Can I see your 275/70r18 please.
Discussion in 'Wheels & Tires' started by Rngr188, Sep 16, 2017.
  1. Sep 2, 2019 at 6:38 PM
    #181
    Edier08
    Edier08 New Member
    nice side steps. I have have the MGM color as well what kinda are those? I'm taking the tube steps off I don't not like them
  2. Sep 2, 2019 at 6:59 PM
    #182
    ProtoJ
    ProtoJ New Member
    2018 Crewmax TRD Off-Road
    RCI Off-road
  3. Sep 2, 2019 at 8:20 PM
    #183
    Rica25
    Ricardo
    Tulare
    I just did 6112 and 1/4 inch shim on top setting and 5160 on rear with coachbuilder shackles +2 really like the stance of it now
  4. Sep 24, 2019 at 9:12 AM
    #184
    Uturn09
    Uturn09 New Member
    Roscoe
    2017 Grey Tundra SR5 TRD
    None to day....that’s why I’m here.
    How hard is it to install the 6112 at home?
    Rica25[QUOTED] likes this.
  5. Sep 24, 2019 at 3:04 PM
    #185
    cmc6070
    cmc6070 New Member
    2008 Crew Max, TRD Off-Road, Radiant Red
    Just got these today...275/70/18 Ridge Grapplers on SCS Ray10'sIMG_E0487.jpg IMG_E0489.jpg
  6. Sep 24, 2019 at 4:20 PM
    #186
    AZBoatHauler
    AZBoatHauler SSEM#140/ASCM#3/2ndGenNaysayer/BAF140
    So.Arizona
    After having a lift to install mine 3 weeks ago, I can't imagine trying to do it in a driveway with jacks and jack stands. Save yourself - find a lift or have a trusted mechanic install them.
    Rica25 likes this.
  7. Sep 24, 2019 at 4:37 PM
    #187
    power80
    power80 New Member
    2018 Tundra Crewmax Limited 4x4
    I have the K02 275/70/18. Great tire with almost zero road noise. I got 18mpg last weekend.
    1.9 up front with with rear shackles
  8. Sep 24, 2019 at 8:32 PM
    #188
    NikNoid
    NikNoid New Member
    BFG K/O2 275/70R18
    2.75" front lift
    1" rear lift
    Stock TRD Off-Road wheels.
    No spacers ... yet, these tires are rubbing the skid plate at full lock.
  9. Sep 24, 2019 at 8:34 PM
    #189
    Rica25
    Ricardo
    Tulare
    It's not bad but I have done them twice before just have a shop assemble the shocks first
  10. Sep 26, 2019 at 6:51 PM
    #190
    Muleycrazy13
    Muleycrazy13 New Member
    Buckeye, AZ
    2015 MGM TRD 4x4 Crewmax
    Toyota spray in bed liner/ 30" LED Lightbar/ Pro Comp Pro Runner SS @ 2.5"/ Husky Xact fronts/ Weathertech rear/ NFAB steps/ 275/70R18 BFG KO2's/ LED interior from GTR lighting/ Tekonsha Prodigy Trailer brake Controller
    Looks great!
  11. Sep 27, 2019 at 8:12 AM
    #191
    ruiner
    ruiner New Member
    2017 Tundra CM 4x4
    Tires look low. What is your PSI set at?
    Rica25 likes this.
  12. Oct 5, 2019 at 11:39 AM
    #192
    CementTurdOffRoad
    CementTurdOffRoad New Member
    Andrew
    Maryland
    '19 Cement Limited Off Road
    9:4:19 - 1.jpg
    275/70r18 Ridge Grapplers on SCS Ray 10s.
  13. Oct 5, 2019 at 12:47 PM
    #193
    ProtoJ
    ProtoJ New Member
    That looks great!lift or no lift?
  14. Oct 5, 2019 at 3:29 PM
    #194
    MaxYota
    MaxYota GrilledCheese
    Murf
    MS Gulfcoast
    2019 TRD PRO VooDoo Blue
    Mighty Mouse suction cupped to the review 8 ball shifter. Driver side "Oh poop" handle. Smoked side window deflectors. ReadyLift TRD PRO +2 for front. 1.5" ProFormFab Shackles + 1" ToyTec block for rear. SDHQ Hidden winch mount with Badlands 9000 winch. 305/70r18 Cooper Discoverer STT PRO
    275/70r18 Dick Cepek Trail Country EXP. White letters out of course.D3DA8E9A-A360-46D3-A11F-558BD98D3D71.jpg BD0A796E-7C95-4AA5-8E6C-54C91D68C685.jpg F722F4C0-E14C-4632-853D-8A9B9F8077C0.jpg 7D299BBF-BAE6-49D3-8430-8446952C89D6.jpg
  15. Oct 5, 2019 at 3:33 PM
    #195
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Did you add wheel spacers or no? Looks great
  16. Oct 5, 2019 at 4:58 PM
    #196
    MaxYota
    Murf
    MS Gulfcoast
    Thanks.
    No not yet.
    I plan to raise the front 1”, the back a 1.5” and 1.25” wheel spacers.
    jewsNbrews[QUOTED] and Rica25 like this.
  17. Oct 5, 2019 at 5:15 PM
    #197
    CementTurdOffRoad
    Andrew
    Maryland
    Thanks, no lift. (Yet)
    Rica25 likes this.
  18. Oct 8, 2019 at 2:56 PM
    #198
    westerj12
    westerj12 2017 CM Super White TRD Pro
    2017 White CM TRD Pro
    Predator bars, Softopper, TRD Pro Shims, +2 Coachbuilder Shackles, 1.25" BORA Spacers, 275/70/18 Cooper Discoverer AT3 XLT, Window tint, Letter inserts
    Just had some Cooper Discoverer AT3 XLTs installe . I have 1.25 inch spacers and I'm getting a lot of rub. I have a 2017 TRD Pro with the stock pro suspension. Will the TRD Pro shims and +2 shackles fix that?
    Rica25 likes this.
  19. Oct 9, 2019 at 1:51 PM
    #199
    BajaTurd
    BajaTurd Burrito Champion
    Aj
    San Diego
    19 4x max
    Camburg uppers Kings Deavers
    Your probably rubbing the skid plate. If you're rubbing anything else take off the spacers.
    Rica25 likes this.
  20. Oct 9, 2019 at 1:52 PM
    #200
    westerj12
    Its rubbing the liner of the front bumper. Will the shims fix that?
    Rica25 likes this.
  21. Oct 9, 2019 at 2:08 PM
    #201
    aresenalgunner007
    aresenalgunner007 New Member
    San Diego
    2019 Black TRD PRO
    BFG KO2’s
  22. Oct 9, 2019 at 2:53 PM
    #202
    BajaTurd
    Aj
    San Diego
    19 4x max
    I’m not sure, I have Kings set around 2.5” not too high and trd 18s with 275s not rubbing anything. I’m pretty sure your spaces are pushing the wheel out enough so its reaching the liner. Try to undo the liner and push it in and retighten if possible. Shims are just gonna raise it another what 1/4”? A lot of work to just fit wheel spacers imo
    Rica25 likes this.
  23. Oct 10, 2019 at 6:43 AM
    #203
    NikNoid
    NikNoid New Member
    On my 2018 TRD Off Road (post #192 above), these tires were rubbing the skid plate on stock wheels. I added 1.25" spacers and they started rubbing the front bumper mud flap thingy. I removed it.
    Rica25 likes this.
  24. Oct 11, 2019 at 1:44 PM
    #204
    westerj12
    Gotta be the spacers. Had the shims and shackles installed today and it helped but still a slight rub (I was planning on having them installed no matter what so it wasn't an added cost). Going to take a heat gun to the liner and see what that will do.
    Rica25 likes this.
  25. Oct 23, 2019 at 6:13 PM
    #205
    Wingnut6155
    Wingnut6155 New Member
    2015 Toyota Tundra SR5
    Anyone running 275/70R18 no lift, 2wd, +18 offset wheels? I want to replace my 20s with 18s, Falken AT/3 tires and Ion 134 wheels on a magnetic grey 2015
    Rica25 likes this.
  26. Dec 3, 2019 at 5:14 AM
    #206
    316KS_Runner
    316KS_Runner There’s no place like…
    Along the CT River
    2019 MGM CM Ltd
    Front 6112 @ 1.9 Rear 5160 | Falken Wildpeak AT3W 295/70R18 | TRD Off Road wheels | Compustar Pro R3 remote start | Baja Designs SAE fog lights | VLEDS V6 Triton Extreme (amber) front turn signals | Hot Tails Option A | 6” stubby antenna | Window tint 15% rear / 35% front | WeatherTech side window deflectors | RCI Front Skid | Talons Garage front and rear CAT Protection
    6112's @ 1.9 and 5160 in the rear. 275/70R18 Falken Wildpeak AT3's.
  27. Dec 3, 2019 at 11:05 AM
    #207
    egibson606
    egibson606 New Member
    Eric
    Georgetown, ky
    2019 super white SR5 tundra
    Stock suspension. 275/70/18 falken wildpeaks.
  28. Dec 3, 2019 at 12:24 PM
    #208
    jpod
    jpod its Finally here
    London Canada
    2020 Tundra CM Cement Grey
    Diamondback HD, 1Up Racks, Yakima Bars, Garbage Weston Steps
    Any rubbing?
  29. Dec 3, 2019 at 5:00 PM
    #209
    ND_Porkchop
    ND_Porkchop New Member
    2008 Tundra 5.7 CM DSM
    Not the best pic, but 275/70/18 Nokian Hakkapellita studded snow tires. Stock 2008 4wd suspension, no rubbing.
  30. Dec 3, 2019 at 6:59 PM
    #210
    egibson606
    Eric
    Georgetown, ky
    If theres any I have yet to notice yet. I've only been running these tires for a few days tho.
    jpod[QUOTED] likes this.
