up with a razor knife, cut holes, and installed on shock mount.
    jeremyd and Flyinryank[QUOTED] like this.
  7. Nov 11, 2019 at 12:17 AM
    Flyinryank
    Las Vegas, NV
    White 2015 CM 4x4
    The blue ones from the yellow shocks? Pics when you can
  8. Nov 11, 2019 at 12:29 AM
    Yep.
    I never took pics. Well maybe. I’ll look.
  9. Nov 11, 2019 at 3:42 AM
    stuckinohio
    stuckinohio MGM Crue
    Mark
    oHIo
    2018 SR5 Crewmax
    When the shock body is on bottom and the boot is on top, the boot works like an umbrella and allows water to drain out. When the shock body is on top, the boot just tends to hold dirt and let the shaft body get submerged in the dirt/ water debris. Adding drain holes helps remove the water but doesn't do anything to remove the dirt coating the inside of the boot ribs. I installed boots on my tacoma and ended up cutting them off because of the crap they held. My vote is roost shield or nothing.
  10. Nov 22, 2019 at 1:03 PM
    blackoutt
    blackoutt YEAH BUDDY!
    NWA
    07 DC Long Bed - Old Man Tan
    OEM+
    On 4runner/FJ/GX Icon makes a nice stainless steel shock shaft roost guard that takes some abuse. I wonder if it would work on these? I had a similar experience with a boot getting full of muddy water and tearing up the shaft, better off leaving it bare in my opinion.
