The shine is wearing off! Dealer says I need new tires after 30k?!
Discussion in 'Wheels & Tires' started by alimbert, Sep 30, 2019.
  1. Sep 30, 2019 at 12:59 PM
    alimbert
    alimbert [OP] New Member
    Stock 2017 CrewMax. 27k miles. Took it in for my 25k service and the dealer thinks I should be getting new tires in 5-10k. WTF?! Bridgestone Duelers only last 30k? Set my expectations. Am I expecting too much? If I am replacing these, what am I replacing them with so I get more than 30k?
    DalTee and Rica25 like this.
  2. Sep 30, 2019 at 1:02 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Check the thread depth yourself and see if true. I've never used that tire so I couldn't tell you how long they would last under normal driving conditions.
    BTBAKER, ColoradoTJ and zcarpenter92 like this.
  3. Sep 30, 2019 at 1:04 PM
    AZTundra
    Paul
    Phoenix, AZ
    My 2017 came with the Michelin LTX tires. I'll have 50K on them within this week and they still look pretty good. Thinking they will need to be replaced ~60K.
    Tierhog, YardBird and Rex Kramer like this.
  4. Sep 30, 2019 at 1:05 PM
    Metro14536
    Metro14536 New Member
    Brandon
    Las Vegas, NV
    2025 Ice Cap SR5 TRD Rally
    That can’t be true...
    I have 17k on my duelers on my 18 Sequoia and the dealership said they look like I have driven only 1,000 miles on them
  5. Sep 30, 2019 at 1:06 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Always get a second opinion. Dealerships are always "Upselling"....
  6. Sep 30, 2019 at 1:30 PM
    Medic343
    Medic343 5+4+3=2
    Kenny
    New Mexico
    '22 SR5 TRD off-road
    I'd say they are full of it, you should get at least 40-50k out of the stock tires. Now if you were running KO2s I'd say that's about right, I'm about to replace mine and they are at about 30k miles
  7. Sep 30, 2019 at 1:33 PM
    RollTide82
    RollTide82 New Member
    Michael
    2019 Tundra 4x4
    My dealership charges 30 bucks to clean battery terminals....assholes
    Darkness, Alaska, sundance and 5 others like this.
  8. Sep 30, 2019 at 1:48 PM
    Chief P
    Chief P New Member
    TX - Texas
    '17 Blue CM Ltd TRD 4x4
    I swear it has something to do with factory tires. I worked at Discount Tire and it always seemed like factory tires were worn out at 35-40k, but we would replace them with the exact same tires and they'd go 60-100k. Its the same with the tires on my '17 Crewmax. I'm at 37k on my factory Michelin A/T2s and I'm going to have to replace them soon, but the A/T2 is a 60k mile tire at least. I've seen guys get 90k on them. It's a strange phenomenon.
  9. Sep 30, 2019 at 1:52 PM
    Trooper2
    JR
    It wouldn't surprise me if tire MFG's sell an inferior / technically low life tire to the automakers for a lower price. Knowing many owners replace with same tires and charge full retail when needed. All a Conspiracy I tell you!
    jeffh81, DalTee, Toyotoholic and 4 others like this.
  10. Sep 30, 2019 at 1:52 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    My 2013 tires were done right at 30k miles. And that was with rotating them every 5k miles. The next set I bought were Toyo AT2 Extremes. I rotated them every 5k miles. They lasted 100k miles. Hell of a difference in longevity. I'm now on my 2nd set of those Toyos. They are the best tire I've ever come across.
    Toyotoholic and don3032 like this.
  11. Sep 30, 2019 at 1:55 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Like hot dogs pack of 10, buns pack of 8. Lol
  12. Sep 30, 2019 at 2:00 PM
    Trooper2
    JR
    My wife has leased two GX470's, Michelin on one Bridgestone on the other. 20k miles on both, they were toast. Luckily wife doesn't put many miles on her vehicles, turned them both in for new towards end of lease. I do think the tires were soft and over loaded for comfort, all time 4wd didn't help either.
    In an RX350 now, interested to see how these tires hold up. More sporty tire for sure on lighter front wheel drive vehicle.
    DoubleJackOnTap likes this.
  13. Sep 30, 2019 at 2:04 PM
    15whtrd
    15whtrd Mr. Blonde
    I’ll show them, I use a slice of bread for the last two. Boom Shakalaka
  14. Sep 30, 2019 at 2:11 PM
    Rngr188
    Rngr188 Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    My factory Michelins started getting punctures and looking bad so at 23k I installed my Ridge Grapplers. Stock tires a P-metric and shouldn't be on a truck as heavy as a Tundra so look at going LT preferably the Michelin m/s2.
    CMB and AZBoatHauler like this.
  15. Sep 30, 2019 at 2:14 PM
    Mnorris1206
    08 tundra
    I'm about right at 30k on my ko2s 35" tires I'm not looking forward to another 1300.00 purchase but I do like the tire alot.
    Medic343[QUOTED] likes this.
  16. Sep 30, 2019 at 2:32 PM
    Chief P
    Chief P New Member
    TX - Texas
    That's my guess too, but I have put a worn factory tire side-by-side with a new one before and cannot for the life of me see a difference.
    Trooper2[QUOTED] likes this.
  17. Oct 1, 2019 at 6:11 PM
    TNTundra7
    TNTundra7 New Member
    TN
    2016 SR5 4WD 5.7L
    Bilstein 5100s, TRD RSB, TRD Wheels
    Bridgestone Duellers came on mine as well. Dealership marked that they were close to needing replaced at 25k as well. Our local tire shop (which is fairly reputable/honest) told me that often cheaper versions of good tires are indeed put on new vehicles. Checked them myself and they were definitely getting close to needing replaced. Bought some from said tire shop. The next time I had service on my truck at Toyota dealership, I inquired about this with one of the service managers who is also reliable/honest and he basically confirmed the same thing.
    @alimbert @Trooper2
  18. Oct 1, 2019 at 7:08 PM
    dlowry81
    dlowry81 New Member
    Doug
    2004 Tundra Doublecab
    It's a known fact that OEM tires don't have same tread depth as regular tires. I've never reached 40k on stock tires yet and that's on a 4runner, Camry, 2 Tundras, and a Sienna.
    Trooper2 and AZBoatHauler like this.
  19. Oct 1, 2019 at 7:18 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I replaced my duelers at about 25k because I wanted to. They had plenty of life left on them, I would say 10-15k more miles easily. I wanted Michelin defenders so I sold my duelers on craigslist and got defenders, which should last me as long as I own the truck. Defenders have been known to go 80k+ and some say 100k. My GF went thru 2 full sets of tires in the first 60k miles on her AWD highlander, then finally talked her into defenders and she's got 40k on them and they look new still.
    CMB and Trooper2 like this.
  20. Oct 1, 2019 at 7:19 PM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    I have never got more than 30-35,000 on original stock tires. They are always wear out quick.
    619Tundra and Trooper2 like this.
  21. Oct 1, 2019 at 8:07 PM
    Rngr188
    Chad
    Harrison AR
    I'm on another forum that has a member who works at a Michelin factory, he swears there is no difference between OEM vs of the shelf, I don't believe him. My previous vehicle had Goodyear's that were OEM and shot at about 35k, my Tundra's Michelins were catching debris and I'd get them patched but after getting a flat on a gravel road at 23k I replaced them with LT instead of P-metric.
  22. Oct 1, 2019 at 8:23 PM
    Pudge
    CT
    I for one, do not believe that tire manufacturers make crappier tires for car manufacturers to use. It wouldn't make sense for them to cheap out and risk their name. It would make sense that they would want the consumer to stick with their brand tires when it comes time to replace them.
    In fact I am pretty sure some tire companies make higher performing "OEM" tires specifically for certain cars.
  23. Oct 1, 2019 at 8:48 PM
    knoxville36
    knoxville36 New Member
    Knoxville, TN
    2024 GMC Sierra 1500 Elevation w/3.0 Duramax
    We got 61k on our 17 4Runner with Yokohama Geolanders. Got 68k on our Nissan Rogue with Dunlop's. Our Acadia went 51k but cannot remember the tires, Goodyear? All bought new.
    It makes no real sense to try and change out materials, machinery settings, etc.... by tire manufacturers.
    I have no real explanation for the mileage as we have never gotten less than 50k out of any tires. My wife and I have drive a lot and out on about 80k miles per year together. We have been through a lot of tires....
    I have tried them all Goodyear, Dunlop, Bridgestone, Cooper, etc..... Michelin's absolutely set the bar on passenger truck and car tires. Hands down they have been the quietest and longest lasting tires.
    No problems with the Duellers on the Tundra through 23k Miles, but I am counting down to the second that Michelin Defender/LTX MS2's go on!!!
    Pudge likes this.
  24. Oct 1, 2019 at 8:52 PM
    Pudge
    CT
    I couldn't wait any longer. I lasted a year on the duelers and sold them on craigslist for $300 while they still had some life left on that.
  25. Oct 1, 2019 at 11:24 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    False.
    619Tundra likes this.
  26. Oct 2, 2019 at 12:22 AM
    Racingjohndeere55
    Racingjohndeere55 New Member
    Ask Firestone
    Pudge[QUOTED] and Skey44 like this.
  27. Oct 2, 2019 at 12:33 AM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Meh, I haven’t had tires on my trucks last much past 35k so I wouldn’t be surprised if they were toast. There’s a LOT of weight bearing down on those passenger tires.
  28. Oct 2, 2019 at 2:55 AM
    ed3trd
    ed3trd New Member
    2017 Silver Crewmax 4x4 Off Road
    I have the Michelin, normal road conditions in FL are anything but normal. Heat, sand all very abrasive. I have always been told that they are a soft tire.
    I drive mostly highway 70 mph ,rotate at 5000,but at 30,000 they won't last past 35,000.
    I had the Goodyear Duratracs on my last Tundra go 45,000 so going back to them.
  29. Oct 2, 2019 at 5:04 AM
    Skey44
    Skey44 GreenvilleOverland
    Scott
    Greenville SC
    2018 GX 460
    Lift, tires, wheels, roof rack
    Had to replace my wife’s Honda Pilot’s Bridgestones at 13k. We were getting punctures every couple of weeks and one finally happened in the sidewall. The oem Bridgestone are reviewed horribly with short life span in this car. Not to mention the ride that starts off soft and quiet and after 10k turns hard and loud. Went with Michelin LTX defender, happy so far. Hope they last as well as other defenders I’ve had on my Prius in the past. At least discount tire gave us $90 for the three remaining tires. Feel sorry for whoever ends up with those.
  30. Oct 2, 2019 at 5:06 AM
    Skey44
    Scott
    Greenville SC
    2018 GX 460
    I agree to double check the tread wear. If you don’t have or want to buy the tool, use a penny. There’s plenty of instructions for this online.
