70+ MPH Vibration! Dealer wont fix! Ideas??
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Cohiba262, Dec 11, 2016.
  1. Dec 11, 2016 at 8:48 AM
    Cohiba262
    Cohiba262 [OP] New Member
    Daniel
    2019 Toyota Tundra TRD Pro
    My 2016 Tundra TRD PRO had the same thing but was a 3 out of 10 (10 being just awful) vibration/shake and now my 2017 TRD PRO has a 10/10 vibration that is so bad I cant drive above 70. Took it to dealer and they couldn't figure out why it's doing that and even stated that it's "possibly normal". I have a test drive with a mechanic on tuesday to review how this could be somewhat normal but betting that he will draw the same bullshit conlcusion. Great truck but this ongoing issues is really frustrating day in and day out. Any thoughts, ideas? I really don't want to buy something to make it better. Just want it to be the way it is without the wobble/shake/vibration etc. Please let me know your thoughts. Thanks
  2. Dec 11, 2016 at 8:54 AM
    jlee
    jlee New Member Vendor
    jerry
    Bay area CA
    2016 TRD Off Road on 35's supercharged and Kings and A 2002 SAS'ed supercharged Tacoma on 37's Linked front and rear
    Oh one or two.
    I'm thinking alignment or tire balance. is it the steering wheel that has the wobble?
  3. Dec 11, 2016 at 8:54 AM
    Did u get it road force balanced?
    BurgEER and Mr Badwrench like this.
  4. Dec 11, 2016 at 9:04 AM
    Cohiba262
    Daniel
    Steering wheel wobble and the rear end wobbles like crazy!!
  5. Dec 11, 2016 at 9:09 AM
    jlee
    jerry
    Bay area CA
    Oh one or two.
    Rear end wobbles how? when I think wobble I think of the steering wheel shaking back and fourth.
    Are you getting bed bounce?
  6. Dec 11, 2016 at 9:10 AM
    Cohiba262
    Daniel
    Yes sorry bed bounce. Very rapid bed bounce.
  7. Dec 11, 2016 at 9:10 AM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    If it's a brand new 2017 truck this should be under warranty at any Cerified Toyota Dealer. If the current dealership isn't taking care if you go to Toyota corporate or another Toyota service center. It's like the old saying "the squeaky wheel gets the grease".
    If your truck is shaking under braking then it's probably rotors. If it's just shaking under higher speeds then it's possibly alignment, tires out of balance or something else. Hope you get someone who takes care of you.
  8. Dec 11, 2016 at 9:26 AM
    jlee
    jerry
    Bay area CA
    Oh one or two.
    All Tundras have bed bounce on rough concrete high ways. I found changing the rear shocks, shackles leaf spring bushings as well as installing a full bed rack nearly took care of all the bed bounce. adding the TRD sway bar brought a little back.
    Honestly the bed rack helped the most helping the bed from flexing making the suspension work more. I've also noticed after ive put nearly 25,000 miles on it l. As the leaf Springs brake in the bed bounce is less and less.
    BTBAKER likes this.
  9. Dec 11, 2016 at 9:27 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    @Cohiba262 , you didn't say, is the truck completely stock? Tires, wheels, suspension? If anything is modified it could be a factor plus, unless installed by the dealer, they may not be responsible at all.
    Mr Badwrench likes this.
  10. Dec 11, 2016 at 9:38 AM
    Cohiba262
    Daniel
    Bone Stock! Doing my test drive with this dealer. If nothing comes from it I will be going to another dealer and go that route with them. Thanks guys
    NewImprovedRon likes this.
  11. Dec 11, 2016 at 9:59 AM
    My bet would be either a bad tire (broken tire cord), way off balance (doubt it if it is as bad as your claiming). You can use your spare tire and swap out every tire with the spare to find a bad tire/ bad balanced wheel.
    Other more technical areas to check is:
    Brake caliper sticking? After a drive, is one brake more hot than the others? You should be able to feel the radiating heat to get a guess on which one it is over the others or use a thermal gun.
    Bent axle: doubt this, but it can happen. When I used to take possession of vehicles from a transporter when I worked for Toyota, I seen things that made my head shake.
    Bad bearing hub. If you have the know how and tools, checking run out is rather easy. This can be overlooked very easily since it is a new truck.
    Loose lug nuts. Seen it happen before.
  12. Dec 11, 2016 at 10:46 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Absolutely not "normal" or acceptable.
    The pro ride is one of the smoothest riding trucks on the road. Bed bounce, though, can get em all, depending on the road.
    Hopefully you get fair and prompt treatment!
    JH5370 and ColoradoTJ like this.
  13. Dec 11, 2016 at 12:47 PM
    All bets are off if he lives in CA and is on Highway 99. That road going south to LA about made my teeth fall out.
    GODZILLA, nlaroy, Viper3G and 3 others like this.
  14. Dec 11, 2016 at 2:42 PM
    saadi996tt
    saadi996tt New Member
    Saadi
    Bakersfield, CA
    2014 CM LTD
    Limo Tint (all around), Weather Tech Floor Mats, Morimoto XB LED Fog Lights, Nerf Bars, Paragon Bed cover (Paint to match), Bilstein 6112’s (F) & 5100’s (R), Wireless iPhone charger, TRD rear sway bar, swing case, led bed lights, pop-n-lock...
    I drive that route a few times a week and I'm going to get my dentures very soon... billing it to Cal-Trans.
  15. Dec 11, 2016 at 2:58 PM
    I hope you have long arm, full bypass shocks on your Tundra...
  16. Dec 11, 2016 at 6:02 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    They always start with the "that's normal" line in hopes of weeding out the door-mats. Stick to your guns, this is NOT normal.
    Shukidevdas, ColoradoTJ and gosolo like this.
  17. Dec 11, 2016 at 6:14 PM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    I had a '14 Silverado, and put new XD wheels and KO2 tires. Between 72-76 mph my bed would bounce like crazy. Changed the tires a couple times, still did it. They said it could possibly be the wheels. At that point I was done and returned it all. Put factory wheels back on with new tires and no bounce.
    That being said, I'd force them to put new wheels on it or like someone else said, use the spare to rotate around. It's probably a bad wheel.
    ColoradoTJ likes this.
  18. Dec 11, 2016 at 6:17 PM
    BlueFalconActual
    BlueFalconActual Field Day Inspector Extraordinaire
    Kevin
    29 Palms, CA
    Tundra-less
    There are sections on the 60 and 605 in LA that are laughably bad as well.
    blizz86 and ColoradoTJ[QUOTED] like this.
  19. Dec 13, 2016 at 3:14 AM
    kevgrant
    kevgrant New Member
    kevin
    2017 tundra pro
    20 inch rims
    my 2017 pro doing close to same thing,and dealer same answer ,Bullshit ,Still trying to figure it out,Some times drive with a small shake, then the next drive terrible ,brand new tires balanced twice,no help, How is the truck with weight in bed or trailering?Mine multiplies the vibration ,
  20. Dec 15, 2016 at 9:46 PM
    UsmcPro86
    UsmcPro86 New Member
    Very weird i have a 16 pro no issues...
    Marty McFly likes this.
  21. Dec 15, 2016 at 9:52 PM
    Marty McFly
    Morty McBoonJug
    X2 - my pro is smooth as butter, I hit 90+ easy, but MPG that's another story :(
    I think the white pros just run faster and smoother
    Law323, GNTundra, Viper3G and 2 others like this.
  22. Dec 15, 2016 at 9:55 PM
    UsmcPro86
    Yea for sure iv had no issues...well iv warped my rotors and toyota replaced all 4 with new pads there good about taking care of customers
  23. Dec 16, 2016 at 4:06 AM
    Any updates on this issue? Hope it was resolved and you're tearing up the desert.
  24. Dec 16, 2016 at 4:12 AM
    Drew05
    Drew05 New Member
    The thing i hate the most is steering vibrations.
  25. Dec 16, 2016 at 6:39 AM
    Rangers
    Rangers New Member
    Joe
    Oklahoma
    2017 Bad Barcelona TRD Pro
    TRD sway bar
    Obviously you haven't driven the new Barcelona Red TRD Pro. They are the fastest/smoothest variant of all the pros.
    OP stay on them and they will fix it.
  26. Jan 7, 2017 at 3:21 PM
    TRD Pro Rookie
    TRD Pro Rookie New Member
    Rick
    D/FW
    2016 TRD Pro
    Nothing major
    My Pro is as smooth as glass right through 108mph when the computer shuts it down. Vibration is not normal.
    Jsena, NewImprovedRon and gosolo like this.
  27. Jan 8, 2017 at 1:39 PM
    209TRDPRO
    209TRDPRO New Member
    2016 Tundra TRD PRO
    Just lights for now
    You guys don't know what you are missing with Pro in MGM feels like you're in warp speed at any speed!!!
    gosolo, Rangers[QUOTED] and 831Tun like this.
  28. Jan 8, 2017 at 1:54 PM
    Rangers
    Rangers New Member
    Joe
    Oklahoma
    TRD sway bar
    Haha, the only warp anything I seen on the Tundras I have owned are the warped rotors. :bananadead:
  29. Feb 21, 2017 at 5:08 PM
    Rbtrd
    Rbtrd New Member
    So Cal/Oregon
    2017 Tundra trd pro CM wht
    Any update to this story........Buellerrrrr
  30. Feb 21, 2017 at 6:02 PM
    Viper3G
    Viper3G Why isn't work more like this?
    Rick
    2016 Crew Max 1794 4WD Super White
    Phillips X-treme Ultinon LED H4 bulbs, 3M Color Stable 35 tint on front doors, 3M Crystalline 40 on sunroof, OEM bed liner, OEM running boards, Morimoto fog LEDs, Fold-A-Cover G4 Elite, Husky X-Act Contour floor mats
    That's good to know. I was planning on driving back down on 99 when I go up north in a few months. Now I think it will have to be Interstate 5.
