Kings Extended Travel vs Non-extended
Discussion in 'Suspension' started by Duckslayr, Mar 29, 2019.
  1. Nov 5, 2019 at 12:09 PM
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    THIS! When my shocks get rebuilt I’ll slap on some TC UCA’s and make OEM Kings ext travel.
    TheBeast[QUOTED] likes this.
  2. Nov 5, 2019 at 1:16 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I don’t think 3.0’s fit with stock uca? so you will by default be able to use extended travel
  3. Nov 5, 2019 at 1:32 PM
    LBGlossWorks
    LBGlossWorks New Member
    Rawr
    2013 Toyota Tundra RW
    King 3.0 come extended and recommend UCA
    here is picture of my 3.0
  4. Nov 5, 2019 at 2:24 PM
    Samoan Thor
    @LBGlossWorks, badass! You got rears too? How much did you get them for? Is it making contact with your tie rods when turning?
  5. Nov 5, 2019 at 2:54 PM
    TheBeast
    TheBeast The Beach
  6. Nov 5, 2019 at 3:13 PM
    Keithbickford
    Keithbickford New Member
    Keith
    Seattle
    2020 Cavalry Blue Tundra
    King 2.5” suspension, Method Race 313 wheels, Nitto Ridge Grapplers 35x12.5x17, TRD exhaust, RCI Skid Plates, Alpine ILX-F309 stereo, Alu-Cab roof top tent on Yakima Overhaul HD, Line-X spray in bed liner, VLED LED reverse light bulbs and VLED LED license plate reverse light. VLED brake/tail light bulbs. VLED third brake light and cargo lights.
    TheBeast likes this.
  7. Nov 5, 2019 at 3:13 PM
    LBGlossWorks
    Rawr
    I have no tie rods issue at full lock, I paid retail and I’m running King 2.5 shock in rear.
    Samoan Thor[QUOTED] likes this.
  8. Nov 5, 2019 at 3:14 PM
    Keithbickford
    Keith
    Seattle
    As opposed to thinking that the 3.0s are extended, think instead that they are not limited, but can be by adding spacers.
    Hbjeff and TheBeast[QUOTED] like this.
  9. Nov 5, 2019 at 4:16 PM
    SpeshulED
    SpeshulED New Member
    Sandy Eggo/Chula Vista, So Cal.
    2015 Mag Gry Ltd. CM TRD Tundra
    TRD Pro Grill | AMP Steps | Husky Floor Mats | SnugTop Sportsman Super Sport Shell | 55w 5k HID Headligts | Method Racing NV Bronze 18x9 | BFG KO2 35x12.5r18
    I didn’t know if the spacer was internal or external
  10. Nov 5, 2019 at 6:27 PM
    Keithbickford
    Keith
    Seattle
    Definitely internal. It has to limit the extension, so that can only be done on the shaft internally.
    SpeshulED[QUOTED] likes this.
  11. Nov 5, 2019 at 6:32 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    That’s definitely what she said
    AggiePhil, Keithbickford and TheBeast like this.
  12. Nov 7, 2019 at 5:50 PM
    Keithbickford
    Keith
    Seattle
    I contacted King directly
    “In order to make them the ( EXT ) you will need a different shaft. The shaft part number you need is 25013-008 along with a 25057-003 shaft spacer”
  13. Apr 22, 2021 at 12:19 AM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    That’s interesting, my King OEMs are in Garden Grove right now and the tech I talked to said easy hour labor no parts. I don’t think the shaft gets swapped. I was in the building. Reg OEM to Ext....
  14. Nov 6, 2021 at 7:12 PM
    Keithbickford
    Keith
    Seattle
    On King OEM shock kits, they add a spacer on the shaft to limit the length. If you change upper control arms to a set that can handle the extra length, you can have the spacer removed. I’ll be doing that soon.
    AggiePhil and alb1k like this.
  15. Nov 6, 2021 at 7:20 PM
    alb1k
    Left Coast
    It's good
    This is it - no shaft replace, just a 1/4" spacer removed. 1/2" extra wheel travel. But enough to need aftermarket UCAs...which are good anyway.
    des2mtn likes this.
  16. Nov 6, 2021 at 8:07 PM
    Keithbickford
    Keith
    Seattle
    The entirety of the thread is referring to the OEM kit. I don’t think it applies to 3.0. I don’t think there’s a 3.0 OEM kit.
  17. Nov 6, 2021 at 8:14 PM
    Keithbickford
    Keith
    Seattle
    alb1k[QUOTED] likes this.
  18. Nov 6, 2021 at 8:18 PM
    alb1k
    Left Coast
    It's good
  19. Nov 6, 2021 at 8:27 PM
    Keithbickford
    Keith
    Seattle
    We will forgive you this once. :)
  20. Nov 6, 2021 at 8:31 PM
    #50
    alb1k
    Left Coast
    It's good
    Yes! Thank you - but if you ever need to know about the 25001-138 EXT, I'm here! :)
  21. Nov 6, 2021 at 8:33 PM
    #51
    alb1k
    Left Coast
    It's good
    But I still question the same shock body adding 3" of travel...lol
    Keithbickford likes this.
  22. Nov 8, 2021 at 7:55 AM
    #52
    AccuTune Offroad
    AccuTune Offroad New Member Vendor
    El Cajon, CA
    Couple things to clear up.
    -25001-143 King Coilover cannot be converted to a 25001-143-EXT. The EXT uses a different shaft and spacer <-- this is directly from our King rep about a year ago.
    -The 9" to 12" thing, no clue where those numbers are coming from. A 25001-143 coilover has about 7.186" of travel. This puts the wheel travel at about 10.56", extended travel (7.7" travel) pushes it to about 11.32" of wheel travel
  23. Nov 8, 2021 at 8:11 PM
    #53
    Keithbickford
    Keith
    Seattle
    It seems the spacer must be 1.5”. I’ll be taking mine apart over Christmas break.
  24. Nov 9, 2021 at 8:09 AM
    #54
    AccuTune Offroad
    El Cajon, CA
    25001-143 King Coilover cannot be converted to a 25001-143-EXT. The EXT uses a different shaft and spacer.
    A 25001-143 = 7.186" of travel
    A 25001-143-EXT = 7.7" of travel
    14burrito, liltrok and alb1k like this.
  25. Nov 10, 2021 at 7:30 PM
    #55
    Keithbickford
    Keith
    Seattle
    I got my info from filthy Motorsports who rebuilds them. I’ll give them a jingle to sort it out.
  26. Nov 11, 2021 at 6:51 AM
    #56
    AccuTune Offroad
    El Cajon, CA
    Or you could contact King who make the shocks ;)
  27. Nov 11, 2021 at 11:43 PM
    #57
    liltrok
    liltrok New Member
    Anaheim, CA
    2nd Gen DC RW
    Anyway you guys know if you can tell the difference externally between extended vs non-extended because I think it's all internal. I am looking to get some used shocks but its hard to justify if the seller is telling me the truth or not about extended vs not.
  28. Nov 12, 2021 at 5:20 AM
    #58
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    The non extended version have a collar around the shaft inside the body right? Without a serial number or marking outside you could only tell by measuring full extended length
  29. Nov 12, 2021 at 5:35 AM
    #59
    Keithbickford
    Keith
    Seattle
    You’d have to measure the eye to eye length, but it will be a little bit of a challenge since you’re dealing with the upper eye in the middle of the mount.
  30. Nov 15, 2021 at 6:59 AM
    #60
    AccuTune Offroad
    El Cajon, CA
    Like mentioned above, you would need to measure the shock at full extension. You can reference the diagram below to help with where you need to measure. Then just compare those fully extended dimensions to 25.7" (this is the -EXT lengths) Its important to be very accurate with your measurements since none -EXT is 25.3"
    liltrok[QUOTED] likes this.
