6112 Setting and Tire/Wheel Combo Thread.
Discussion in 'Suspension' started by Rngr188, Apr 4, 2018.
  1. Nov 5, 2019 at 6:42 AM
    #661
    COTundra23
    COTundra23 New Member
    My truck is going in the shop tomorrow for the 6112/5160 installation but I am still unsure of what settings i should go with.
    Option 1) 6112 at he top setting and toytec shackle at the 1.5" setting
    Option 2) 6112 at the 1.9" setting and shackle at 1"
    I would like to keep the proper rake for towing, bed weight, and tss sensor.
    Anyone have any pics of either setup or preference towards one or the other?
    Rica25 likes this.
  2. Nov 5, 2019 at 6:49 AM
    #662
    wwinslett
    wwinslett New Member
    Will
    Birmingham AL
    2016 Tundra CM Magnetic Grey
    6112's Toytec Shackles Method NV on Ridge Grapplers 295/70/18
    6112 at top setting
    toytec shackle at middle hole (which i think is 1")
  3. Nov 5, 2019 at 7:15 AM
    #663
    Rica25
    Ricardo
    Tulare
    If I was to do it again I would go with the 1.9 setting I went with 2.5 and a shim
    COTundra23 likes this.
  4. Nov 5, 2019 at 7:55 AM
    #664
    Mike19
    Mike19 New Member
    Chi town
    2019 SR5 CM 4X4 TRD Sport
    TRD Exhaust, Bilsteins 6112/5100, CB Shims 2/1, CB +3 Shackles, Air Ride, RCI Engine and Trans Skid Plates, Cooper AT3 XLT 275/65/20
    Both of those settings will still have a rake. You could go either way. I would go with option 1.
    Rica25, equin and COTundra23[QUOTED] like this.
  5. Nov 5, 2019 at 8:21 AM
    #665
    COTundra23
    for any particular reason?
    Rica25[QUOTED] likes this.
  6. Nov 5, 2019 at 8:57 AM
    #666
    Rica25
    Ricardo
    Tulare
    I have CB +2 in the rear and seems to have a minor nose lift and also little to stiff
  7. Nov 5, 2019 at 8:58 AM
    #667
    Rica25
    Ricardo
    Tulare
    Also my alignment was maxed out so I had to replace UCA
    COTundra23[QUOTED] likes this.
  8. Nov 5, 2019 at 9:03 AM
    #668
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    Mine is set at the top setting + 1/4" CB shim to get 3" front lift. For some reason, I don't have a lean visually. My rear is set at 1.5" via Toytec shackles. I did stuff it with 37x12.5 tires.
  9. Nov 5, 2019 at 7:22 PM
    #669
    cmiller219
    cmiller219 New Member
    Nashville, TN
    2018 Cement CM Tundra
    Sorry still no real photos just a couple point and shoot which I hate. I still don't have new measurements either I am failing royal. Life has been crazy the last 4 weeks. but here are a couple. No issues with any sensors, my lane departure works fine, my cruise control and vehicle sensors work. The truck works as if it was never touched.
    6112 Top Setting
    5160
    Camburg UCA
    CoachBuilder +3 Shackles
    CoachBuilder Shims 2 driver side 1 passenger
    Revtek Diff Drop
    CoachBuilder Carrier Bearing Drop
    Wheels 17x8.5 ET 0
    Tires 35x12.5x17 Nitto Ridge Grappler
  10. Nov 6, 2019 at 3:17 PM
    #670
    COTundra23
    @Toytec Lifts
    Got my 6112/5160 installed today
    1.9 up front
    Toytec 1” shackle in the rear
    BFG 275/70
    Love the stance and drivability this far. Would highly recommend Toytec for parts and install.
    20CDE2A4-B4C3-4570-97E6-7A9BA6B2A64F.jpg A2B1CA15-A269-45BE-B12A-2A5A000E2FFE.jpg
  11. Nov 6, 2019 at 3:25 PM
    #671
    justfortun
    justfortun New Member
    James
    Boston
    2016 SR5
    :bowdown:
    Rica25 and COTundra23[QUOTED] like this.
  12. Nov 6, 2019 at 3:44 PM
    #672
    roy2015
    roy2015 Waterproof
    Houston
    Super White = Super Fast
    What wheels are these exactly?
    How did the tires effect the drivability and the mpg’s?
    dannysmith604 and Rica25 like this.
  13. Nov 6, 2019 at 3:47 PM
    #673
    Icematt
    Icematt Toyota4life
    Black 1794 TRD
    Fuel wheels
    1.3 on the front
  14. Nov 6, 2019 at 5:21 PM
    #674
    cmiller219
    Nashville, TN
    Fifteen 52s
    I’m getting about 11mpg now and they drive great. Smooth all the way to 100mph that I know of and quieter than stock.
    roy2015[QUOTED] and Rica25 like this.
  15. Nov 6, 2019 at 10:16 PM
    #675
    CCLJ03
    CCLJ03 Tundra forever
    Craig
    2018 TRD Off-Road - Cement
    You may not know, seeing as they were on the truck when you bought it, but what would airbag install cost? And how does that work? You have a switch to inflate the airbags in the cab?
  16. Nov 7, 2019 at 3:52 AM
    #676
    trailrnr
    trailrnr New Member
    2013 Rock Warrior CM
    No idea on cost but looks to be a reasonable weekend afternoon DIY (could be wrong on that!).
    Mine has a valve for each side that pop out near my license plate. I have a compressor in my garage as well as my work trailer which is the primary thing I tow so air is always close at hand.
    Rica25 likes this.
  17. Nov 7, 2019 at 12:08 PM
    #677
    Mbraz
    Mbraz New Member
    Wyoming
    2017 tundra
    6112‘s in the front set at 1.9”, SPC upper control arms. 5100’s in the rear with Toytec shackles set at 1”, and a Toytec diff drop kit. 285/75/17 Falken Wildpeak AT3’s on 17” Icon Rebounds in satin black.
  18. Nov 7, 2019 at 12:29 PM
    #678
    MICKs18yota
    MICKs18yota New Member
    Ohio
    2018 Tundra SR
    Nice set up what steps do you have on this and a closeup of them.
  19. Nov 7, 2019 at 1:54 PM
    #679
    justfortun
    James
    Boston
    2016 SR5
    Looks awesome - how much trimming with the 285/75/17?
  20. Nov 7, 2019 at 11:54 PM
    #680
    Mbraz
    Mbraz New Member
    Wyoming
    2017 tundra
    All I’ve done is take off the front aero flaps, they rubbed pretty good on those but only in reverse. Tires rub a just a tiny bit on my mud flaps in reverse still, but They are Duraflap (DIY) that I put on myself. I don’t even think they would rub on stock mud guards
    justfortun[QUOTED] likes this.
  21. Nov 8, 2019 at 3:23 AM
    #681
    Flyinryank
    Flyinryank New Member
    Las Vegas, NV
    White 2015 CM 4x4
    I’m still rocking the 6112 front and 5160 rear combo! 305/65R18 BFG KO2s no issues.
    I just installed some MCM UCAs.
    My question is am I getting the max travel I can or are the 6112s limiting my setup in the front?
    cmiller219 likes this.
  22. Nov 8, 2019 at 5:31 AM
    #682
    Bakelite
    Bakelite New Member
    Sam
    2018 Toyota Tundra TSS 4x4
    Gawd damn that is a might fine looking truck. Want to trade?
    cmiller219[QUOTED] likes this.
  23. Nov 8, 2019 at 7:30 AM
    #683
    georgiey22
    georgiey22 Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    How many miles do you have on the 6112’s?
  24. Nov 8, 2019 at 8:28 AM
    #684
    Flyinryank
    Las Vegas, NV
    White 2015 CM 4x4
    Bout 35k
  25. Nov 8, 2019 at 9:46 AM
    #685
    georgiey22
    Fantastic, interested to learn how durable these shocks are.
  26. Nov 9, 2019 at 3:16 PM
    #686
    BarcelonaSX
    BarcelonaSX New Member
    2019 Barcelona red SR5 SX
    Bilstein 6112 front coilovers @2.5”. Bilstein 5100 rear shocks with toytec shackles @1”. 20x9. Xd grenade wheels with 295/60/20 ridge grapplers. Tinted windows. Gibson single side dual exhaust.
    6112. Top setting. 2.5. Toytec shackles. 1.5” rear. 275/70/18 nitto terra grappler g2.
  27. Nov 10, 2019 at 7:55 PM
    #687
    cmiller219
    Nashville, TN
    Thanks a lot. Took a while to get everything together and did a ton of reading. I picked what I liked on some trucks and parts off others to come up with what I got. I honestly couldn't be happier. Almost went with a 295/70 but at the last min was like f that I'm going a real 35 and everything just worked out.
    Bakelite[QUOTED] likes this.
  28. Nov 10, 2019 at 7:56 PM
    #688
    cmiller219
    Nashville, TN
    they are the factory steps. I am going to remove them soon for sliders
  29. Nov 16, 2019 at 7:15 AM
    #689
    Boris7k
    Boris7k New Member
    2019 TRD Off-Road
    Shell, tint, 6112s at 1.9, 5160s with Icon expansion pack, Cooper ST Maxx LT275/70R18, RCI front skid plate
    6112s at 1.9 with 1 Boss shim on driver’s side, stock rear. Next up will be 275/70R18 Cooper S/T Maxx on the OR wheels. Eventually I’ll add 1.5” leafs and 5160s. I’m digging the ride on the front, firmer and more controlled like I keep hearing.B7073193-6B8B-4F6D-8F13-18ADA37A4AD4.jpgC61B1D36-DF9F-4F0E-AECF-D9474011EB5A.jpg
  30. Nov 16, 2019 at 7:46 AM
    #690
    Stocky Balboa
    Stocky Balboa New Member
    OC , CA
    2018 Limited TRD 4x4 CM - Cement
    Minor stuff- Tint, rear sway bar , pedal commander, TRD drop in filter DD Exhaust, Bilstein 6112/5160, stealth 32” lightbar, Cali Raised Offroad fog light replacements.
    Got my 6112 done yesterday. Top setting, stock tires, wheels (for now). Has about .25” reverse rake. It doesn’t bother me. I’ll add bags soon. I’m stoked on the look and love the ride, soaks up everything much better and feels solid.
    I’ll be installing the 5160 today.
    Thanks Tundra forum the advice on this setup.
    Before and after
