12volts Plug & Play remote start groupbuy!
Discussion in 'Audio & Video' started by T-Rex266, Jul 31, 2019.
  1. Sep 10, 2019 at 6:38 PM
    #661
    T-Rex266 [OP] Elon approved Staff Member
    jewsNbrews and GiantsFanDan like this.
  2. Sep 10, 2019 at 6:40 PM
    #662
    Big Wave Dave
    Big Wave Dave Big Wave Dave
    2019 White Platinum Tundra
    -Rigid D series midnight fog lights -TRD Pro headlights -JL audio stealth box (2 x 10 W3 subs) -JL audio RD1000/1 amp -JL audio XD400/4v2 amp -Alpine Halo9 head unit (fully upgraded) -HDMI hook-up -TRD Pro emblems -Amp Research Steps -Fully tinted windows -Bed-liner -Automatic tailgate kicking mechanism -Roll-N-Lock E-Series electric tonneau cover -Icon 3.0 coilovers -Camburg UCA’s -Black Rhino Barstow Wheels -Toyo Open Country AT’s 295/65-20 -PrecisionLED lights inside cabin and outside including flood lights -TRD exhaust tip -12 Volts remote starter
    I got a very similar setup. It bangs!
    T-Rex266[QUOTED][OP] likes this.
  3. Sep 10, 2019 at 9:06 PM
    #663
    Rube207
    Rube207 New Member
    Rob
    Atlanta
    2010 Pyrite Mica Limited CM
    Just ordered mine, looking forward to it!
    jewsNbrews likes this.
  4. Sep 11, 2019 at 2:50 PM
    #664
    RavegreenA4
    RavegreenA4 New Member
    Gilbert, AZ
    2022 Lunar Rock SR5
    Rough County lift, VR Forged wheels, VR Bespoke steering wheel
    Ordered! Should have found this earlier...right when its about to cool down in AZ.
  5. Sep 12, 2019 at 9:36 AM
    #665
    Uhhhh....
    Uhhhh.... New Member
    Dave
    Virginia
    2016 Silver Limited DC
    7” BDS, 37s
    For those who got the optional extended range FOBs...where did you mount the receiver? I just zip-tied it to the Fortin module, but I'm finding the range sucks (even when in direct line-of-sight). Not much farther than OEM FOB it seems.
    I'm going to mount it under the driver-side pillar (where the grab handle is....if you did that mod) and see if that helps.
    Anyone finding the range close to advertised range? Where'd you mount the receiver?
  6. Sep 12, 2019 at 10:59 AM
    #666
    AZTundra
    Paul
    Phoenix, AZ
    Think it needs to be mounted up by the A Pilar at the top of the windshield so it can get a better line of communication.
  7. Sep 12, 2019 at 9:07 PM
    #667
    Snotundra
    Snotundra New Member
    2016 Silver Sky
    My truck is 2015. I don't have an alarm or glass break sensor. I installed the remote start which works great with the exception of panic alarm triggering if I turn the car off remotely. I read here that some of the 2018/2019 owners had a fix for that, but I can't find what the solution was for 2015 models. Any suggestions?
  8. Sep 12, 2019 at 10:25 PM
    #668
    Jmad1997
    Jmad1997 New Member
    Connect the white wire off the module to the white and black wire on your ECM IIRC and that won’t cause your alarm to sound. It will also trigger your alarm if you start it and leave it idling longer than 15 mins so it may be worth it to take 20 mins and connect that wire.
    Big Jeff likes this.
  9. Sep 13, 2019 at 10:26 AM
    #669
    Snotundra
    2016 Silver Sky
    This is where I get confused. Which white wire on the module?
  10. Sep 13, 2019 at 12:24 PM
    #670
    Uhhhh....
    Dave
    Virginia
    7” BDS, 37s
    Page 3 of the instructions: https://cdn02.fortin.ca/download/71361/evo-one_ig_thr_bi_toy7_tundra_2010-2017_gkey_a_71361.pdf
    Left side of diagram you'll see a yellow box that says "Vehicle equipped with factory alarm." Follow that diagram for your 2016 Tundra. It says to connect the white/black wire (#19 from the Fortin module's 20-pin connector) to the black wire (#2 black in the plug) on your truck. That plug on your truck is highlighted with the red number 5 in the picture...it's right below where one of the T-harnesses hooks up to your truck. Pic of page 3 from the instructions:
    GiantsFanDan, TheBeast and AZTundra like this.
  11. Sep 13, 2019 at 3:59 PM
    #671
    Snotundra
    2016 Silver Sky
    Here is how the alarm activation after turning the engine off remotely was solved after I spoke to James:
    In 2015 Tundra, with no factory alarm installed, I connected the white with black stripe wire from the remote module to the grey wire connected to a small 2-pin plug with two wires in it located by the key cylinder. This is the plug with only two wires: 1 wire is white with black stripe and 1 wire is grey. The thicker white with black wire is attached to the module with several other wires. The end of the white/black wire from the module needs to be striped. The coating on the grey wire needs to be stripped just enough to poke hole through and wrap the end of white/black wire around it. The white/black wire needs to be spliced into the grey wire. Both wires get taped up when done.
    Be very careful stripping the coating off the grey wire because the copper wires underneath are hair thin.
    The module works as designed now: Using the factory remote, 3 presses of lock button start the truck and 3 presses of lock button turn the truck off. No panic alarm activation when turning the engine off with the key fob and no alarm activation if idling for over 15 minutes.
    Hope this helps someone.
    nvrgvup444, Bama and Big Jeff like this.
  12. Sep 13, 2019 at 5:30 PM
    #672
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    That wire tones out to the key sense wire on the ECU pin 2 (black wire) in the instructions.
    I found it way easier to use the wire from the ECU rather than the wire Next to the ignition key that James was talking about.
    AZTundra likes this.
  13. Sep 14, 2019 at 9:43 AM
    #673
    paradizecityz
    paradizecityz New Member
    Richmond, TX
    2022 Tundra TRD Off Road
    Just tried the “fix” and it didn’t work. Truck still won’t relock :(
  14. Sep 14, 2019 at 9:48 AM
    #674
    Ted4311
    Ted4311 Don't Sweat The Small Stuff
    SOMD
    14 Tundra MGM TRD-OFFROAD 4X4
    A LOT... NEVER ENDS
    Update: added this to my things to do. Alarm sets off if I 3 press to turn off the truck.
    Do I have to do this on my 2014? I never tried to turn it off with the 3 press or let it run the full 15 minutes. (Gonna try it when I get home and I guess it'll tell me if I need to do this)
  15. Sep 14, 2019 at 10:53 AM
    #675
    Ted4311
    SOMD
    A LOT... NEVER ENDS
    Seems super simple. I'll attack this tomorrow.
  16. Sep 14, 2019 at 10:57 AM
    #676
    Ted4311
    SOMD
    A LOT... NEVER ENDS
    Don't mine my dumb question.... Just splice into it or unpin and insert the wire? Either should work right
  17. Sep 14, 2019 at 12:20 PM
    #677
    Snotundra
    2016 Silver Sky
    I spliced the black/white wire into the grey wire. I don't know if the grey wire can pushed out with a pin or something thin.
    Ted4311 likes this.
  18. Sep 14, 2019 at 5:46 PM
    #678
    Ted4311
    SOMD
    A LOT... NEVER ENDS
    Roger that thanks!
  19. Sep 15, 2019 at 8:51 AM
    #679
    MARanger
    MARanger Lost in the woods
    Andy
    Home of Friendly's Ice Cream
    2017 Super White SR5 DC 4X4
    After sitting on the starter for close to a month, finally got it installed on my 17. Straight up install, no extras for me. Works perfectly.
    Looking forward to a warm truck this winter
  20. Sep 15, 2019 at 2:44 PM
    #680
    Ted4311
    SOMD
    A LOT... NEVER ENDS
    Spliced right into the black wire on connector 5 like the directions said. No more alarm when I turn the truck off via remote or waiting the 15 minutes. Thanks for the kick ass kit @james@tech12volts
  21. Sep 15, 2019 at 4:00 PM
    #681
    ToyotaTundraMike
    ToyotaTundraMike Not A New Member
    2015 Tundra
    Loving mine so far. Having an issue that I don’t think is associated with the remote start but figured I better ask here anyway just in case seeing as I just now noticed this issue a couple weeks after the install. Probably just a coincidence but my back passenger door is completely dead. Doesn’t lock or unlock with the rest of them, have to manually do it from the inside. Anyone else have this issue? Pretty sure it has nothing to do with the remote start and it’s just the internal mechanism gone bad but want to make sure.
  22. Sep 15, 2019 at 4:09 PM
    #682
    Yoda21
    Yoda21 New Member
    Hayward ,ca
    2022 limited Trd crew max
    Sounds like the lock actuator went out tundra r known for it
    AZTundra and ToyotaTundraMike like this.
  23. Sep 15, 2019 at 4:50 PM
    #683
    AZTundra
    Paul
    Phoenix, AZ
    As stated, most likely the door lock actuator has failed and just a coincidence with timing.
  24. Sep 17, 2019 at 12:59 PM
    #684
    Ted4311
    SOMD
    A LOT... NEVER ENDS
    Update after tapping the white and black wire into black wire on connector 5
    1. Remote lock 3 press start and remote lock 3 press off. Doesn't set alarm.
    2. CL6 app start and CL6 app off. Sets alarm off (not a big deal but just noting it)
    3. CL6 app start and remote lock 3 press off. Doesn't set alarm off.
    The odds I will let it run past 15 minutes or need to cut it off are slim but it's nice having the option. Still highly recommend this kit to everyone looking for remote start.
  25. Sep 17, 2019 at 5:07 PM
    #685
    AZTundra
    Paul
    Phoenix, AZ
    Weird that the CL6 will set off the alarm when turning off the truck, but not the remote. I had this issue with the CL6 setting it off also when using it to turn off the truck, but connecting the White/Black key sense wire from the EVO to the Black wire on the ECU fixed that.
  26. Sep 17, 2019 at 5:45 PM
    #686
    Ted4311
    SOMD
    A LOT... NEVER ENDS
    I am sure I did that. I will double check and test tomorrow. Might have just been user error. Remote on and off works flawlessly and the CL6 on and off is flawless. Mixing the two she no likey
    I was tinkering on my truck this evening (detailed engine bay and cleaned leaf's out of my finder area behind the rubber when you have the door open. Drivers was horrible but passenger side was clean) and did 3 tests. Didn't mess with it aside from the 3 tests.
    AZTundra[QUOTED] likes this.
  27. Sep 17, 2019 at 5:52 PM
    #687
    AZTundra
    Paul
    Phoenix, AZ
    Ok, maybe I didn't catch that....so it starts/stops correctly with the remote or with the CL6, you just can't mix them (start with CL6 / stop with remote). I'll have to try that on mine and see if it sets it off. I never thought about mixing them when I tested mine.
  28. Sep 17, 2019 at 6:06 PM
    #688
    Ted4311
    SOMD
    A LOT... NEVER ENDS
    It works like a champ if I start and stop with either the remote or CL6. I was curious about mixing so I tried remote started and CL6 off, bam no likey. As I said definitely not a big deal, I just wanted to make note of it
  29. Sep 17, 2019 at 6:07 PM
    #689
    Ted4311
    SOMD
    A LOT... NEVER ENDS
    I'm a tech junky so I enjoy testing new stuff I install :D
  30. Sep 17, 2019 at 9:25 PM
    #690
    captain_bij
    captain_bij New Member
    Bijan
    15’ Tundra Crewmax Platinum 4x4
    Ahhh maybe I should have read through this a little more. Placed an order Friday evening since the link still worked figured the group buy was still going.
    Can anyone verify that?
