2007 tundra ac drain location?
Discussion in '2nd Gen Tundras (2007-2013)' started by Kirkewanless, Oct 15, 2019.
  1. Oct 15, 2019 at 12:31 PM
    Kirkewanless
    Kirkewanless [OP] New Member
    i need to unclog my ac and can’t locate the drain. A picture would be helpful. Searched everywhere on passenger side as far up under the transmission as I could see. Spent about four hours looking so far!
  2. Oct 16, 2019 at 7:09 PM
    Black4X2
    Black4X2 New Member
    2007 Black Tundra Limited 4X2
    Don't know exactly where it's at but mine drips water out just about the center of the truck. It seems to be farther back than most vehicles.
  3. Oct 16, 2019 at 8:09 PM
    Kirkewanless
    Thanks. That helps. I’ll keep looking up and behind the transmission. I have a feeling it will be very difficult to access.
  4. Oct 16, 2019 at 8:11 PM
    Azblue
    Azblue Beer is Good Ban Moderator
    The Dirty T
    Above the transmission, towards the front.
  5. Oct 25, 2019 at 11:55 AM
    Kirkewanless
    The only thing I can find in that area is a plastic fitting that makes an inverted cup about 2 inches in circumference. Sort of an oblong rectangular shape. Is that it. I put my fingers in it and couldn’t feel any openings inside. I can’t see inside it. I thought I’d be looking for a tube?!? Maybe I’ll try jamming a coat hanger in there to see what happens! Anyone have any thoughts?
  6. Oct 25, 2019 at 12:07 PM
    Jrharvey02
    Jrharvey02 New Member
    That rectangular piece you feel is it, I’m pretty sure. There’s no drain tube, dunno how it exits condenser...
  7. Oct 25, 2019 at 12:08 PM
    Jrharvey02
  8. Oct 25, 2019 at 12:10 PM
    15whtrd
    15whtrd Mr. Blonde
    Mine drips on the passenger side LCA. Somewhere around there.
  9. Oct 25, 2019 at 12:15 PM
    P-Factor
    P-Factor New Member
    2018 Tundra Limited Double Cab
    TRD Sway Bar, TRD Exhaust, TRD Cold Air Intake
  10. Oct 25, 2019 at 1:29 PM
    Kirkewanless
    The thread jharvey cited is on point for the 2007 tundra. It’s not a tube but this odd inverted cup with a little slit for a drain which I can’t visualize. I’m going to try a thin metal wire or zip tie. I bought some ac mold foaming product but I’m not sure I can make that work. We’ll see.
