  1. Oct 31, 2019 at 1:48 PM
    qwikkut
    qwikkut New Member
    qwik
    1794 4x4 Tundra
    Thank you
  2. Oct 31, 2019 at 2:25 PM
    YoTundra
    YoTundra New Member
    2018 Tundra SR5 Quicksand
    New wheels, tires, and 2.5" leveling kit. But now the front is a little higher than the rear :annoyed:
    mgm16trdpro, yoshi82, NAFlash and 3 others like this.
  3. Oct 31, 2019 at 2:43 PM
    deepblu89
    deepblu89 New Member
    2018 Barcelona Red Tundra
    If you saw my other thread you'll know it wasn't as simple as I had hoped but the Victory 4x4 skid plate is now on my truck.
  4. Oct 31, 2019 at 2:51 PM
    HappyGilmore
    HappyGilmore Ex 1st Gen Member
    Trent
    Lakewood CA
    2018 White Limited TRD 4x4
    What leveling kit do you have? It looks like a bit more than 2.5". If you have the Bilstein 5100, the coil seat could possibly be installed incorrectly. Which is dangerous, and can cause it to lift higher. To me, this looks to be the case.
  5. Oct 31, 2019 at 3:08 PM
    DCB500
    DCB500 New Member
    Oklahoma City
    2019 Tundra SR5 TSS Double Cab
    Wheels, sound system, antenna, tailgate letter inserts, Grill/Hood Bulge, Exhaust, Leather
    yeah the front looks quite a bit higher....I am certainly no lift expert but from research I have been doing 2” front lift should be basically level but that looks like quite a bit more than 1/2” higher than the rear.
    aussieaarons likes this.
  6. Oct 31, 2019 at 4:44 PM
    aussieaarons
    aussieaarons die with memories, not dreams
    2019 Cavalry Blue TRD
    2” level, roof mount DVD, interior LED bulbs, sumosprings out back, OEM folding cover, Blackout emblems
    2” Leveling kit installed last night and alignment done this afternoon at a local shop. Exact look I was after
  7. Oct 31, 2019 at 4:49 PM
    YoTundra
    YoTundra New Member
    It's the rough country leveling kit. I also have all these lights on, but they did break a speed sensor when disassembling, that they ordered, am hoping that's the cause of the lights. Any input?
    I've had this on ramps and started it and had no alerts?
    I think I'm going to need to put 1" in the rear.
  8. Oct 31, 2019 at 5:59 PM
    biebs96
    PA
  9. Oct 31, 2019 at 6:34 PM
    Gabrielo93
    Gabrielo93 New Member
    Gabriel
    Grand Prairie, TX
    2015 Black Toyota Tundra SR DC
    12 Volt Remote Starter Lockerdown Safe ICS Fab Dash Mount Husky All Weather Beaters Mats Rear Folding Seat Mod Linex Platinum Kicker Sub/Amp Combo CoverCraft Dash Cover Kenwood Headunit Cravenspeed Untenna CupHolderHero Aukee Tailgate Inserts OEM Deck Rails Rolling tonneau cover CravenSpeed Untenna
    How long did it take to receive your order?
  10. Oct 31, 2019 at 6:36 PM
    Blueknights75
    Ron
    Clayton, NC
    Time for some CB shackles...
    mgm16trdpro likes this.
  11. Oct 31, 2019 at 6:46 PM
    biebs96
    PA
    22 calendar days for this order. I’m still waiting on another order.
    In my honest opinion, it is 100% worth the wait.
    My neighbor has the TRD PRO center caps and these look exactly like them as far as fit and finish (obviously the design is different) but they cost less then 1/2 the price of one OEM part.
    Gabrielo93[QUOTED] likes this.
  12. Oct 31, 2019 at 9:36 PM
    HappyGilmore
    Trent
    Lakewood CA
    The lights are odd, but hopefully the speed sensor will fix it.
    Also I read that the Rough Country kit is a spacer kit, and includes shims to fine tune your ride height. If all shims are used then it will be a 3 inch lift. Nothing wrong with that (might be a bit challenging to align, but not impossible) . And if you like that height, then you can lift the rear to level it. Otherwise see if they used all the shims, and if so you can remove some to lower the front level with the rear.
    GODZILLA likes this.
  13. Oct 31, 2019 at 10:20 PM
    16TRD
    16TRD New Member
    Norcal
    2016 White crewmax
    I was just about to ask this right here. Im betting the coil seat is upside down.
  14. Oct 31, 2019 at 10:21 PM
    16TRD
    16TRD New Member
    Norcal
    2016 White crewmax
    take a pic of the coilover
  15. Nov 1, 2019 at 6:55 AM
    HappyGilmore
    Trent
    Lakewood CA
    He said he used the Rough Country 2.5" level kit. I'm not familiar with it, but a quick Google search shows its a spacer lift. Stock coilover untouched.
  16. Nov 1, 2019 at 7:47 AM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    what wheels are those? Fuel techs?
  17. Nov 1, 2019 at 8:09 AM
    YoTundra
    YoTundra New Member
    Exactly, I told them 2.5", well, they added all the spacers to make it 3".
    What's better to use, shackles or icon 1.5" rear spring lift?
  18. Nov 1, 2019 at 8:10 AM
    NAFlash
    NAFlash New Member
    Randy
    Tundra TRD Sport 4x4
    Love the wheels and tires. Don't care to much for the front higher than the rear, just personal preference though. And is that snow, wow, haven't seen that in long while.
  19. Nov 1, 2019 at 8:13 AM
    YoTundra
    YoTundra New Member
    Wheels are 20" kmc XD135 in bronze +18 offset. I am a little surprised that the tires rub, only a 33" tire. Tires are Falken wildpeak, I like them, no tire drone.
  20. Nov 1, 2019 at 8:16 AM
    YoTundra
    YoTundra New Member
    Yeah, I dont care for it either, they added all the spacers when I told them 2.5". I will be doing something to the rear, not sure if shackles or icon spring lift is better?
  21. Nov 1, 2019 at 8:18 AM
    HappyGilmore
    Trent
    Lakewood CA
    I don't have experience with either one on these trucks, but I have read good things about both. I'm sure others will give input.
  22. Nov 1, 2019 at 8:32 AM
    robz
    robz New Member
    Rob
    2015 Platinum 2WD
    Full interior LED lights. Bed cover. OEM LED Headlights and Fog lights
    Wow...I can see you put up your Christmas tree early this year :rofl:J/k
  23. Nov 1, 2019 at 11:05 AM
    Ted4311
    Ted4311 Don't Sweat The Small Stuff
    SOMD
    14 Tundra MGM TRD-OFFROAD 4X4
    A LOT... NEVER ENDS
    Washed and quick detail. Great day off
    mgm16trdpro, GAknight, Bama and 7 others like this.
  24. Nov 1, 2019 at 11:14 AM
    Ted4311
    SOMD
    A LOT... NEVER ENDS
    Hit the tires with some shine. More gooder
    mgm16trdpro, GAknight, equin and 8 others like this.
  25. Nov 1, 2019 at 11:57 AM
    Cthulhu
    I have a Pro Comp 2.5" leveling kit, and the rake is perfectly flat; no spacers or shims were added. Now that you have a mini Carolina Squat, your TSS sensor may be throwing all those lights...
    Here's what mine looks like.
  26. Nov 1, 2019 at 12:48 PM
    Gabrielo93
    Gabriel
    Grand Prairie, TX
    I should get them soon I ordered them about 20-24 days ago. Thanks they look awesome
    biebs96[QUOTED] likes this.
  27. Nov 1, 2019 at 1:48 PM
    benharrison
    benharrison New Member
    2020 MGM CrewMax SR5 4x4
    Replaced black plastic door handles and mirror trim with chrome.
  28. Nov 1, 2019 at 2:01 PM
    easleycrawler
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
    Yes, one of the few chrome adders.
    :headbang:
    classiccat, mike44, Leetomnsx and 2 others like this.
  29. Nov 1, 2019 at 2:07 PM
    benharrison
    Yeah I feel like I'm in a minority. I understand the motives behind chrome-delete because I did that with my old Tacoma, but my tastes have changed a bit with the Tundra. I like really liked the look of the Limiteds and Platinums, but couldn't find one in a 6-passenger.
  30. Nov 1, 2019 at 3:39 PM
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Installed my carrier bearing drop today, super quick and easy install. I didn't realize how much vibration I had until I installed the drop kit, but it's all cleaned up now! VeIB3oQ7Tg+uctU4wP1oIA.jpg
    mgm16trdpro, GAknight, equin and 2 others like this.
