VF Tuner 3UR Support - Development Tools
Discussion in 'Performance and Tuning' started by OVTune, Apr 25, 2019.
Thread Status:
Not open for further replies.
  1. Oct 9, 2019 at 5:56 PM
    #1411
    DavidB
    DavidB New Member
    david
    Largo FL
    2018 Tundra CM RWD
    OVTuning
    Very tru my friend! Before lift & tires I was around 14.0mpg so the tune is helping a little.
  2. Oct 9, 2019 at 6:01 PM
    #1412
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    The extra low end torque helps a lot
    DavidB likes this.
  3. Oct 9, 2019 at 6:09 PM
    #1413
    DavidB
    DavidB New Member
    david
    Largo FL
    2018 Tundra CM RWD
    OVTuning
    Yes indeed!!!! Hell of a lot better response! Next mod, exhaust.
  4. Oct 9, 2019 at 8:14 PM
    #1414
    shellshock
    shellshock Guy who drives a lot
    Iowa
    2019 TRD PRO
    Im a solid 14-15 mpg in my truck with factory size tires. I definitely get some drag off the habitat though down the interstate. I found out in Colorado idle is not nearly as friendly as the Tacoma, its quite thirsty on the trail.
    TruckyTruck and HulkSmurf14 like this.
  5. Oct 9, 2019 at 11:45 PM
    #1415
    mikmikcm15
    mikmikcm15 New Member
    Thank you for the update! I am convinced with it, upon reading the whole thread it seems like this tune has more to offer than dap. I cant wait for them to open again and the tune to be completely developed.
  6. Oct 10, 2019 at 3:26 PM
    #1416
    OVTune
    OVTune [OP] New Member
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    Flex Fuel Patch Notes -
    Patch - EROM- v1.04
    Release : ~ expected December 2019
    it has taken us quite a while to make some further enhancements for flex fuel trucks based on ethanol content, so that we can create a tune that will adjust power based on ethanol content. Here is our current patch setup for the Flex Fuel Tundra that will make on the fly adjustments to fuel based on 3 determining factors > Engine Speed > Engine Load > Ethanol content.
    Our next piece of this patch will be on the fly ignition enhancements based on these 3 variables as well.
    Some testing and further tweaking will be done on this patch this weekend on our truck.
    Flex Fuel Enhanced fuel control.
    Direct Target AFR by calculated ethanol content.
    Load Based Fuel - adder for Supercharged Flex Fuel Trucks.
    Takes our primary target and averages based on Target > engine speed > Engine Load > Flex content.
    Primary target + Load compensator adder / average of = target AFR
    for current / pending tickets waiting on an update, we will have a lot of updates out tonight through tomorrow night. We have *almost* every ECU supported now.
    Dakar650, Wynnded, shellshock and 4 others like this.
  7. Oct 10, 2019 at 3:39 PM
    #1417
    KevinK
    Back in Arizona. Again.
    Tundras to Sedona
    Excited to see the movement on ethanol tuning. Can’t wait to see some timing adjustments in the next patch. Get that real power for us NA flex fuel trucks. ;)
    TruckyTruck and Vr0ck like this.
  8. Oct 10, 2019 at 4:27 PM
    #1418
    TruckyTruck
    Gary
    This is awesome!
  9. Oct 10, 2019 at 5:02 PM
    #1419
    4Runner
    4Runner New Member
    Columbia, SC
    2017 Black Limited FFV
    Magnuson Supercharged, FOX 2.5 DSC front and rear, TRD Exhaust, TRD Rear Sway, and many more....build thread coming
    I’m not sure what this means but I’m excited. Woot! Woot!
    AZTundra likes this.
  10. Oct 10, 2019 at 5:05 PM
    #1420
    AZTundra
    Paul
    Phoenix, AZ
    Yeah, some of this is outside my knowledge, but it sounds cool. :thumbsup::yes:
    I'm going to be creating a thread soon and tagging a bunch of you guys running the supercharger. Finally talked the wife into it. Just trying to pull together an execution plan here in the next 3-4 month and will have a lot of questions for you guys with the knowledge and experience.
  11. Oct 10, 2019 at 5:30 PM
    #1421
    4Runner
    4Runner New Member
    Columbia, SC
    Hit me up. I’m 20k in on my SC.
    AZTundra[QUOTED] likes this.
  12. Oct 10, 2019 at 5:49 PM
    #1422
    Midway
    Midway New Member
    Can't wait to get the Harrop installed!
    Same here. I just ordered the Harrop kit (Non-Flex), and can't wait to get started. I've definitely been educating myself with all of this. Pretty exciting stuff
  13. Oct 10, 2019 at 6:14 PM
    #1423
    Jbtaco2002
    Jbtaco2002 Almost a Tundra
    San Diego
    nothing cool
    Get any of the Sequoia databases yet???
  14. Oct 10, 2019 at 6:17 PM
    #1424
    Jbtaco2002
    San Diego
    nothing cool
    Sounds exciting! Hopefully see some Dyno #'s posted. I'm still waiting for my tune but I plan to do a few runs to compare stock TRD SC tune, the BD tune on 93 setting, and then OV should be providing a 91 and 93 tune as well. Be awesome to see all 4 compared
    Midway[QUOTED] likes this.
  15. Oct 10, 2019 at 6:39 PM
    #1425
    Seuqoia11
    Seuqoia11 New Member
    X2 hopefully no snags on my sequoia either! Just don’t forget us “old” pre 2019 folks!!!
  16. Oct 10, 2019 at 7:23 PM
    #1426
    art64
    art64 New Member
    With the latest update I received which is 91 Octane + GL, gear lock feature is active whenever S mode is selected be it S mode, S+Tow/Haul, S+4HI. I tested it right after flashing and it works. But after a few days of driving the truck (daily driver), the gear lock feature disappeared. It downshifts like stock tune. The torque and power is still there.
    I reflashed last weekend. And this morning, the GL feature on S mode(not tow/haul) disappeared again. I pressed TOW/HAUL +S and drove it hard. GL still working on this mode. I reflashed as soon as I got to my work's parking lot. Still works when I drove home.
    I didn't get any errors during the flashing procedure. Now, I'm thinking it maybe my laptop . Too old and too slow to load the data...maybe.
    Dell D620 with Win 10.
  17. Oct 10, 2019 at 7:30 PM
    #1427
    TruckyTruck
    Gary
    Art, were you specifically told you didn't have to press the tow button to activate gear lock in S mode? Notice the quoted response by Mat responding to you...
    You have to press the tow still if you want gearlock in S mode.
    :goingcrazy:
  18. Oct 10, 2019 at 7:40 PM
    #1428
    4Runner
    4Runner New Member
    Columbia, SC
    My gear lock doesn’t work either.
  19. Oct 10, 2019 at 7:41 PM
    #1429
    TruckyTruck
    Gary
    Did you press the tow button.....!!! :rofl:
  20. Oct 10, 2019 at 7:41 PM
    #1430
    roy2015
    roy2015 Waterproof
    Houston
    Super White = Super Fast
    Really hope *almost* includes 0CL11!
    Love reading everyone’s reviews. Keep them coming.
  21. Oct 10, 2019 at 7:59 PM
    #1431
    art64
    art64 New Member
    The latest tune I received from you is 91 Octane+GL-6600 Sep 29. Worked perfectly. Then 4 Oct, gl on D on S mode got disabled. I reflashed that same day and it worked perfect again.
    This morning, lost gl on D on S mode again, but S+TOW/HAUL worked perfect. I reflashed at work. So far it is working good again. I will change laptop to a newer model see if that helps. I didn't get any error messages during my reflashes.
  22. Oct 11, 2019 at 4:48 AM
    #1432
    4Runner
    4Runner New Member
    Columbia, SC
    I’m not going to really use the gear lock anyway.....thinking we get our updated tune files today so whenever I flash I will test it.
  23. Oct 11, 2019 at 10:18 AM
    #1433
    suby2low
    suby2low New Member
    2016 TRD Tundra DC SC'd
    3" lift w/ 33x12.50s, Grampa cap, TRD supercharged, URD pulley, 340LPH FP, OV tuned
    @OVTune I emailed you with a few questions regarding data logging last week.
  24. Oct 11, 2019 at 10:44 AM
    #1434
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    Are we confident we fully understand how gearlock works? Because it has never disabled in our R/D truck ever.
    It's important to note, even with gearlock if you floor it from very low rpm in a gear it will downshift. Safety feature, below a certain rpm the truck must downshift otherwise you'll stall
    In higher gears when you floor it the TC will unlock, looking like a downshift, but it's not.
    shellshock, TruckyTruck and Wynnded like this.
  25. Oct 11, 2019 at 10:46 AM
    #1435
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    :plane:+ stalling = :bananadead:
    I would assume that an aggressive amount of throttle at too low of an rpm would produce an almost unmanageable amount of knock.
    HulkSmurf14 and TruckyTruck like this.
  26. Oct 11, 2019 at 10:48 AM
    #1436
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    What rpm is that?
  27. Oct 11, 2019 at 10:52 AM
    #1437
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Gonna guess (I'm actually guessing) 1500 rpms would be safe. That's about where I'd be cautious with the skinny.
    Wait, edit: I thought about this a little more and determined that it's going to have to depend upon a number of variables. Gear, road speed, amount of throttle input, T-case selection (for the crawlers), timing, input from knock sensors, breakfast, octane, N/A, S/C, ambient temperature, intake temperature, ambient air pressure; heck, who knows what else! So it probably wouldn't be a fixed value.
    TruckyTruck likes this.
  28. Oct 11, 2019 at 1:56 PM
    #1438
    Seuqoia11
    No base tune yet :fingerscrossed: but Friday isn’t over yet? Matt any updates?
    roy2015 likes this.
  29. Oct 11, 2019 at 1:57 PM
    #1439
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    I usually work pretty late into the night so I still have quite a few emails to get to
  30. Oct 11, 2019 at 2:43 PM
    #1440
    4Runner
    4Runner New Member
    Columbia, SC
    No, I’m not sure I do. I assumed it would not change gears unless I shifted....just like a manual. I’m cool with whatever you guys set on this. I guess mine is working as designed based on this post.
Thread Status:
