Thoughts on 6" lift?
Discussion in 'Suspension' started by CDB, Nov 15, 2019.
  1. Nov 15, 2019 at 9:35 PM
    CDB
    CDB [OP] New Member
    20200103_154119.jpg 20200103_154135.jpg I have a 2013 2WD crewmax. Getting ready to to drop some money into it. Shop has me setup for a 6" lift with 22x12 fuel rims and 33" tires. Any thoughts or opinions on whether or not this is a bad setup would be appreciated. I explained that I didn't want the tires to sit out much past the (XSP) fender flares and i didn't want the height of the tire to get lost in the wheel wells. 6" seems high to me but I have never owned a lifted truck before. Any comments or comparison pics would help me out a lot. Updated pics, finally done.
  2. Nov 15, 2019 at 10:35 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
  3. Nov 16, 2019 at 12:16 AM
    CDB
    CDB [OP] New Member
    I agree that 12" rims will set out past the fenders but I have those bolt on fender flares which extend out 2.5" or so beyond the factory fender. With my current Toyota XSP tire and rim setup the tires are recessed about 4" from the edge of the wheel flare, viewing the truck from the rear looks like a fat man with skinny legs. He assured me that the tires would not bump out from fender flares more than 1", I also do not know what offset he picked for the rims. I originally wanted a 3 or 4" lift but of the trucks in the shop and pictures that he showed me the 6" seemed to look better. I am worried about too much room between the top of the tire and the wheel well though. Sounds like you might be confirming my thoughts, maybe 4" lift would be better with 33" tires. I appreciate any further comments
    SC_TRD likes this.
  4. Nov 16, 2019 at 12:22 AM
    SC_TRD
    SC_TRD Big BASTRD 4x4 Enthusiast
    Colin
    Round Rock, Tx
    2012 CrewMax & 2008 Sequoia
    I have a 3-3.5” lift on my sequoia and my tundra, both of which are running between 34”-35” tires...I agree with you, 33” tires with a 6” lift will likely not fill the wheel wells like you want.
    3” lift with 34.6 x 13” tires for perspective:
    Hope this helps!
    Fireman/68W, Y0TA PR0 and Prostar 190 like this.
  5. Nov 16, 2019 at 12:35 AM
    CDB
    CDB [OP] New Member
    Perfect, thanks for your help. Nice truck as well
  6. Nov 16, 2019 at 1:24 AM
    CDB
    CDB [OP] New Member
    I see what you mean, I think they fill the wells in the front pretty good but not so much in the rear. Thanks for your help
  7. Nov 16, 2019 at 4:09 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    But that’s with 3”. The same 33’s with a 6” lift will look tiny.
  8. Nov 16, 2019 at 4:33 AM
    Here's 6" and 35's.
    Here is a 20 x 10 -19 offset
    [​IMG] [​IMG]
  9. Nov 16, 2019 at 8:59 AM
    CDB
    CDB [OP] New Member
    Ok that's perfect, I'm going with the 35's but I'm a bit worried because my rims are 20×12 and yours are 10. I dont understand what a -19 offset is, my rims state a 4.75" offset
  10. Nov 16, 2019 at 9:03 AM
    unclebeejo808
    unclebeejo808 New Member
    Oahu
    Offset if from the front of the wheel hub to the center of your rim. Your 4.75” is backspacing which is the measurement from the front of your wheel hub to the inside lip of your rim.
  11. Nov 16, 2019 at 9:26 AM
    SC_TRD
    Colin
    Round Rock, Tx
    I am a picture kind of guy.... simple explanation...
    aperezsh, GODZILLA and unclebeejo808 like this.
  12. Nov 16, 2019 at 9:28 AM
    unclebeejo808
    Oahu
    Much easier to understand. Haha
    SC_TRD[QUOTED] likes this.
  13. Nov 16, 2019 at 9:42 AM
    CDB
    CDB [OP] New Member
    Ok I see now. It says back spacing is 4.75" and offset is -43mm which is 1.7". But I still don't understand how that relates to your -19
    Prostar 190 likes this.
  14. Nov 16, 2019 at 9:44 AM
    -43 will hang out there more than twice as much as mine. :sawzall:
  15. Nov 16, 2019 at 9:47 AM
    CDB
    CDB [OP] New Member
    Fuck
    AxelsHumanDad, aperezsh and GODZILLA like this.
  16. Nov 16, 2019 at 9:50 AM
  17. Nov 16, 2019 at 9:51 AM
    I didn't cut any metal.
  18. Nov 16, 2019 at 9:55 AM
    2010bigdog
    2010bigdog New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
    what lift do you have ?
  19. Nov 16, 2019 at 9:58 AM
    Rough Country.
    k0diak8o8 likes this.
  20. Nov 19, 2019 at 4:33 PM
    trapper j
    trapper j New Member
    Greg
    2016 Tundra Crewmax Limited
    2016 Toyota Tundra Limited w/ 6 inch Rough Country lift, gray 20x9 Fuel Rebel wheels and 35x12.5x20 Nitto Ridge Grapplers. Step rails are Podium by NFab
  21. Nov 19, 2019 at 6:26 PM
    DM 2018 Tundra
    DM 2018 Tundra New Member
    2018 Limted Tundra
    6inch RC with upgrade struts. 295/65/20 Nitto Ridge grappers 20x9 fuel vapor with 0 off set
    6 inch RC lift with 20x9 fuel rims 295/65/20 tires with an 0 offset E87E5D54-0768-4A06-87C8-F292FF3DAF3C.jpg
  22. Nov 19, 2019 at 6:29 PM
    DM 2018 Tundra
    2018 Limted Tundra
    you going to put tow mirrors on?
  23. Nov 19, 2019 at 6:30 PM
    DM 2018 Tundra
    2018 Limted Tundra
    Sweet Ride. How do you like to step rails
  24. Nov 19, 2019 at 6:34 PM
    I don't plan on it. I have pulled alot of different things and haven't had any issues. They look good though.
  25. Nov 19, 2019 at 6:35 PM
  26. Nov 19, 2019 at 6:36 PM
    DM 2018 Tundra
    2018 Limted Tundra
    Yea they would. I had to get some for mine. So used to big mirrors on my Diesel trucks. It hope a ton pulling my pondtoon and I guess a camper. Lol
  27. Nov 19, 2019 at 6:37 PM
    DM 2018 Tundra
    2018 Limted Tundra
    No. Go this Saturday at 1 and get it. They going to recheck everything on and do a walk around. I double checked this really good on this. Now leaks I seen on this one.
  28. Nov 19, 2019 at 6:38 PM
    TxTundra37
    TxTundra37 New Member
    Deer Park
    2019 Black Platinum Tundra
    6" pro comp stage II lift, fender flares, bakflip cover, 36" light bar, 35" Nitto's, etc..
    20190809_172150.jpg Nice, Here's mine.
  29. Nov 19, 2019 at 6:38 PM
    DM 2018 Tundra
    2018 Limted Tundra
    They also working on getting a drop hitch for it.
  30. Nov 19, 2019 at 6:39 PM
    Take some pictures when you pick it up!
