Concerning finding on my first service visit.....
Discussion in '2.5 Gen Tundras (2014-2021)' started by shawn474, Sep 24, 2019.
  1. Sep 24, 2019 at 2:27 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    OK, with that bit of information, 0.001" out of tolerance could make sense.
    Tundra Service Repair Manual indicates maximum axle shaft runout as 1.5mm or 0.0591" (nearly 1/16") for the shaft itself. BUT, the maximum allowable on the axle flange is only 0.05mm (0.00197"). "(I)t is out by 1/1000th" means the axle FLANGE has nearly 0.003" TOTAL runout and exceeds Toyota's allowable. The axle shaft should be replaced. Good on Mr. Master Tech.
    I would let them do the repair without hesitation. That confirms you've got a good dealer. :thumbsup:
    ColoradoTJ, JMB and jewsNbrews like this.
  2. Sep 24, 2019 at 2:44 PM
    shawn474
    shawn474 [OP] Lego connoisseur
    MoCo, Maryland
    Perfect; just spoke to the master tech on the way home. He was nice enough to call me to give me an update. A lot of it sounds like Chinese to me but this is the gist.....he said the rear axle shaft is bent. He used a micrometer (I think that’s the tool) and confirmed. Said he has seen this on two Tacoma’s in his time and never on a tundra. It could be related how it was transported. - he said he has never seen one come off the factory line with this. Almost always due to hitting something or some other anomaly. He assured me this was the issue and has no reservation about saying so. Sounded convincing and he was a really nice guy. My buddy told me he is one of the most decorated master mechanics Toyota has in the country as they contact him to determine fixes for issues on a national level apparently.
    ColoradoTJ, DZ_ and JohnLakeman like this.
  3. Sep 24, 2019 at 3:11 PM
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    Probably a dial indicator, like this.
  4. Sep 24, 2019 at 3:23 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I wouldn’t be worried about them fixing it at all
  5. Sep 24, 2019 at 3:31 PM
    JohnLakeman
    This is an actual axle flange runout measurement using a dial indicator on Mustang axle flanges. The first reading shows more than 0.010-0.012", and the second reading (other side?) shows MORE THAN 0.022". :eek: Toyota's standards (<0.002") are a little tighter.
    https://www.youtube.com/watch?v=lTAPRWAE-IU
  6. Sep 24, 2019 at 3:34 PM
    Fire123
    Fire123 New Member
    2015 White 1794 Edition
    7" BDS w/ Fox, Fuel Wheels
    First, the unusual 1/1000th off is a concerning statement from your dealer service. How are they measuring that minute measurement? Also if the axle is truly bent those forces would have caused damage to other components. I would differently get a second opinion.
  7. Sep 24, 2019 at 3:40 PM
    JMB
    Chesapeake, VA
    True, out of spec=needs fixed.
    Yep, that's how it's done.
    See above.
    Each tic mark on the dial is .001".
  8. Sep 24, 2019 at 3:50 PM
    glowblue
    glowblue From time to time
    VA
    Ironically last night took my Tundra in for the 5,000 mile service and they “mistakenly” did a 10,000 mile service and changed the oil. The ironic part was I’d just changed it the day before!
  9. Sep 24, 2019 at 3:54 PM
    Rider0120
    Rider0120 New Member
    Bucks County, Pa
    2018 White double cab SR 4x4 long bed
    Ranch Hand full replacement bumper
    My friend at work had his replaced, happened after more miles on the clock then yours but if was fixed and kept on rolling. Btw they had to replace the bearings and axels because he was over loading his tundra saying it's a "heavy half ton" and treated it like a 3/4.
    ColoradoTJ likes this.
  10. Sep 24, 2019 at 4:02 PM
    plinyyounger
    plinyyounger New Member
    Ken
    Idaho
    2025 Tundra limited
    3-2 lift, KO3’s, Fuel wheels, tint.
    Just let them fix it and go from there. They are the professionals, just keep all the documentation for later if need be.
  11. Sep 24, 2019 at 4:33 PM
    shawn474
    MoCo, Maryland
    Yep, I think this will be my approach. At the end of the day, I know whatever happens my buddy will take care of me. That’s better peace of mind than anything else.
    plinyyounger[QUOTED] and JMB like this.
  12. Sep 24, 2019 at 5:15 PM
    panicman
    Eric
    2018 SR5 CM TRDoffroad MGM
    :facepalm:
    What a waste! From now on I will wait until AFTER my 5k services to change the oil!
  13. Sep 24, 2019 at 5:28 PM
    KingsAustin
    KingsAustin Grey Goose II
    Morgan County, AL
    2021 Limited Night Shade
    BakFlip MX4, Gator All Weather mats, Console Safe, Ceramic Tint, Roadmaster Active Suspension, Interior/exterior LED conversion, Wireless console charger, AJT designs.
    Sorry to hear your troubles, but you are eligible to join the club.
  14. Sep 25, 2019 at 6:33 AM
    PeakIT
    PeakIT Old Member
    Utah
    2019 OR Tundra Double cab
    Coachbuilder 3” shackles, King extended travel, SPC upper arms, 5:29 gears, FN FX rims,35"tires, leer shell, grill
    Regear it at the same time. If they are already pulling it apart and swapping bearings etc..
  15. Sep 25, 2019 at 8:05 AM
    PJR202
    PJR202 New Member
    How are so many people perplexed that someone is able to measure in thousandths of an inch?
    Cpl_Punishment, Pinay and JMB like this.
  16. Sep 25, 2019 at 8:30 AM
    Randy Morton
    Randy
    Deepinahearta, Texas
    Tolerance on most automotive parts is between .005 and .008, the confusion is how .001 is critical. Measuring in thousandths is easy to understand, and many even understand the term "Tenth mic".
    joonbug likes this.
  17. Sep 25, 2019 at 8:37 AM
    PJR202
    PJR202 New Member
    That's not the way I've interpreted some of these comments. Some/most of them obviously are discussing the measurement and how it applies to tolerance, but a few of these sound like they've never heard of a micrometer (not that there's anything wrong with that).
  18. Sep 25, 2019 at 8:39 AM
    BigdaddyII
    BigdaddyII New Member
    South Louisiana
    2019 Ram 1500
    My only thought is that if you had hit a pothole hard enough to bend the axle it would be a memorable experience. That would have to be like a 3 bedroom, 2 bath furnished pothole. I sure remember how my axle was dislocated and bent and Im sure I will for a while.
    JMB likes this.
  19. Sep 25, 2019 at 9:43 AM
    JohnLakeman
    There was only confusion about how 0.001" could be relevant when tolerance allowance is typically more than several thousandths on automotive parts. "(I)t was out 1/1000th" was the tech's way of saying the axle flange runout EXCEEDED Toyota's maximum allowance by 0.001".
    pickeledpigsfeet likes this.
  20. Sep 25, 2019 at 9:55 AM
    #50
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    King 2.5 coilovers Nitto Exo Grapplers
    Not on gears:
  21. Sep 25, 2019 at 10:21 AM
    #51
    JohnLakeman
    No, but the range or allowed tolerance (backlash) on 3UR differential gears is 0.004"-0.008"..."1/1000th" in that context then makes no sense UNLESS you're measuring 0.009".
    The tolerances on the axle bearings will be expressed in tenths of thousandths, and likely not measurable in the field by any means without destroying the bearing.
    Edit @computeruser6 : Final finish on precision gears is ground, therefore the tolerances on the gear surfaces themselves is likely in tenths of thousandths.
  22. Sep 25, 2019 at 11:29 AM
    #52
    Stig
    Stig New Member
    Just perused through here. Seems a bit blown out of proportion. Brand new vehicles often have issues in the first few thousand miles, some small and some major. That's why there's a warranty.
    My previous Tundra had an error code for the filler cap leaking at leas than 10k miles. It needed the entire has tank to be replaced because they couldn't separate just the filler neck.
    No big deal. I got to drive around in a Corolla loaner for a few days. It was fun ripping around in that thing. Fastest car I've driven, besides all the other rentals I've had.
  23. Sep 25, 2019 at 11:44 AM
    #53
    shawn474
    MoCo, Maryland
    I am very satisfied after talking to the mechanic and my buddy. I think it was more the initial shock of needing such a seemingly major repair on a brand new $40+K truck with absolutely no history of any type of accident, jarring or pothole. I got the truck with 8 miles on it. It will be repaired by an excellent mechanic at a dealership I trust and with people who I know.
    Cpl_Punishment likes this.
  24. Oct 4, 2019 at 4:07 AM
    #54
    shawn474
    MoCo, Maryland
    Update: dealership had Toyota FSE (field service engineer) called in for this. Took my truck, confirmed the issue and replaced the left axle shaft, bearing, etc....no more noise at all. Very happy with the way they took care of me.
  25. Oct 4, 2019 at 4:53 AM
    #55
    Jonny Bones
    Jonny Bones New Member
    Baltimore
    2019 cement limited crew max
    I am having a similar noise on my Tundra that I was going to mention at my 5,000 mile service. Now I am wandering if I should take it up now and have it inspected.
