Fog light options?
Discussion in 'Lighting' started by TTU19, Oct 8, 2019.
  1. Oct 8, 2019 at 6:44 AM
    TTU19
    TTU19 [OP] Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    I'm looking for some new fog light options for '16. I currently have the Morimoto XB LED fog lights, and they've been great so far, but I've noticed one of them starting to flicker. Could be that the wire harness is loose, or the housing is loose because it seems to bounce on rougher roads.
    But figured while I was doing all that, I might see what else is out there. So what are you using? Anything with easy plug and play? Links and photos are always appreciated. Thanks..!
  2. Oct 8, 2019 at 7:04 AM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    08 tundra cm 4x4 trd sc, +2 pulley, 4.88s, 37's, other things
    i switched from morimoto to baja designs. the difference is unreal. @Baja Designs and be happy. i did mine in amber squadron sport.
  3. Oct 8, 2019 at 7:23 AM
    Jrharvey02
    Jrharvey02 New Member
    Me and plenty of others here sure do like our Baja Design Squadron Sport fog lights (wide cornering; amber) in conjunction with Eddies Fog light mod which allows you to run your fogs independent of your headlights...
    rmvcard0303 and TTU19[OP] like this.
  4. Oct 8, 2019 at 7:50 AM
    TTU19
    Wes
    Tx
    2021 TRD Sport
  5. Oct 8, 2019 at 7:51 AM
  6. Oct 8, 2019 at 8:12 AM
    Jrharvey02
    TTU19[QUOTED][OP] likes this.
  7. Oct 8, 2019 at 9:02 AM
    Tun-D
    Tun-D New Member
    Don
    Sacramento CA
    2019 TRD Sport MGM
    I was looking at these ones too in Amber. I have a 2019 Sport with stock LED fogs - can anyone tell me if this will be a significant improvement over the stock LED's when driving in snow and fog?
  8. Oct 8, 2019 at 9:03 AM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Million times better then stock
  9. Oct 8, 2019 at 9:04 AM
    fisherman951
    Tony
    2017 crewmax 4x4
  10. Oct 8, 2019 at 9:23 AM
    Tun-D
    Tun-D New Member
    Don
    Sacramento CA
    2019 TRD Sport MGM
    Are non-SAE's only legal off-road?
  11. Oct 8, 2019 at 9:38 AM
    GravityGear
    Aurora, CO
    It's really DOT that determines on road legality. Department of Transportation will approve the use of lights on public highways. DO NOT use non SAE/DOT lights on the road. You don't have inspections in CA, but in an inspection state, without covers, non SAE/DOT lights are an instant fail.
    Non SAE/DOT lights will probably have a beam pattern that prioritizes your visibility over any others on the road. This is great for off road use, not so much when there's other drivers around.
    http://www.carlightings.com/what-is-sae-dot/
  12. Oct 8, 2019 at 9:43 AM
    fisherman951
    Tony
    2017 crewmax 4x4
    That’s what it says but I live in Cali and have been running them for almost 2 years and probably have been flashed a hand full of times. Things are super bright. I do plan on swapping those out for the SAE approved ones soon(Black Friday)
  13. Oct 8, 2019 at 9:48 AM
    Tun-D
    Tun-D New Member
    Don
    Sacramento CA
    2019 TRD Sport MGM
    Thanks for the info. I guess since I would mostly use mine on-road I should look into the SAE's.
  14. Oct 8, 2019 at 9:55 AM
    Rubberdown
    Rubberdown Spilling my guts here.
    Baja designs missed the mark on their sae fog lights. Rigid is the way to go on sae fog lights in my humble opinion. Which is worth about zero.
  15. Oct 8, 2019 at 11:33 AM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    at least a million. maybe two million. literally night and day (little light joke there..)
    HappyGilmore likes this.
  16. Oct 8, 2019 at 11:47 AM
    TTU19
    Wes
    Tx
    2021 TRD Sport
    Being in Texas, I dont think they care much about all this, ha. But I guess I need to look into that. Road only.
  17. Oct 8, 2019 at 12:10 PM
    MAGDADDY
    MAGDADDY TTC #280
    JON
    Houston TX
    18 Platinum CM MGM
    Leer 100XL, Bedrug, Go Rhino running boards, LED int/ext lighting, Bilstein 6112/5100 1/2”shims up front, Coachbuilder +3 shackles, CB drop, TRD front/rear sway bar, 275/65/20 Michelin LTX M/S 2, sequoia painted mirror cap/door handles, Rago Fab low pro ditch brackets, Baja Designs S2 sports ditch lights. Baja Designs S2 sport rear flush mount pod
  18. Oct 8, 2019 at 4:41 PM
    kevine0001
    kevine0001 New Member
    Kevin
    a friend of mine runs the baja designs on his 4R in amber. holy shit they are light daylight when he runs them at night on a trail. i'll be getting them once i have $$ for the entire kit with bezel and light. i think it's like $375
  19. Oct 8, 2019 at 4:47 PM
    YotaMan
    YotaMan Silver Bullet
    Colorado Springs
    2021 Platinum
    Rigid D-Series is where you want to spend your money
  20. Oct 8, 2019 at 4:54 PM
    The Squadrons are on my list. @Bailey is our BD rep.
  21. Oct 8, 2019 at 5:54 PM
    NoMoTaco
    NoMoTaco New Member
    Bluffton SC
    2018 Tundra DC TRD OR Silver
