2005 Transmission fluid change/check level
Discussion in '1st Gen Tundras (2000-2006)' started by Brandusedtundra, Dec 21, 2018.
  1. Dec 24, 2018 at 6:17 AM
    Professional Hand Model
    Fred
    Hand Protectors
    What is the magic temp? Once engine warms up completely? Or somewhere in the middle? Curious as always.
  2. Dec 24, 2018 at 7:18 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
  3. Dec 24, 2018 at 10:16 AM
    growit
    growit New Member
    2006 Dbcb SR5
    Bring it to the Dealer already
  4. Dec 24, 2018 at 10:24 AM
    Fred
    Hand Protectors
    Yep. Wonder what they’ll say after 200k?
  5. Dec 25, 2018 at 1:30 AM
    remington351
    remington351 New Member
    2006 SR5 DoubleCab
    YardBird likes this.
  6. Jan 3, 2019 at 10:38 PM
    seth419
    seth419 New Member
    Santa Barbara, CA
    2005 Tundra DC 4x4
    I took mine to the local independent Toyota shop and they did it for $115 and I sat there and BS'd with the guy the whole time. I thought I had a tranny fluid leak which turned out to be the water pump. He looked at the tranny fluid and said it was time to replace. This was at 260k and I am not sure if it had ever been flushed before that, but probably not.
  7. Jan 4, 2019 at 12:21 AM
    Whocares
    Whocares Member
    Drive around, allow atf temp to reach 100 or so. Using scanguage 2.
    Park on level surface. Extremely important.
    Go through all gears while parked.
    Loosen fill plug first and then hit the drain plug.
    Approximately 2 quarts will drain - use a clear drain pan with graduated marks. Put drain plug back in. Might need a new washer.
    Refill 2.5 quarts to be safe. Run a funnel through the engine bay and refill or use a pump and refill underneath vehicle.
    Using scanguage 2, once temp is around 114 but no higher than 130 ( double check temperature for your specific year ), loosen the check plug and allow it to drain to a trickle and reinsert check plug
    Torque fill, drain, and check plug to correct number.
    Repeat that 2 or 3 more times over the course of a month or so .
    Ive been using amsoil atf with great success. Seems to shift a lot smoother than Toyotas WS atf. Anyways good luck, lots of videos on YouTube. Its not a difficult procedure by any means, just takes an hour or so.
  8. May 21, 2019 at 6:47 AM
    Jerry311SD
    Jerry311SD New Member
    Jerry
    Ramona San Diego CA
    05 Tundra
    Yeah my Mercedes is a (sealed) trans. and at 160K its acting funny in stop and go traffic jerking back and forth in sport mode when im barley rolling. I look like an idiot that cant drive a stick. lol and the car is an Auto trans
    I dont trust sealed transmissions
  9. Sep 21, 2019 at 2:50 PM
