2006 Tundra starts and shuts off 2 seconds later
Discussion in '1st Gen Tundras (2000-2006)' started by Dook55, Sep 15, 2019.
  1. Sep 15, 2019 at 9:04 AM
    Dook55
    Dook55 [OP] RCLB Guy
    Montana
    My dog alerted me and I found a packrat under the hood of my 2006 V8 4x4 regular cab Tundra this morning and used brakleen to herd it into my dog's mouth, but not before the rat did some damage to my wiring. In several places under the hood I've found where she chewed plastic covering off the wiring harnesses, but I didn't find any actual wire insulation chewed....not yet anyway. Nothing down to bare copper anywhere.
    It starts up every time, but shuts down 2 seconds later. The only way I can keep it running is by pushing the accelerator enough to maintain 3000+ RPM.
    I can't find any indication what or where the problem is, but don't know what to look for. I'm pretty handy mechanically but a total zero when it comes to electronics.
    Any help or suggestions would be greatly appreciated.
  2. Sep 15, 2019 at 10:58 AM
    Dook55
    Montana
    OK, I think I found the problem. She chewed a wire in two that went to the 2 wire module on top of the right front fenderwell. I spliced it back together, re-booted the battery and it seems to work fine now.
  3. Sep 15, 2019 at 11:00 AM
    PenderBen
    PenderBen Forum lurker…
    Gulf Islands, BC Canada
    2003 Tundra AC 4x4
    Any chance it got into the air filter housing? Maybe it started to nest in there and blocked things up, I’ve had mice do that and pack a lot of debris in there. Are there any fault codes?
    Dook55[OP] likes this.
  4. Sep 15, 2019 at 11:01 AM
    PenderBen
    2003 Tundra AC 4x4
    Never mind, sounds like you’ve got it :)
  5. Sep 15, 2019 at 11:03 AM
    15whtrd
    15whtrd Mr. Blonde
    Next step, come up with a deterrent to keep that little shit away from your truck. Dryer sheets, mothballs, peppermint oil or specific deterrent sprays.
  6. Sep 15, 2019 at 11:10 AM
    Dook55
    Montana
    Thanks!
    I'll try mothballs under the hood. I do use peppermint oil in the interior but it doesn't always work, they get into my Cherokee anyway. The Tundra cab is secure enough to keep them out. That was the third packrat old Blue killed in the last month.
    15whtrd[QUOTED] likes this.
  7. Sep 15, 2019 at 11:15 AM
    15whtrd
    15whtrd Mr. Blonde
    Good luck man. That’s gotta be the one of the worst things to have to deal with. You do your best to take care of your truck and do all the maintenance. Then something completely out of your control comes and chews up your wires. I consider it worse than having a car accident or some uncontrolled act of nature like hail. Little bastards!
    Welcome to the forum by the way!
    GODZILLA and Dook55[QUOTED][OP] like this.
  8. Sep 15, 2019 at 12:26 PM
    MS22
    MS22 New Member
    02 Tundra 4x4
    I boiled up a bunch of diced Jalapoes and basically any other type of hot pepper you can find and add alot of cayenne pepper. Strain it and dump the juice in a spray bottle and spray engine bay and around your truck. Works awesome well for me it does. Good Luck
    Dook55[OP] and 15whtrd like this.
  9. Sep 15, 2019 at 12:28 PM
    15whtrd
    15whtrd Mr. Blonde
    What a great idea! Just be careful when you’re working on your truck you don’t rub your eyes!
    MS22[QUOTED] likes this.
  10. Sep 15, 2019 at 12:29 PM
    15whtrd
    15whtrd Mr. Blonde
    Also to add to your idea, maybe using some type of oil with it so it stays on everything for longer. Chop up all the peppers and mash it with a light automotive oil.
  11. Sep 15, 2019 at 12:32 PM
    DireWolf
    DireWolf The Dark Lord - Tundra Owner
    North East Florida
    2016 Dark Gray Tundra SR5 (MGM)
    none
    This may sound stupid but in an F 150 i had that with a spare key i had that had no chip in it, it opened door fine would start the truck and then die.
    Filthyphil and Dook55[OP] like this.
  12. Sep 15, 2019 at 12:36 PM
    15whtrd
    15whtrd Mr. Blonde
    Yeah it definitely needs to chip in the key to keep the antitheft unlocked.
