Traction control sharp corners
Discussion in 'Suspension' started by cadis10, Jun 13, 2014.
  1. Oct 18, 2019 at 7:59 AM
    merbesfield
    merbesfield New Member
    ADD is my middle name . How do I turn off the VSC? Hold down a button? For five seconds? What is the procedure? Would love to do this esp when in Mtns.
  2. Sep 6, 2021 at 8:36 AM
    surffj62
    surffj62 New Member
    2011 DBL RW
    Bump-
    Happening to me in mtns on hair pin turns- ABS fires.
    Just a quick flash yellow light while it’s firing. No other lights on. Tried turning off traction but still cycled ABS in turn. It seems that it’s working as it should (if I was in a skid- but I wasn’t skidding)
    No other lights on like check engine.
    I think it is tied directly to new larger tires. If so can you reset?
    New 34’s, 2.5/1, trd sway bar in rear.
