My first Tundra and my first truck :)
Discussion in 'New Member Introductions' started by 2019Tundra4.6, Sep 24, 2019.
  1. Sep 24, 2019 at 5:16 PM
    2019Tundra4.6
    2019Tundra4.6 [OP] New Member
    I think I got a good deal.
    New 2019 Tundra 4.6L CrewMax 4X2 TSS Off road package = $32,600
    I realized after purchase, that I did not have tow/haul button or electric brake control.
    Will this be an issue for towing a boat and trailer? Can the deal add these at a reasonable cost.
  2. Sep 24, 2019 at 5:20 PM
    Mnorris1206
    08 tundra
    Electronic brake controler yes but the tow haul button no. It's something that comes with tow packages from toyota. I would really recommend you make sure what is safe for your particular truck to pull before going crazy with it. But for an example I have the 5.7 and I forget many time to push that button when pulling my camper not a big deal it's just better shift points for the transmission.
  3. Sep 24, 2019 at 5:20 PM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Welcome from Alberta :canada: Brake controller addition is easy plug and play! Nice truck
    Black Wolf and 2019Tundra4.6[OP] like this.
  4. Sep 24, 2019 at 5:20 PM
    Mnorris1206
    08 tundra
    O congratulations on the new ride looks sweet.
  5. Sep 24, 2019 at 5:21 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Whoa I didn’t know a guy could buy a truck without tow/haul!?
    Mnorris1206[QUOTED] likes this.
  6. Sep 24, 2019 at 5:23 PM
    Mnorris1206
    08 tundra
    :goingcrazy:I didn't know that eather .and makes me wonder of it's a 4.6 thing or both the 4.6 and 2x4 idk. Sounds like a sweet deal but as long as he can pull what he needs to that would be my only concern.
  7. Sep 24, 2019 at 5:29 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
  8. Sep 24, 2019 at 5:30 PM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Welcome to the party!!!
  9. Sep 24, 2019 at 5:32 PM
    Patch999
    Kyle
    2017 Bad@$$ TRD Pro
    Look great. Welcome
  10. Sep 24, 2019 at 5:43 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from Colorado and good choice
    2019Tundra4.6[OP] likes this.
  11. Sep 24, 2019 at 5:46 PM
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    Hey there from Virginia!:mudding:
    Nice lookin rig! Congrats!
  12. Sep 24, 2019 at 5:50 PM
    Welcome from NY.
  13. Sep 24, 2019 at 6:17 PM
    Blueknights75
    Ron
    Clayton, NC
    Welcome from NC! Congrats on a beautiful truck!
  14. Sep 24, 2019 at 7:04 PM
    Mcoop
    Mcoop Throbbing Member
    Michael
    Berlin, NJ
    2015 Black SR5 5.7L DCLB 4x4
    Welcome from southern NJ.
  15. Sep 24, 2019 at 8:05 PM
    Welcome from TEXAS
  16. Sep 25, 2019 at 5:36 AM
    2019Tundra4.6
    Thanks for all the kind compliments! I will research the tow recommendations for my truck.
  17. Sep 25, 2019 at 5:55 AM
    2019Tundra4.6
    Are these numbers consistent with the type of towing you guys are doing?
    Tow Limits
    2019 Toyota Tundra4×2 Double Cab: 10,200 lbs.
    4×2 CrewMax: 10,100 lbs.
    4×4 Double Cab: 9,900 lbs.
    4×4 CrewMax: 9,800 lbs.
  18. Sep 25, 2019 at 6:44 AM
    CavBluTundra
    CavBluTundra CavBluisdabomb
    Howard
    2018 TRD Off Road Limited
    If you have the mechanical hydraulic brakes on your boat trailer, you won't need the electronic brake controller.
  19. Sep 25, 2019 at 8:10 AM
    Welcome from Ohio.
  20. Oct 8, 2019 at 8:57 PM
    HbbTundra08
    HbbTundra08 Epstein Didn't Kill Himself
    Brad
    2008 Toyota Tundra Crewmax SR5 2wd 5.7L
    TAC Stainless Steel Bull Bar RCI Steel Engine Skid Plate Two Stainless Steel 100w KC Daylighters Black Husky Weatherbeater Floor Liners front and rear. Kenwood Media System with Rear License plate backup camera integrated.
    My dad towed his Ranger bass boat with his 2008 Tundra since new. He never even used tow haul and had no brake controller installed.
    His boat does have electric over hydraulic trailer brakes and he's never had a problem. They just work with a normally factory installed tow package.
    He has since passed me that truck and moved on to a 2017 1794 Edition 4x4. He still tows the boat and never bothers with tow haul or the factory installed brake controller and has never had an issue. My dad has towed a boat since he could drive, so he knows his stuff I guess!
    The trucks are made to handle the towing no doubt, I think it just depends on your confidence in towing what you tow. Tow haul just lets the computer know to expect its stopping the truck with more weight behind it.
    If you're a confident driver and it's not an overly large tractor trailer or a yaght being hauled, any small trailer or boat should be easy stuff with a standard tow package.
    If you'll need special braking for larger or heavier multiple axle trailers, a brake controller of some sort would probably be advised.
    Also check what type of brakes are on the trailers or boats you wish to tow and get familiar with how they work, some require a brake controllers, some don't, and some trailers don't even have brakes! *Insert photo of my happy dad to give you confidence*
  21. Oct 9, 2019 at 7:54 AM
    2019Tundra4.6
    Thanks for input buddy! That picture of your dad hauling a boat is indeed a happy one! :)
    Tight lines and waiting for the thump!
    HbbTundra08 likes this.
