Ramp question
Discussion in '2.5 Gen Tundras (2014-2021)' started by mr_data, Oct 20, 2019.
  1. Oct 20, 2019 at 2:48 PM
    mr_data
    mr_data [OP] New Member
    Northern New York
    2016 Super White Tundra SR5
    Hi all,
    I have these ramps https://www.amazon.com/gp/product/B0117EETEK/ that I used with a former vehicle. I believe that the Tundra's GVWR is less than the max for these ramps, but I was just wondering how people felt about using these ramps for a Tundra or if there are better ramps I should get.
    Thanks.
    Tundra14Platinum likes this.
  2. Oct 20, 2019 at 2:52 PM
    BTBAKER
    BTBAKER DIFFERENT NAME. SAME JUNK.
    Brad
    Castle Rock
    2023 Ram Rebel
    I use them. I haven’t had an issue after using them 10 times or more. I do use a jack stand as a back up though.
  3. Oct 20, 2019 at 3:48 PM
    Jrharvey02
    Jrharvey02 New Member
    I got those too...
  4. Oct 20, 2019 at 3:56 PM
    7.62Tundra
    7.62Tundra Chromeaphilliac
    SA Texis
    2015 5.7 Crewcab
    The weight is determined by axle not gross.
    Kerch71 and Black Wolf like this.
  5. Oct 20, 2019 at 4:05 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    What does that mean?
  6. Oct 20, 2019 at 4:17 PM
    mr_data
    Northern New York
    The ramps list a maximum gross vehicle weight of 12,000. The ramps themselves list 6,000 lbs maximum each. It seems that it should be fine just based on the numbers. I was mainly looking for other people's real world experience with them.
  7. Oct 20, 2019 at 4:21 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    I have the harbor freight version and works fine, I also use jack stands with them though.
    Cruzer and Black Wolf like this.
  8. Oct 20, 2019 at 4:28 PM
    7.62Tundra
    SA Texis
    2015 5.7 Crewcab
    Sorry, they look good, I'm in the market for some too. Try them and see what you think. Most everything I ever owned was too low so ramps were still too low. Ramps are cool if you're underneath but going back and forth to engine compartment is a PITA working off a ladder.
  9. Oct 20, 2019 at 4:33 PM
    mr_data
    Northern New York
    No problem. As I already have them, I tried putting the truck up on them. It seems like they should be fine, but it'd always be a good idea to use jack stands under the truck also just in case the ramps failed. I'd probably get the heavier duty ones or get steel ramps if I ever need to get new ones though.
    saybng likes this.
  10. Oct 20, 2019 at 4:43 PM
    7.62Tundra
    SA Texis
    2015 5.7 Crewcab
    I had the same conversation with a friend a week ago the does serious work on his stuff and asked him what he thought. He said they're fine. I'd just throw on the parking break and chock the rear wheels. If you're doing serious surgery, jackstands are always a good idea.
  11. Oct 20, 2019 at 5:51 PM
    7.62Tundra
    SA Texis
    2015 5.7 Crewcab
    It means that you will probably never have all 4 wheels on ramps unless you jack an axle up. Cuz you ain't driving both axles up on ramps at the same time unless you got clearance on the fenders
    BTBAKER likes this.
  12. Oct 21, 2019 at 7:55 AM
    Part_time
    Part_time Not a new member
    Oregon
    2017 MICA BRONZE SR5
    I use same style ramp when working my tundra says it is good up to 12000 lbs. I have also used those up front then jack up the back with jack stands to make level
  13. Oct 21, 2019 at 8:42 AM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    They have to be lighter to pick up than mine.
    I have an old set of metal ones that I wish would get stolen or something.
    I dont have the heart to toss them out though.
    panicman likes this.
  14. Oct 21, 2019 at 10:48 AM
    Bergmen
    Bergmen New Member
    Ukiah, California
    I've used these since I bought my new 2018. Four oil/filter changes so far. I really like them, very good product. Being reinforced plastic, they are fairly light to haul around and put into position. A couple of points:
    1) I hear they can slide if you are in a garage with a polished concrete floor. I have never tried this, I always work on my truck in our level driveway which has a rough surface. No worries here.
    2) I'm always a little nervous driving up the ramps, I don't want to blow it and drive over the front end. I'm very careful with one foot on the gas pedal, the other on the brake. I creep up slowly and nce I crest the hump, I let it settle in the depressed area. The I set the parking brake to secure it.
    Since I use these to only do oil/filter changes, access to the under hood area for oil fill is not compromised, easy to do. After the change, I fire it up on the ramps to assure no leakage (or other problems). Then I re-install the front skid plate and back down the ramps.
    I highly recommend them.
  15. Oct 21, 2019 at 3:01 PM
    MtnBound
    MtnBound New Member
    Brent
    Shingle Springs, CA
    2018 Crewmax Limited 4x4
    OME614/JBA/Toytec SCS F5, Cooper 295/70R18 AT3 XLT
    5491A86A-E897-4656-8FD5-7814B8905439.jpg Here is the label on mine, they are rated for 3000lbs each, I have used them on my Dodge 3500 with a Cummins, they should be fine with a tundra. Basically for marketing reasons the 12k sounds better but it assumes that 12k is equally distributed on each wheel.
  16. Nov 21, 2019 at 6:42 AM
    Part_time
    Oregon
    I use mine for oil changes and have even jacked up my rear end and put on jack stands. So half and half. No problems.
  17. Nov 21, 2019 at 7:13 AM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    I have used them for years.
    I put the truck in 4wd and crawl up no prob. They are great. Think of your tires that have a load rating of about 2800-3200lbs so these are about the same as the tire on your truck now!
  18. Nov 21, 2019 at 8:26 AM
    shellshock
    shellshock Guy who drives a lot
    Iowa
    2019 TRD PRO
    I’ve got the same ramps. No issues
    Pac12AfterDark likes this.
  19. Oct 3, 2021 at 5:12 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Diy project with son. Gives us 8" additional clearance.
    Will use them this week to apply Corrosion Free to the undercarriage.
    2x10x10 boards (2)
    $40 Canadian.
    saybng, LS3 and BTBAKER like this.
  20. Oct 3, 2021 at 5:36 PM
    Pac12AfterDark
    Pac12AfterDark New Member
    Agree, I use mine with my camper in the bed. No issue at all
  21. Oct 3, 2021 at 5:54 PM
    steved0xTD
    steved0xTD New Member
    2020 Tundra SR5 4x4 TRD Off-road
    I've got 2 sets (a 12000 gvw and 16000 gvw) and use them on my other cars. Used a pair just a while ago to change the front diff gear oil on my FJ. I had a hard time easing the front tires up them, and when I went to stop, they slid just a little. I since learned that a possible trick is to go in 4lo and really crawl slowly up them. I haven't put my tundra up on them yet but if I do I will go in 4lo. I also put a jack stand under the frame on the side I'm going to be on. They felt safe every time I was under them.
  22. Oct 5, 2021 at 4:55 PM
    737fixer
    737fixer New Member
    For $10 more get the 16,000. Not really one of those things that when it fails good things happen. Have had a pair for many years now and as mentioned before only complaint is the way they slide on the garage floor. Literally have to put a 2x6 between them and the wall when using or they shoot out every time.
  23. Oct 5, 2021 at 5:24 PM
    Nowhereman
    Nowhereman New Member
    Al
    Monterey Bay area
    2021 Tundra SR5 / TRD / Cement
    Rough Country shocks, ReTrax cover, Summo springs, black out badging, bed extender, "some other things I can't mention"
    Just one note of caution, never try to run up a vehicle onto these ramps with finished concrete surface flooring.
    Why? because they will slip forward while running up the ramps and cause some serious crap.
    AggiePhil and Oey12 like this.
  24. Oct 5, 2021 at 5:38 PM
    BTBAKER
    Brad
    Castle Rock
    2023 Ram Rebel
    I always engage 4wd and don’t have issues. If I attempt to use my ramps in 2wd they slip every time.
    KFed, AggiePhil, shellshock and 2 others like this.
  25. Oct 6, 2021 at 1:09 AM
    CMikeB
    CMikeB New Member
    THERE it is!:rolleyes::thumbsup:
    BTBAKER[QUOTED] likes this.
  26. Oct 6, 2021 at 1:21 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    I also have the same same.. No issues at all.
  27. Oct 6, 2021 at 4:46 AM
    EZDoes It
    EZDoes It New Member
    Ed
    LSD (Lower Slower Delaware)
    2020 MGM CM SR5 TRD exhaust, TRD wheels
    Tint, tow mirrors, remote start, Razormotor taillights, Genuine trans cooler, tailgate light strip, Extang tonneau, TRD rear sway bar, trans cooler…(thanks TRD)
    Have them, love them. I use 4WD low so I can creep up on them, not that I’m creepy, well you know what I mean. However I do not use jack stands as a back up. I hope they don’t creep up on me someday.
    AggiePhil and BravoDeltaRomeo like this.
  28. Nov 2, 2021 at 11:45 PM
    rugerm44
    rugerm44 New Member
    2021 Tundra
    I use 3m adhesive tape on the rubber tab on bottom of ramp. It works fine and no slipping
  29. Nov 3, 2021 at 9:05 AM
    MDUplander
    MDUplander New Member
  30. Nov 3, 2021 at 2:36 PM
    RickPlatinum2020
    RickPlatinum2020 New Member
    Rick
    Eastern PA
    2020 Barcelona Red Platinum 4x4
    Front and rear TRD sway bars, 18" TRD OR wheels. ESP underseat storage
    Planning on getting my truck up on four ramps to do front and rear diff and transfer case in the next couple of months.
