Truck in the shop
Discussion in '2.5 Gen Tundras (2014-2021)' started by havasuTRD, Sep 27, 2019.
  1. Sep 27, 2019 at 4:19 PM
    havasuTRD
    havasuTRD [OP] New Member
    Brett
    2017 Tundra crewmax TRD 4X4
    Went in for a simple oil change with my trustworthy local mechanic and I got a surprise. Shows me what they suspect is the rear main. Truck only has 25k on it. So I called toyota since they have done 2 oil changes on it (freebies) and I went in to see a service guy. I was alittle pissed that this is the first time I’m hearing of this. IM sure the Toyota tech that did my last oil change had to of seen this. Anyways, Toyota doesn’t think it’s the rear main but maybe a seal in the bell housing or the camshaft. They put dye in the oil and are gonna crack her open in a week after I get some miles on it. Shit!!! Anyone have similar problems? 5234EB05-FC2E-407D-BD3B-D5D0331D52A6.jpg
    Y0TA PR0, georgiey22 and Rica25 like this.
  2. Sep 27, 2019 at 6:24 PM
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    17' Tundra SR5, 12' Tacoma TRD offroad
    Could be worse, could of been your cam towers leaking. Still sucks, truck only has 25k on it this is unacceptable.
  3. Sep 27, 2019 at 6:52 PM
    havasuTRD
    Brett
    They didn’t rule out the camshaft seal yet. I doubt it’s the towers cuz I’ve been looking and they’re still dry. We’ll see. I’m bummed but it will get fixed under warranty at least
    GODZILLA likes this.
  4. Sep 27, 2019 at 7:35 PM
    AZTundra
    Paul
    Phoenix, AZ
    I recall seeing a similar thread a while back. I'll take a search for it, but I'm pretty sure this has come up before.
    TheBeast and YardBird like this.
  5. Sep 27, 2019 at 7:37 PM
    AZTundra
    Paul
    Phoenix, AZ
  6. Oct 9, 2019 at 7:40 PM
    havasuTRD
    Brett
    Got the truck back today. They did the rear main seal. Thought everything was cool until I got home and heard an awful sound under the truck. Take a listen. Back to Toyota tomorrow!!!
    Nevermind, can’t load my video clip.
    AZTundra likes this.
  7. Oct 9, 2019 at 9:34 PM
    AZTundra
    Paul
    Phoenix, AZ
    Any ideas what the issue could be?
  8. Oct 10, 2019 at 7:58 AM
    havasuTRD
    Brett
    Not sure yet, driving her down to the dealership soon. I wish I could post the video I made on my iPhone. Not savvy enough
    AZTundra[QUOTED] and Black Wolf like this.
  9. Oct 10, 2019 at 12:53 PM
    havasuTRD
    Brett
    Well, service guy heard the noise clear as day and now I’m in my second rental!!! This is getting fun. 25k miles on a tundra and already having these problems? Wtf
    YardBird likes this.
  10. Oct 10, 2019 at 1:08 PM
    MatthewPTguy
    MatthewPTguy Not a new member
    Eugene, Oregon
    2017 Tundra 5.7 DC TRD MGM
    Borla dual cat back exhaust system, K&N replacement air filter, Headlight Revolution 40" Stealth LED light bar, Headlight Revolution LED fog light replacement bulbs, Line X bed liner, de-badge
    Yeah... I had the same problem... they “fixed “ it once... replacing the seal.. began leaking again. There was an issue with pins on the transmission or the block that weren’t set to the right depth. Once they seated them and put it all back together it was good to go.
    Check out the thread quoted above
    YardBird and AZTundra[QUOTED] like this.
  11. Oct 10, 2019 at 1:09 PM
    toyoboyo
    toyoboyo New Member
    Made in the good 'ol US of A!
  12. Oct 10, 2019 at 1:45 PM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    He dropped his 10mm in there and never got it back.
    Remove 10mm and good to go I bet
    15whtrd, Tundyfundy, mdavis and 5 others like this.
  13. Oct 10, 2019 at 1:50 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
  14. Oct 10, 2019 at 2:11 PM
    havasuTRD
    Brett
    Got the call from the service guy. Turns out it was a bent heat shield that was touching the exhaust making the noise. Thank God. Hopefully the rear main is all good now and I can be happy again. I was about to go and buy a Dodge!!!
  15. Oct 10, 2019 at 3:07 PM
    havasuTRD
    Brett
    I know I apologize. I just read it out loud to myself
  16. Oct 31, 2019 at 12:21 PM
    havasuTRD
    Brett
    Crawled under the beast on Saturday and saw some oil near the “u” section of the housing. Just dropped it off again at Toyota. I got the “we’ll have to check with Toyota” answer on how to proceed. I told the service guy about the alignment pins specs and he thought that was interesting....let you guys know ASAP what’s going on. Obviously a problem on these trucks
  17. Oct 31, 2019 at 12:32 PM
    Badger Co-Op
    Badger Co-Op Blood sausage, cheese, and lutefisk; hit me!
    Kenny
    WISCO
    It's a mechanical beast that we feed oil, gas, and exponential amounts oxygen depending on your bolt-ons. There is no problem. You are looking at results of known quantities of heat traded for fun and $$$. Act accordingly....
  18. Oct 31, 2019 at 3:05 PM
    HappyGilmore
    HappyGilmore Ex 1st Gen Member
    Trent
    Lakewood CA
    2018 White Limited TRD 4x4
    Our expectations may be different, but I do not expect my truck to leak for a very long time. I sold my 1st Gen with 200k and no leaks during my ownership.
  19. Oct 31, 2019 at 3:19 PM
    havasuTRD
    Brett
    You’re the man!! Same feelings. They added my dye since they couldn’t find a trail. I’m returning it on Monday. They opened a case with Toyota. I will be calling toyota after this
  20. Nov 1, 2019 at 5:52 AM
    db52282
    db52282 New Member
    Georgia
    2017 Silver Tundra Limited
    Please post the outcome with dealer and Toyota.
    I'm interested in knowing how they deal with this situation.
    YardBird and havasuTRD[OP] like this.
  21. Nov 1, 2019 at 6:59 AM
    915tundra
    915tundra New Member
    LEE
    WEST TX
    2017 Tundra TRD Pro
    snivilous and Badger Co-Op like this.
  22. Nov 1, 2019 at 7:22 AM
    Man, oil and fluid leaks seem to be the Achilles heel of new Tundras. Amazing that Toyota screws that part up after building such awesome machines.
    My Tundra is almost 18 years old and doesn't leak anywhere.
  23. Nov 1, 2019 at 7:48 AM
    Badger Co-Op
    Kenny
    WISCO
    I'm with ya. The 5.7 motor is a beast. Europeans have a thing for oil leaks, and protecting their water supplies linked to leaks on the streets. Americans used to take it as a pride of ownership for some sort of leakers club......when the 5.7 was a GM engine. Toyota owners are better than that, KUDOS to you!
  24. Nov 5, 2019 at 4:48 PM
    havasuTRD
    Brett
    Got the call from the dealer. Couldn’t find a leak or any dye trail. They want me to put some more miles on it and monitor. So tired of driving to/from dealership and using rental cars!! The service tech said maybe the rear main seal finally seated after so many miles and heat...? I hope so cuz if not, I’ll be back!!!
  25. Nov 5, 2019 at 5:44 PM
    db52282
    db52282 New Member
    Georgia
    That is a new one one me!! Never heard that a rear main can "seat itself". I would get another opinion.
  26. Nov 5, 2019 at 6:18 PM
    havasuTRD
    Brett
    I guess I should Have said that better. They resealed the rear main a couple weeks back. I would take it to my independent mechanic but this is all under warranty so I’m at their mercy
  27. Nov 5, 2019 at 6:56 PM
    db52282
    db52282 New Member
    Georgia
    No problem man. It just sounded like they were trying to pull a fast one over on you.
    I truly hope they have fixed the leak. I know I absolutely HATE any kind of leaks.
  28. Nov 5, 2019 at 7:03 PM
    TheBeast
    TheBeast The Beach
    ugh that sucks
  29. Nov 20, 2019 at 1:01 PM
    havasuTRD
    Brett
    Update on my truck. So I crawled under the beast last week and still noticed oil on the bell housing. Brought it back again to the dealership (under warranty) and they finally found the dye trail which lead to the upper oil pan. Toyota technical told them to check that. Apparently they have had a “pitting” issue and leaks. Bummer is, they have to yank the motor to fix it. Only has 26k on it. I’ll be reaching out to Toyota customer care and reporting how un happy I am. For those of you that have complained to them, did they do anything for you? I almost want to ask for a new truck or deal somehow. Or am I just being paranoid and it’ll be all good. Thoughts?
    ColoradoTJ likes this.
  30. Nov 20, 2019 at 1:06 PM
