Having trouble deciding on Toytec Shackles.
Discussion in 'Suspension' started by evans7, Oct 16, 2019.
  1. Oct 16, 2019 at 12:36 PM
    evans7
    evans7 [OP] New Member
    Cypress, Tx
    2016 2WD Tundra TSS
    Bilstein 6112 front struts and 5100 rear shock absorbers
    Hey all, I’m trying to decide on if I want to add a set of Toytec Shackles at 1” along with 5100’s. I plan on setting my 6112’s at the top setting (2.5) and want it to sit level or a slight rake. I’m having the hardest time deciding and need so suggestions from the Tundra world!
    Thanks everyone!
  2. Oct 16, 2019 at 12:37 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    If you are putting the front up 2.5 you will need a 1/2 inch in the back to make it look level
    BarcelonaSX likes this.
  3. Oct 16, 2019 at 12:42 PM
    Porkchop Express
    Porkchop Express Its all in the reflexes
    Cody
    2017 Tundra CM
    Lift , tires , stereo , TRD headlights , Rolling tonneau
    Middle hole
  4. Oct 16, 2019 at 1:10 PM
    evans7
    Cypress, Tx
    2016 2WD Tundra TSS
    My shackles are in 1-1.5in Toytec and have 2 holes
  5. Oct 17, 2019 at 3:29 PM
    Dirtfiend
    Dirtfiend New Member
    So.OC
    2019 SSM 5.7 Crew Max 4x4
    Bilstein 6112 front (2.5")/5160 rear Total Chaos UCAs Toytec Shackles 1" Method Roost 18x9 Falken Wildpeaks 295/70 R18 Carven Cat Back Exhaust Baja Designs Squadron Fogs (Amber) Stubby Antennae Blackout Badges/ Tailgate Insert Front Tint (20%) K&N Air Filter Gate King adjustable lift gate Color matched grille/bulge
    I have the 6112's @ 2.5" w/ Toytec shackles 1" setting. Slight rake but I dig the stance.
  6. Nov 4, 2019 at 10:01 PM
    COTundra23
    COTundra23 New Member
    Pics?
  7. Nov 4, 2019 at 10:28 PM
    Dirtfiend
    So.OC
  8. Nov 4, 2019 at 11:33 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I have the same setup, but for whatever reason I have a little more rake.
    BAAB1B4D-343A-41B7-90CF-D7BBCE1A53C3_zps_7ffac3a64544a766ae08a7c16663e8af27af5538.jpg
