6112 Setting and Tire/Wheel Combo Thread.
Discussion in 'Suspension' started by Rngr188, Apr 4, 2018.
  1. Oct 25, 2019 at 2:16 PM
    #631
    CementTurdOffRoad
    CementTurdOffRoad New Member
    Andrew
    Maryland
    '19 Cement Limited Off Road
    6112 - 1.9”, and 1 CB shim on driver side. 5160 with no lift. D137E759-8385-46CD-BF0E-B35CD2B729D6.jpg18180D75-5A94-49E3-83E1-DEE0EA6CC924.jpg
  2. Oct 25, 2019 at 2:24 PM
    #632
    danno266
    danno266 n00b
    2016 White CM SR5/TRD OR
    Looks damn perfect! This is probably the setup I'll take when the time comes for new tires (aka larger).
  3. Oct 25, 2019 at 4:51 PM
    #633
    Youth is overrated
    Youth is overrated New Member
    2017 Silver Tundra CM TRD
    6112/5160 2.5 +2 driver 1 pass CB shims, CB+3 shackles,
    What size tire are you running on that setup?
    Rica25 likes this.
  4. Oct 25, 2019 at 5:17 PM
    #634
    BarcelonaSX
    BarcelonaSX New Member
    2019 Barcelona red SR5 SX
    Bilstein 6112 front coilovers @2.5”. Bilstein 5100 rear shocks with toytec shackles @1”. 20x9. Xd grenade wheels with 295/60/20 ridge grapplers. Tinted windows. Gibson single side dual exhaust.
    That looks killer. Just ordered the 6112s at 1.9. Ordered 275/70/18 terra grapplers. Going on my stock black 18s. Leaving the rear suspension alone for now since I sometimes park in garages at work.
  5. Oct 26, 2019 at 6:13 AM
    #635
    CementTurdOffRoad
    Andrew
    Maryland
    275/70R18 Nitto Ridge Grapplers
    Davesbase and Rica25 like this.
  6. Oct 26, 2019 at 6:30 AM
    #636
    airgunner
    airgunner New Member
    N-KY
    2015 DC MGM TRD
    I wish I had done the 1.3" :(
    I did the 1.9 because I was afraid the 1.3 wasn't going to be enough for the tire I was getting (297/70R17) but turns out the 1.3 would have been plenty.
    I guess I'm weird but I think the Tundra looks much better with a little forward rake. My truck is pretty level at 1.9 but on an incline or a bunch of stuff in the rear I get that horrible cali/bro lean look that I can't stand.
    I have some Toytec shackles that I can install but I'm honestly seriously considering taking the truck back to the shop and having the fronts dropped to the 1.3 setting
  7. Oct 26, 2019 at 8:00 AM
    #637
    Icematt
    Icematt Toyota4life
    Black 1794 TRD
    Fuel wheels
    I've 285/60-20 on the 1.3 settings and the ride is awesome.
    Rica25 likes this.
  8. Oct 26, 2019 at 9:56 AM
    #638
    phonyteachr
    phonyteachr New Member
    2018 SR5 TRD off-road CM
    Wow looks great! What size and offset rims do u have? What size tires ? Any issues with rubbing?? Thanks.
    Rica25 likes this.
  9. Oct 26, 2019 at 11:13 AM
    #639
    CementTurdOffRoad
    Andrew
    Maryland
    Thanks. Wheels are 18x9 +25mm offset. Tires are 275/70R18 Ridge Grapplers. No rubbing at all!
  10. Oct 26, 2019 at 11:36 AM
    #640
    dlowry81
    dlowry81 New Member
    Doug
    2004 Tundra Doublecab
    I don’t think I ever posted pics of mine finished. 6112’s @ 1.9 with 1 shim per side, 5160’s with CB +2 shackles, CB bumper shims, removed small front mud flap, and Icon rebound in bronze with 285/75/17 Cooper AT3 XLT’s. No rubbing anywhere.
  11. Oct 26, 2019 at 1:01 PM
    #641
    phonyteachr
    Thanks for info!!
  12. Oct 26, 2019 at 11:14 PM
    #642
    unclebeejo808
    unclebeejo808 New Member
    Oahu
    How’s the ride on top settings? I got mine coming in to replace a spacer lift, debating about going 1.9 or top setting.
    Rica25 likes this.
  13. Oct 26, 2019 at 11:35 PM
    #643
    Dirtfiend
    Dirtfiend New Member
    So.OC
    2019 SSM 5.7 Crew Max 4x4
    Bilstein 6112 front (2.5")/5160 rear Total Chaos UCAs Toytec Shackles 1" Method Roost 18x9 Falken Wildpeaks 295/70 R18 Carven Cat Back Exhaust Baja Designs Squadron Fogs (Amber) Stubby Antennae Blackout Badges/ Tailgate Insert Front Tint (20%) K&N Air Filter Gate King adjustable lift gate Color matched grille/bulge
    The ride is a little stiff, but I feel like they’ve softened some over the last 3 months. I have nothing else to compare the ride quality to on these other than the stock suspension, which that was totally improved otherwise. I hear it’s softer at the 1.9 setting, so maybe that’d be your preferred route if retaining some “plushness” is a concern.
    Rica25 and unclebeejo808[QUOTED] like this.
  14. Oct 27, 2019 at 8:38 AM
    #644
    dlowry81
    dlowry81 New Member
    Doug
    If you want the height but retain the plushness, go 1.9 with 1 shim like I did. My dad was fully convinced I was ruining the ride when he came over and helped me install them. After a 3 hr ride in it to go fishing he couldn’t believe how smooth the ride was. I highly recommend going this route.
  15. Oct 27, 2019 at 2:06 PM
    #645
    cmiller219
    cmiller219 New Member
    Nashville, TN
    2018 Cement CM Tundra
    I would have to say that even a 2.5 the ride is way less harsh and more comfortable than the stock offload suspension.
    equin, drobb, Rica25 and 1 other person like this.
  16. Oct 28, 2019 at 5:23 PM
    #646
    COTundra23
    COTundra23 New Member
    how are you liking the AAL?
    Rica25 likes this.
  17. Oct 29, 2019 at 12:33 AM
    #647
    roy2015
    roy2015 Waterproof
    Houston
    Super White = Super Fast
    Any idea what the largest size tire that can be ran set at 1.9" with TRD wheels. I've seen 295/70/18 with aftermarket wheels (post #119). 285/70/18 has been done (post #314).
    I personally don't need lift, I only need larger tires. Trying to find the best way to accomplish that.
    Rica25 likes this.
  18. Oct 29, 2019 at 1:00 AM
    #648
    Depends on how much larger you need the tires and how willing you are to chop up the truck. Generally speaking, the best way to accomplish tires is going to be with a lift.
    roy2015[QUOTED] and Rica25 like this.
  19. Oct 29, 2019 at 2:42 AM
    #649
    phonyteachr
    Any issues with rubbing or trimming on your set up? After a couple months do you still like the 285/70/18's?
    Rica25 likes this.
  20. Oct 29, 2019 at 8:27 AM
    #650
    Cement
    Cement ...
    2019 Cement Trundra TRD
    No complaints.
  21. Oct 29, 2019 at 5:47 PM
    #651
    BarcelonaSX
    Got my 275/70/18 terra grapplers today. I also changed my mind and asked boss to set my 6112s at 2.5 instead of 1.9 and to send me 5100s and toytec shackles for the back. Lol. . Now the question will be 1 or 1.5 out back. Maybe I’ll flip a coin.
  22. Oct 29, 2019 at 10:12 PM
    #652
    Mike19
    Mike19 New Member
    Chi town
    2019 SR5 CM 4X4 TRD Sport
    TRD Exhaust, Bilsteins 6112/5100, CB Shims 2/1, CB +3 Shackles, Air Ride, RCI Engine and Trans Skid Plates, Cooper AT3 XLT 275/65/20
    If you plan to tow, then go 1.5. It’ll give you a little bit of rake.
  23. Oct 30, 2019 at 5:16 AM
    #653
    Bakelite
    Bakelite New Member
    Sam
    2018 Toyota Tundra TSS 4x4
    :muscleflexing: Awesome looking!
  24. Nov 3, 2019 at 5:10 PM
    #654
    Stocky Balboa
    Stocky Balboa New Member
    OC , CA
    2018 Limited TRD 4x4 CM - Cement
    Minor stuff- Tint, rear sway bar , pedal commander, TRD drop in filter DD Exhaust, Bilstein 6112/5160, stealth 32” lightbar, Cali Raised Offroad fog light replacements.
    Is it safe to say you can go with 6112 at (Top setting 2.5) with 5160’s out back w/ air bags and be good to go for towing?
    Don’t have to add shims , UCA’s or shackles etc?
    dannysmith604 and Rica25 like this.
  25. Nov 3, 2019 at 5:13 PM
    #655
    trailrnr
    trailrnr New Member
    2013 Rock Warrior CM
    That’s my exact setup. I tow frequently for work and it all works great.
    Rica25 and Stocky Balboa[QUOTED] like this.
  26. Nov 3, 2019 at 5:14 PM
    #656
    Stocky Balboa
    OC , CA
    Sweet. I’ll be doing this setup in the next few weeks. Appreciate the feedback.
    What bags do you use ? Firestone or Air Ride ?
    Rica25 likes this.
  27. Nov 3, 2019 at 5:20 PM
    #657
    trailrnr
    trailrnr New Member
    Airlift Load lifter 5000. They were on the truck when I bought it. They really do an amazing job. Way more stable towing.
  28. Nov 4, 2019 at 6:05 PM
    #658
    RW-3
    RW-3 May the Mods be with you
    Rob
    16 Black TRD CM 4x4
    Lights: 2018 OEM Black Chrome LED’s Morimoto XB Fogs Interior LED upgrade - VLED’s LED reverse / cargo - VLED’s Footwell lights, vanity lights, break lights, rear turn signals, 3rd break light - All VLED’s 30” Rough Country light bar hidden in bumper w/ Rago Fab Brackets Matt Gecko LED bed lights (red & white) and hood lights Exterior: Truxedo Lo Pro QT WeatherTech in-channel window deflectors Interior: Husky X-Act Contour front & rear Front, back and rear windows all tinted 10% Ceramic Heat Film on Windshield 70% OCD console organizer OCD console tray TRD 4x4 inserts on Husky mats by Achuop Tacoma TRD Pro shift knob with TRD leather boot AJT Design vent ring trim - chrome delete Center console wireless charger Drivers side grab handle Performance: Dirty Deeds BA Muffler 12” Budget Standard System TRD Rear Sway Bar AFE Pro Dry S Air Filter Bilstein 6112 1.9” clip Bilstein 5100 - rear Coachbuilder +1’s Nitto Ridge Grapplers 285/70/18 Audio: Infinity dash speakers Tech12Volts custom center dash speaker Hertz Uno door speakers JL Audio RD 900/5 amp 2 JL Audio 10w-0 v3 10” subs in custom Tech12Volts box Protection: McGuard Tailgate Anti theft lock OEM tailgate lock w/ Dynamat TRD Pro skid plate SNS ARB sensor guards Misc: TRD key fob case AJT Designs Rear diff breather mod Fortin remote start with Car Link CL6 TRD battery bracket by Coupe TRD valve stem caps TRD interior handle inserts by abomb60 (Adam)
    No regrets at all. The shop had to trim the skid plate a little and that’s it. No rubbing at all. Very happy with the 285’s. From a dead stop I pulled my 1,400lb ski boat up a hill with wet grass from morning dew and it didn’t slip once in 2wd. Thought for sure I’d need 4 wheel high at minimum. Lost a little on the MPG’s but I wasn’t setting any records before these tires.
    Rica25 likes this.
  29. Nov 4, 2019 at 6:40 PM
    #659
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, King 2.5's/Bilstein 5160's, Built Right UCA,s, Method 701's, TOYO ATIII 35x12.5x17, TRD LED headlights, Pro Grill
    Looking for input: Should I instal 6112 @ 1.9 with 2 shims driver/ 1 shim passenger and 5160 with CB +2 now with 275/55/20 or wait 6 months until I go with 285/75/17?
    Davesbase likes this.
  30. Nov 5, 2019 at 5:41 AM
    #660
    Stig
    Stig New Member
    Why wait. Do it all now. YOLO, right?
    Davesbase, Rolling Biome and Rica25 like this.
