My 2019 tundra is lemon
Discussion in '2.5 Gen Tundras (2014-2021)' started by Wasitworthit, Sep 28, 2019.
Thread Status:
Not open for further replies.
  1. Sep 29, 2019 at 1:58 PM
    #121
    SouthWestGA
    SouthWestGA New Member
    2007 Tundra CrewMAX and 2014 Nissan NV3500 Passenger
    Yea,if he likes wearing out his tires prematurely and having steering wander
    Do it right or not at all!
    Rica25 likes this.
  2. Sep 29, 2019 at 1:59 PM
    #122
    roy2015
    roy2015 Waterproof
    Houston
    Super White = Super Fast
    Truck looks great! I'd be pissed too if my new truck was having problems. Get it fixed and enjoy it for years and years!!
    Rica25 and Wasitworthit[OP] like this.
  3. Sep 29, 2019 at 3:08 PM
    #123
    Rica25
    Ricardo
    Tulare
    Yes added shims
  4. Sep 29, 2019 at 3:36 PM
    #124
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    :thumbsup:
    Rica25[QUOTED] likes this.
  5. Sep 29, 2019 at 3:50 PM
    #125
    KeetAz
    KeetAz New Member
    Gilbert AZ
    2020 SuperWhite PRO
    I’m going 6112 at the 1.9 setting and 2 driver side shims and 1 passenger shim. I didn’t have UCAs in my build plan. Should I? Wasn’t thinking i needed them. Now you have me questioning myself....:confused:
  6. Sep 29, 2019 at 3:52 PM
    #126
    Rica25
    Ricardo
    Tulare
    I'm masked out in caster so that why I'm doing but also love the way the look.....lol.....told my wife that I needed to buy them because we cant be making uturns with these being maxed out in caster and also because they are Dangerous being on the way they are and she said oh ok get ASAP
  7. Sep 29, 2019 at 3:55 PM
    #127
    KeetAz
    KeetAz New Member
    Gilbert AZ
    2020 SuperWhite PRO
    The coach builder guy (can’t remember his name) said 1.9 with the 3 shims and shackles in back will bring me up 2.5 inches total.
  8. Sep 29, 2019 at 5:19 PM
    #128
    toyoboyo
    toyoboyo New Member
    Rica25 likes this.
  9. Sep 29, 2019 at 5:54 PM
    #129
    tstieb
    tstieb New Member
    2014 CM TRD
    I need them at 1.9 setting with one shim.
    Migraine and Rica25 like this.
  10. Sep 30, 2019 at 3:19 AM
    #130
    Double Badass
    Double Badass For Thoughs about to Rock we SALUTE you
    James
    Arizona
    2019 Cement Tundra Crewmax
    6 inch pro comp coilover lift, 20 fuel wheels 35 nitto mud grapplers, colorbomb blackout, rigid industries lights, amp steps
    Thanks brother! I really hope you get your issues fixed. I will definitely steer clear of Right Toyota. I will also tell all my friends not to go there as well, as far as I'm concerned the only way to get through to these dealerships is to stop going to the ones that don't stand behind there products. You deserve better.
  11. Sep 30, 2019 at 9:03 AM
    #131
    Vector W8
    Vector W8 Old guy with a lot of expensive habits.
    2015 Platinum Super White Crewmax 4X4
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    All alignments should pull slightly to the right when you let go of the steering wheel. This is designed to prevent you from falling asleep at the wheel and driving across the median in to oncoming traffic. Better to kill yourself then take others with you. You should end up in the ditch on your right. There is typically a quarter of a degree in tow to make sure this happens.
  12. Sep 30, 2019 at 9:18 AM
    #132
    rustynail11
    rustynail11 New Member
    Scott
    Mansfield,TX (DFW Area)
    2017 Grey Tundra TRD
    Tundra isn't a lemon, the lift is. No way to really know though unless it is returned to stock. The real problem here is that the dealer charged $7K for a 3in lift
    GODZILLA and Black Wolf like this.
  13. Sep 30, 2019 at 6:11 PM
    #133
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Toe cannot cause a vehicle to pull. I've probably done a thousand alignments, I lost count after 20 years and I've never set a vehicle to pull right. When I'm done the vehicle will run straight with a dead center steering wheel and no tire wear.
  14. Sep 30, 2019 at 6:22 PM
    #134
    mastergunnera8
    mastergunnera8 New Member
    Northern Virginia
    IMHO contact the dealer, tell them its unsafe to operate. Doesn't matter if they say its the alignment, if they cant fix it, its an unsafe vehicle you bought new that "cant be fixed". If they wont put it back to new (stock) call corporate ASAP and report them for selling an unsafe vehicle and that you want your cash back (at least the 7K) and/or another truck. Dont piss around with it...time makes it harder...wish you luck , but Id be PERISISTANT...Oh, can you post up the laminated build sheet? Curious...
    plumber802, GODZILLA and Ruggybuggy like this.
  15. Sep 30, 2019 at 6:37 PM
    #135
    AZTundra
    Paul
    Phoenix, AZ
    But I'm sure they also kept the stock rims and tires to later resell for some more profit on top of that...
    sundance and Hbjeff[QUOTED] like this.
  16. Oct 1, 2019 at 8:15 AM
    #136
    1fujifilm
    1fujifilm New Member
    Bear
    19 Tundra Crew
    Happens all the time no matter the name of the manufacturer, luckily you bought a Toyota with great resale (hope you got 11% off plus 3k rebate).
    Sell it or trade it, simple as that.
    I had a 2019 SR-5 4x4 crew 6 months back and it had problems;
    -Headliner around microphone was pulled apart. They said they would glue in a an new headliner..no thanks.
    -Exhaust pipe was damn near rubbing on the box. Said it was ok even though I couldn't fit the TRD accessory chrome tip on.
    -Bumper was on crooked. Said they would try to adjust, did not work.
    I paid 37.7, put on 6,200 miles and traded it back in for 37.5 on a different new 2019 and again got 11.3% off plus 3k rebate.
    Try it if you are fed up.
    You may have to go to another dealer to find a new 2019.
    Bear
  17. Oct 1, 2019 at 8:28 AM
    #137
    sundance
    sundance New Member
    Most road are sloped to run the water off. This will cause a slight pull to the right. However, I can honestly say that my Tundras have always been very easy to hold straight with the slightest of pressure. I usually drive with two fingers.
    HazMatt likes this.
  18. Oct 1, 2019 at 10:09 AM
    #138
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    Bilstein 5100/5160 Toyo at2 295/70r18 Ray10 GunMetal
    Holy crap.
    Jack McCarthy likes this.
  19. Oct 1, 2019 at 11:40 AM
    #139
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    2 things - good news/bad news:
    1. Bad news: $7k is way too much for a spacer lift. It should be more like $500 for that setup.
    2. Good news: The "lift" itself is not that bad, and you don't need new UCAs for a 3" lift. There are way too many people on this forum who talk crap about stuff they don't know about** - just hearsay that gets repeated as facts. There are many people on this forum that that have 3" lifts without new UCAs. Many spacer lifts without problems. Yes, it is better to get UCAs and better to get a different better suspension lift, but not necessary. There are many people on this forum who have 3" spacer lifts and they don't have issues with pulling to the right either, myself included, so I speak from experience.
    There are things to talk over with the dealer - the cost of the lift (not sure how you will get out of that one) and then they have to get it aligned right, whatever the reason is, but it is fixable and should not be the reason for you not liking your new truck.
    Good luck!
    **I do respect the knowledge on this forum; a lot of knowledgeable people; just some who talk crap about things when it is not supported by facts.
  20. Oct 1, 2019 at 12:05 PM
    #140
    DvilleMafia
    DvilleMafia New Member
    DFW
    2018 Tundra SR5 4x4
    What aftermarket UCA can you run with factory wheels? Seems like every brand i check requires aftermarket wheel with 5.5” back spacing. I don’t want any rubbing nor do I want to cut/bend/remove anything inside wheel well. Running stock 20” on 275/60R20
  21. Oct 1, 2019 at 12:28 PM
    #141
    Wasitworthit
    Wasitworthit [OP] New Member
    Camy
    2019 tundra
    Calvary Blue aka Elsa
    Alright here’s a little update. The alignment according to the dealership is perfect but and off road alignment shop showed me these prints outs. I called the manager at the dealership and explained that if they don’t fix it it will go up the chain to Toyota that you are authoring a customer to drive an unsafe vehicle with a four year old in the car and pretty fast they have me going to another mechanic this Friday to fix what apparently I’ve been saying all along
    GODZILLA likes this.
  22. Oct 1, 2019 at 2:01 PM
    #142
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I'm sure that alignment isn't helping. The first set of numbers is your caster. Having the right side about .5* higher will help from pulling right. But with your stock arms, I doubt they could get it any higher. Second set is Camber. Both should be about the same, near 0. And last set is your toe. Having your right wheel pointed straight and your left wheel pointed to the right will probably make the truck go right.
    Vizsla and Pinay like this.
  23. Oct 1, 2019 at 2:28 PM
    #143
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    It doesn't show the trust angle.
    Those numbers are just the front.
  24. Oct 1, 2019 at 3:09 PM
    #144
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Caster will pull to the least negative number. The caster numbers displayed will offset road crown and technician will add more or less depending on the road crown in your area. Toe will never cause a pull.
    Tumbler likes this.
  25. Oct 1, 2019 at 3:10 PM
    #145
    SoCalTundy
    SoCalTundy Tundra Owner since 2017
    Icon Shocks. Total Chaos UCA. Deaver u748 TC shackles Flowmaster super 50. Diode Dynamics fogs. 5.29 Revolution Gears. SSW 17" wheels on BFG 35x12.5
    What size tires are you running and how many miles have you put on your truck WITH the spacer?
  26. Oct 1, 2019 at 3:14 PM
    #146
    Boerseun
    Ferdie
    Sarasota Florida
    275/65/20 (34.6" OD). About 20,000 miles on this truck.
    SoCalTundy[QUOTED] likes this.
  27. Oct 1, 2019 at 3:25 PM
    #147
    NateDiz
    NateDiz Sunday Tunday
    Nathan
    So Cal
    2013 MGM CrewMax TRD
    Trd Pro Suspension, spyder headlights with morimoto HID, Raceline Defender Wheels, AFE filter, Dirty Deeds 8” exhaust
    Damn you, @Rica25 . Im so jelly. I want to do this so bad
    Wasitworthit[OP] likes this.
  28. Oct 1, 2019 at 3:30 PM
    #148
    mastergunnera8
    Northern Virginia
    IMHO, get out of it, get a refund towards another truck..(i.e. try and get your 7 dang K back)..but hope it works out for you!!! What shocks are in there?
  29. Oct 1, 2019 at 3:32 PM
    #149
    SoCalTundy
    It looks like the OP may be running a wider tire which also may be more reason for an aftermarket UCA. When suspension companies like icon, king, etc tell you you will need after market UCAs when going above 2.5” of lift, then it’s best to do so. I had a 2.5” spacer lift on mine and my shocks started squeaking after 18k miles. UCA was stock and alignment was fine. At 3” I probably would have needed a UCA upgrade. The spacer put too much pressure on the bottom mount. This voided the warranty on the shocks. In my experience, spacers are junk. It’s a good temporary solution, but in the end they will reduce the life of your shocks and you will have to spend more on a better suspension. Just speaking from experience.
    Boerseun[QUOTED] likes this.
  30. Oct 1, 2019 at 3:46 PM
    #150
    NateDiz
    Nathan
    So Cal
    If i were you, i would call corporate immediately and tell them that you wont let it go until they remove the lift and credit your loan the 7k. prove that you were taken advantage of by that dealer and give them a quote from the off road shop stating how much a spacer lift actually costs. Use phrases like "i am dissapointed in the service im getting" or "they let me drive off with an unsafe vehicle" or "they took complete advantage of me charging me over 10x for a lift" Tell them that the dealer you went to put such a sour taste in your mouth that you wish you had never purchased the truck. Then if it worked take that money straight to an off road shop and get the 6112 setup.
    This might be a long shot, but they are much more likely to bend over on a profit that is so heavily padded. Especially since you are saying you still want the truck. They paid probably 200 dollars for the parts of that lift, and maybe an hour of labor. Unless they are also getting screwed by the local off road shop they have a partnership with. That would be too funny. anyway, i hope it all works out. You bought the right truck dude, you just got unlucky with the dealer.
Thread Status:
