Oil pressure issue
Discussion in '1st Gen Tundras (2000-2006)' started by Coker032, Oct 8, 2019.
  1. Oct 8, 2019 at 7:19 AM
    Coker032
    Coker032 [OP] New Member
    Bradley
    San angelo
    02 Toyota tundra sr5
    None
    I have e a 02 Toyota tundra sr5 with 4.7 the oil pressure gauge reads really low when sitting in idle and when I put it in drive it drops even lower iv tried changing the oil sending unit and it hasn't helped a whole lot when I crank it in the morning it climbs up to about half way a d when the motor heats up it drops I'm wondering is this normal the pic that's higher is in park and the other is in drive it has 243,421 miles15705439848504978332438703100967.jpg [=full]340144[/ATTACH]
  2. Oct 8, 2019 at 7:43 AM
    Mustanley
    Mustanley Two time totaler
    Hendersonville, NC
    2004 Limited TRD 4x4 DC
    Eibach Shocks/Coils|Doug Thorley Headers|Spintech 3000XL Muffler
    Pretty sure that's normal. Mine is the same. It should climb to the middle of the range when accelerating.
  3. Oct 8, 2019 at 8:12 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Automotive oil pumps are gear-type, positive displacement pumps, and are highly dependent on the input shaft speed, i.e. engine rpm. When you put it in drive without moving, the rpm drops on an already slow rotational speed, and the oil pressure is less than before. When the oil warms up, the viscosity is less, causing less pressure to be produced by the same pump running the same speed. At idle, required oil pressure is only 4-5 psi. At higher speeds, the gauge should be near the mid-way mark. If it's less than half gauge at highway speeds, then that's not too unexpected for 243K miles. Eventually, like everything else, your 4.7L will die.
    Sunnier, Darkness and remington351 like this.
  4. Oct 8, 2019 at 8:36 AM
    Coker032
    Bradley
    San angelo
    None
    I did notice take off and driving short distances it climbs to the half way mark but going long distances on interstate or highway doing that speed or usually runs in between quarter and half way mark. I'm no mechanic when it comes to motors all the suspension and stuff I redone myself I'm just not a motor person and don't know much about motors or transmissions
  5. Oct 8, 2019 at 8:42 AM
    JohnLakeman
    Why we're here...to help Tundra guys learn about things they don't know about. I learn something here every day.
    Reason your oil pressure is lower once you're up to cruising speeds for long distance: Engine is finally heat-soaked, and oil temp is as high as it's going to get (lowest viscosity). Your transmission has also now shifted into the highest overdrive gear available, dropping the engine speed as low as it can go at that vehicle speed.
  6. Oct 8, 2019 at 8:48 AM
    Coker032
    Bradley
    San angelo
    None
    Thanks that helps out a lot
  7. Oct 8, 2019 at 9:41 AM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    What type of oil are you running? When I first got my tundra, it was low like yours. The previous owner said it had a recent oil change but I don't trust people so I did it again anyways. After changing it to 5w30 synthetic, it came up quite a bit. It still shows 'low' at idle but it is definitely more than when I first bought it. It's all normal though.
  8. Oct 8, 2019 at 10:21 AM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    San Angelo huh?
  9. Oct 8, 2019 at 10:41 AM
    Coker032
    Bradley
    San angelo
    None
    I use 5 w- 30 synthetic
  10. Oct 8, 2019 at 10:42 AM
    Coker032
    Bradley
    San angelo
    None
    Yea I'm inSan angelo at the moment I'm from south Mississippi though
  11. Oct 8, 2019 at 10:47 AM
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    Thought I'd seen that truck around. Also helps since that location is extremely identifiable hah.
  12. Oct 8, 2019 at 10:49 AM
    Coker032
    Bradley
    San angelo
    None
    Yea... that was at my uncle's shop on knickerbocker in front of the auction
  13. Oct 8, 2019 at 4:36 PM
    It's pretty normal.
    Mr Badwrench, Darkness and Filthyphil like this.
  14. Oct 8, 2019 at 4:57 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    314K.....they don't make like they used to but you gotta get that bulb replaced on the ole girl :)
    bmf4069 likes this.
  15. Oct 8, 2019 at 4:59 PM
    I need to replace this one too. :D
  16. Oct 8, 2019 at 6:22 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    If your big end and main bearings aren't knocking then you have enough oil flow.
    If that gauge is bugging really bad you can try Mobil 0W-40. That will improve your hot idle pressure and still flow enough oil through your bearings.
  17. Oct 10, 2019 at 8:09 PM
    Coker032
    Bradley
    San angelo
    None
    I have another problem I tested 1 out of the 8 cylinders with a compression tester and I was only getting about 50 to 75 pounds what do u recomend I do
  18. Oct 11, 2019 at 4:02 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    So I'm not misunderstanding....you picked 1 out of 8 to test and that one was low or you checked all 8 and 1 was low ?
    Normally to check further, one check is to pour small amount of engine oil into the cylinder through the spark plug hole and re-check.
    From my 2004 Service Manual....
  19. Oct 11, 2019 at 5:04 AM
    JohnLakeman
    @BubbaW has provided the next step in the process, which is to determine if the problem is with the compression rings.
    If the compression test pressure comes up with oil in the cylinders, it says your compression rings are not sealing. If oil in the cylinder makes no difference in the test pressure, then you have bad valves. Either way, you are looking at engine work to eliminate that hard miss you've been experiencing.
    I would probably try running SeaFoam? through it. I've never used it, but in this case, I would give it a try. I am not optimistic that will do anything to help your low compression, but you have nothing to lose.
    Aerindel and BubbaW like this.
  20. Oct 11, 2019 at 5:11 AM
    georgie
    georgie New Member
    I don't know much, but I think its time for an engine fresh up. The guage is telling you and the cylinder issue. Its a great engine but it does wear with that milage yses some get alut more miles on them but there is so many reason why some of us don't .
  21. Oct 12, 2019 at 7:22 AM
    Coker032
    Bradley
    San angelo
    None
    Yes I only tested 1 out of 8 when I went to test another one the screw on fitting at the end of the tester stayed in my block so I faught with that to get it out and didn't try the rest but the 1 that I did do was low
  22. Oct 12, 2019 at 7:23 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Did you pin the throttle open during the test?
  23. Oct 14, 2019 at 9:06 PM
    Coker032
    Bradley
    San angelo
    None
    I only took one plug out and my uncle cranked the truck up and I checked the compression as he cranked it and while it was idling I'm not even sure if we did it right but it only averaged between 50 to 75 pounds every time
  24. Oct 14, 2019 at 10:49 PM
    Aerindel
    Aerindel New Member
    Montana
    How does the truck run? We have a saying in EMS...."Treat the patient, not the number" Is that number the only problem or is the truck actually running badly in some way?
  25. Oct 15, 2019 at 5:17 AM
    JohnLakeman
    A. Hardest path, but dependable information for an informed decision:
    (1) Buy a good compression tester or fix the one you have.
    (2) Check that battery is fully charged.
    (3) Pull all the plug wires, label any that could get mixed up. You don't want it starting.
    (4) Open throttle completely and fix it open.
    (5) Do a compression test of #1 and record the pressure reading.
    (6) Continue testing and recording each cylinder through #8.
    (7) Compare readings to data in post #18 above, and to each other.
    (8) Make decision
    B. Easy path, assume previous test was accurate and all cylinders are similar:
    (1) Engine worn out. If you can get it to run, sell the truck...OR,
    (2) It's a 17 year old truck. If you can't afford to trade up right now, buy a used engine for it, BUT VERIFY THE ENGINE MILES. The trucks age is against you...plenty of worn out Toyota engines out there.
  26. Oct 15, 2019 at 7:43 AM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    It was running during test?????:eek:
  27. Oct 15, 2019 at 4:57 PM
    Coker032
    Bradley
    San angelo
    None
    It cranks and runs... I will attempt to drive it from Midland back home to Mississippi in about a month then I'm just going to probably get it over hauled...
  28. Oct 15, 2019 at 4:59 PM
    Aerindel
    Aerindel New Member
    Montana
    Which bulb?
    bmf4069 likes this.
  29. Oct 15, 2019 at 5:24 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    In @bmf4069 first pic, I'll take a slight WAG and say the P bulb. In second pic he posted, I'll take WAG it's the L bulb !
    bmf4069 likes this.
  30. Oct 15, 2019 at 6:34 PM
    TX-TRD1stGEN
    Seth
    South East Texas
    2000 Tundra 4x4
    I don't think it is supposed to be running during compression test.
    Just supposed to turn it over.
    Pull all the plug wires first
