Skid plate hole for filter replacement
Discussion in 'New Member Introductions' started by Rubysdad, Oct 29, 2019.
  1. Oct 29, 2019 at 9:18 AM
    Rubysdad
    Rubysdad [OP] New Member
    Paul
    Northern Neck, VA
    2014 white Tundra Trd 4x4 DC 5.7
    20191029_130603.jpg Hello all! My new to me 2014 dc 5.7 needed an oil change. All the horror stories I've read here are true. Oil cap was put on with an air gun... took a breaker bar to get it loose. Put a new aluminum one on. When I took the perforated tall tube out of the old cap to transfer it... they didn't bother to put the spring back in! Once again, that's why I do my own maintenance. Put a new Fumoto valve on, Toyota filter and Mobile 1 synthetic 0w 20. As I had the skid plate off, I decided to cut a hole for filter access. Cut a 6" square hole... plenty of room to work. Decided on a door configuration that would be easy and secure. I cut a piece of 5v roofing tin about 8" square. Hardware store had several sizes of clip nuts, typically used for securing fender liners and such. Arranged 4 at corners, or near and drilled holes to match the 6mm stainless bolts. Bent the roofing tin to match the curve and secured it. Now all I have to do is take out 3 bolts, loosen the 4th and slide it back for access. I'll try to attach a few picures before too long. Really enjoy this site. An old dog can still learn alot here!20191029_092547.jpg 20191029_092317.jpg
  2. Oct 29, 2019 at 9:21 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Welcome from SoCal!
    Nice work!
  3. Oct 29, 2019 at 9:39 AM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    Welcome from NH. I need to do that.
  4. Oct 29, 2019 at 9:52 AM
    Welcome from NY.
  5. Oct 29, 2019 at 9:54 AM
    Welcome from Colorado.
  6. Oct 29, 2019 at 9:55 AM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    Very nice work and good contouring. Haven't seen anyone do this with a Rivnut tool which would be cool
    Tundyfundy and Pinay like this.
  7. Oct 29, 2019 at 9:55 AM
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    paint it!
    Looks good though :thumbsup:
    Pinay likes this.
  8. Oct 29, 2019 at 10:02 AM
    Mcoop
    Mcoop Throbbing Member
    Michael
    Berlin, NJ
    2015 Black SR5 5.7L DCLB 4x4
    Welcome from southern NJ.
    Pinay likes this.
  9. Oct 29, 2019 at 10:14 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Welcome! Nice work. A few others have done similar.
  10. Oct 29, 2019 at 10:19 AM
    Welcome from TEXAS
  11. Oct 29, 2019 at 1:44 PM
    mambo143
    mambo143 New Member
    Phil
    Maine
    2016 Tundra TRD Crewmax
    Bilstein 6112, 5160, Coachbuilder 1” shackle lift, Wildpeak A3’s, LED backup, Maxiplus mats, Bak Rollover Mx4, BedRug, Westin HD Headache Rack. Westin HD Brush Guard, Spidertrax 1.5 spacers. TRD Brakes. Headlight Revolution LED. TRD rear Torsion Bar. Dirty Deeds 10 inch Stainless. TRD Pro Grill. Bushwhacker Pocket Flares. Baja Designs Combo Driving/Fog lights.
    Welcome from Maine
    I have a replacement skid plate set aside and am about to do this, so your post is timely and helpful.
  12. Oct 29, 2019 at 4:03 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Good job, welcome from AZ
  13. Oct 30, 2019 at 5:41 AM
    Welcome from Ohio.
  14. Oct 30, 2019 at 6:01 AM
    MAGDADDY
    MAGDADDY TTC #280
    JON
    Houston TX
    18 Platinum CM MGM
    Leer 100XL, Bedrug, Go Rhino running boards, LED int/ext lighting, Bilstein 6112/5100 1/2”shims up front, Coachbuilder +3 shackles, CB drop, TRD front/rear sway bar, 275/65/20 Michelin LTX M/S 2, sequoia painted mirror cap/door handles, Rago Fab low pro ditch brackets, Baja Designs S2 sports ditch lights. Baja Designs S2 sport rear flush mount pod
    Welcome! That’s gonna be helpful for sure.
  15. Oct 30, 2019 at 6:19 AM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Welcome to the party!!!
  16. Oct 30, 2019 at 7:09 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    Welcome from So Cal. I need to find the time to do that to my skid plate. Sure will make oil changes much easier.
    NewImprovedRon likes this.
  17. Oct 30, 2019 at 7:17 AM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Welcome from Ventura California
  18. Feb 10, 2020 at 4:46 AM
    parkerbows
    parkerbows New Member
    Jack
    2017 crew max sr5 trd off road
    Firestone air ride air bags
    would you happen to have measurements for hole you cut. in other words where the hole is not so much the size
  19. Feb 10, 2020 at 5:36 AM
    Rubysdad
    Paul
    Northern Neck, VA
    I just looked at a few pictures here of holes others had cut and lined up with those. Mine is a bit bigger at 6 inches, but makes for really easy access. There are a few points where, on the engine side, there are flanges that are welded on that make a double layer to cut through. I used those as guides as I didn't want to lessen the structural integrity of the skid plate. Just look at the pictures of mine and mark the corners. Draw connecting lines, drill small holes at the corners, flip it over, and see if you avoid those flanged areas. When I bent the cover, I slid a wood dowel under the cover, put it in place and beat it with a rubber mallet to shape. One of the most satisfying projects I've done. This, a Fumoto valve and oil filter drain attachment and oil changes are a breeze!
    NewImprovedRon and WILLINH like this.
  20. Feb 10, 2020 at 5:47 AM
    Rubysdad
    Paul
    Northern Neck, VA
    As a side note, I sprayed the skid plate and cover with Permatex rust converter and some Rustoleum paint on both sides. Much better.
  21. Feb 10, 2020 at 7:52 AM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    I did mine several years ago. Turned out well and makes for a cleaner, quicker oil change.0503150903.jpg
  22. Feb 10, 2020 at 1:57 PM
    toner9001
    toner9001 New Member
    Walter
    Tundra 2006
    Nice job folks. toyota should incorporate into production, perhaps as a dealer mod. for those less handy folks.
  23. Apr 13, 2020 at 8:05 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Did mine yesterday. Also changed the front diff oil which was completely clean, looked brand new. Oh well. Between this new hole and the Fumoto valve oil changes will be a breeze. I use pics from this thread to cut my hole so thanks fellas, I really appreciate it.
  24. Apr 13, 2020 at 10:08 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    Good Job and welcome aboard from SoCal.
  25. Apr 14, 2020 at 3:39 AM
    Rubysdad
    Paul
    Northern Neck, VA
    Looks good! Glad my experiment helped you in some way. Post some pics of the finished product. Welcome aboard!
  26. Jun 25, 2020 at 11:27 AM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    Almost ready to put back on, just have to clean everything up.
    Ragnarkov, bowtieman55 and RitcheyRch like this.
  27. Jun 28, 2020 at 10:28 AM
    SILVER FOX
    SILVER FOX New Member
    GARY
    IDAHO
    2015 SILVER DOUBLE CAB
    BULL BAR ** FENDER FLAIRS ** TINTED WINDOWS ** VISOR VENTS.....so far. :)
    I.... LIKE IT !.....:yes::) ... painted body color? All it needs is pin striping...or...flames? scallops? Don't mind me, I'm just an old hot rodder who use to do those things.
    I am detail oriented also; I will be doing mine soon.
    I recently purchased/joined the forum after buying my 2015 Tundra, found the thread/pics of your mod, so I am a little late to the party. Again, nice job!
  28. Sep 26, 2020 at 2:08 AM
    CMB
    CMB New Member
    Cecil County MD.
    I'd like to see Toyota INCLUDE it into production too.
    WILLINH likes this.
  29. Sep 26, 2020 at 10:42 AM
    ericnvb
    ericnvb New Member
    Eric
    Virginia Beach, VA
    2020 TRD Pro
    Nice and Clean looking
  30. Sep 28, 2020 at 5:25 PM
    Rgross2112
    Rush
    2020 Silver TRD Limited
    Welcome from Pennsylvania
