Lift suggestions
Discussion in 'Suspension' started by SCRPS12, Sep 22, 2019.
  1. Sep 22, 2019 at 11:13 PM
    SCRPS12
    SCRPS12 [OP] New Member
    Todd
    2019 SR5 Off Road Tundra
    N/A (Yet)
    Hey all. Looking at lifting my 2019 SR5 crewmax. Should I go 3” or 4”, and what brand would you suggest? Also, what size wheels and tires would you suggest? Mainly road driving, but I will be taking it hunting and camping and such, not a mudder or 4wheeling guy, but a family vehicle mainly.... but still my toy! So don’t want to go nuts, but still want a badass looking rig!
    Toytec Lifts likes this.
  2. Sep 22, 2019 at 11:54 PM
    SCRPS12
    Todd
    N/A (Yet)
    Looking to spend under $3500 for lift and wheel and tires installed. Doable with a decent setup?
  3. Sep 23, 2019 at 12:01 AM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    King 2.5 coilovers Nitto Exo Grapplers
    2-3"; the less you lift the better (unless it's a specific look you're going after). You can spend less than half of your budget on shocks/coilovers if you get the Fox 2.0 series. You can also fit a 35" tire on stock wheels if you keep the width at no more than 285mm. I fit 285/75R18 tires on my truck with stock springs in the rear and coilovers in the front set at about 2" of lift. Why spend the money on new wheels when what you have now work perfectly fine? If you ever mess them up you can always find gently used ones for cheap.
    Rex Kramer, Quebec and Migraine like this.
  4. Sep 23, 2019 at 12:06 AM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
  5. Sep 23, 2019 at 9:37 AM
    smiles89
    smiles89 New Member
    Portland, OR
    2019 Tundra SR5 CM Off Road
    This is maybe the finest looking Tundra I've ever seen. God, I wish they made 3rd gens in regular cab/short bed configurations :(
    tbutler and Rex Kramer like this.
  6. Sep 23, 2019 at 2:28 PM
    W27
    W27 New Member
    I had similar requirements. I went with a basic 3/1 lift. It keeps the stock ride. You can get much better lifts as many will suggest, but you’re not going to have any money left in your budget for wheels and tires. For your needs it should be fine. I went with Fuel Mavericks wheels on 35” Nitto Ridge grapplers. This was the best option for me. I did a lot of research beforehand. It’s got a very aggressive off-road look, but rides great and tires are quiet. I don’t really do off roading but it’s been a beast in the snow. I’m in the NYC area where prices tend to be higher and I got everything installed and alignment for 3k out the door.
  7. Sep 23, 2019 at 2:35 PM
    BrownieT
    BrownieT New Member
    2018 Tundra TRD 4x4
    King —- they are unbelievable
  8. Sep 23, 2019 at 3:32 PM
    Meangreen
    Meangreen New Member
    JC
    2017 1794 Sunset Bronze
    5100's highest setings = 350
    Coach builder's shackles/ shims= 350
    Labor/ alignment = 250
    Tires BFG KO2 285/65/20= 1250
    $2200 out the door, left money for BAM exhaust group buy, remote start and still under 3k.
    I actually wanted 18" wheels but didn't want to spend the extra $. I did 3/1 lift kit on my previous trucks and drove fine. This setup is night and day and for only a couple hundred dollars difference is a no brainier. Kind of a bad picture but looks greay in person. Good luck with your future setup. Truck now sits 4" higher than stock.
    Rlh.airborne and tbutler like this.
  9. Sep 23, 2019 at 5:06 PM
  10. Sep 23, 2019 at 5:32 PM
    W27
    W27 New Member
    Whatever you decide. After the bigger tires I added the TRD rear sway bar. $200-250. Really helped the handling. Easy to install yourself.
  11. Sep 23, 2019 at 5:35 PM
    RLHULK
    RLHULK Too many gamma rays in all that BBQ smoke.
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    Old Man Emu with 612 springs if you are keeping your stock front bumper and not adding a winch, get the toytec adjustable shackles for the rear, set at 1 inch.
    Right around $1000 for that set up, pus labor or do it yourself for free, that leaves a lot left over for new tires and wheels.
    OME is a great all around shock that also gives you around 2-1/2 of lift.
  12. Sep 23, 2019 at 8:22 PM
    computeruser6
    Dirk
    Escondido
    Thank you!
  13. Sep 24, 2019 at 7:49 AM
    Toytec Lifts
    Toytec Lifts New Member
    Denver, CO.
    We can get you taken care of no problem at all!! We have it all from mild to wild! Give us a ring at 303-255-4959 and we can get you squared away no problem!
    Bakelite likes this.
  14. Sep 24, 2019 at 8:40 AM
    RLHULK
    Rich
    2022 Silverado LT.
    Here’s mine after the ome was installed
    Allrsdup likes this.
  15. Sep 28, 2019 at 12:44 AM
    Allrsdup
    Allrsdup New Member
    Joe
    24 Lunar Rock Limited crewmax trd ord
    that looks great! how do u like the ride of the ome? did u go with 612 coils? how much lift up front ?
    PlatinumXing1985 likes this.
