Quick question for year end CM Limited and garage fit
Discussion in '2.5 Gen Tundras (2014-2021)' started by cmp1960, Dec 22, 2016.
  1. Dec 22, 2016 at 7:23 AM
    cmp1960
    cmp1960 [OP] New Member
    Newbie. Two questions.
    1) I'm looking at a new 2017 2WD Crewmax LTD, Black/Black, Remote, LTD Upgrade Package, sprayin bed, Oval chrome step, cargo light, exhaust tip. Looking to take advantage of year end deals. What would be a good price on this configuration? I'm using Edmunds TMV as a guide and it does indeed comprehend a year end rebate, but just don't want to make a mistake. Apologies in advance if discussing prices is forbidden.
    2)Bigger question. I measured my garage and I think it's a little small. 19'6" to be precise. Anyone have a Crewmax with a std garage of this length. I'm thinking it will fit backed in, with driver side exposed to the middle, the entry to my house is a few inches offset to that side and I think the rear bumper would not impede entry.
    Thank you.
  2. Dec 22, 2016 at 7:31 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    hah... ya, the garage fit. I had the same concern about fitting my truck in my garage. My garage is right at 20 feet so the truck fits with several inches to spare. You are correct, backing in is the best way to do it. This allows you to use your mirrors and backup camera to carefully maneuver the tight spot. according to toyota's website, the CM tundra is 228.9 inches or 19.075 feet. so you should be able to fit the truck in your garage, but I bet it will be close. I suspect that you might need to touch the rear bumper against the wall :)
    hell, even if the truck doesn't fit in your garage, get it anyway. the tundra is so awesome :)
    NewImprovedRon likes this.
  3. Dec 22, 2016 at 7:35 AM
    GoHuskers
    GoHuskers New Member
    Nebraska
    '24 iForceMax, '17 RX350, '15 GX460
    I would say NO....Too close. Like NetMonkey said the overall length of the CM is 228.9 (19.1') so having couple inches of clearance for Front and Rear is TOUGH....
    Can you park it outside?
  4. Dec 22, 2016 at 7:46 AM
    Netmonkey
    Georgetown, TX
    well... a tenth of an inch is 1.2 inches. so that's 19 feet 1.2 inches. if he has 19 feet 6 inches, he should be able to fit it in the garage, but it will be close :)
  5. Dec 22, 2016 at 7:49 AM
    Netmonkey
    Georgetown, TX
    about your first question... I am going to guess here, but I bet the MSRP would be around $46k. in my experience, Toyota is really stingy on rebates or specials. if you could get that truck for under $40k, I think that would be a deal.
    EDIT:
    ohh... also.. aren't the year end deals for the current year? for the 2016's and not the 2017's?
