Questions on rims for Waltrip Tundra
Discussion in '1st Gen Tundras (2000-2006)' started by RAMTEK, Sep 8, 2019.
  1. Sep 8, 2019 at 7:07 PM
    RAMTEK
    RAMTEK [OP] New Member
    Randy
    Phoenix, AZ
    2006 Darrell Waltrip Tundra
    no mods
    Just picked up a 06 Waltrip Tundra 4x4. Love this truck! This is the second 1st gen I've owned and these are great trucks. Noticed the door sticker calls for 18" rims. I know for a fact my other 1st gen took 16" rims, so I called Toyota directly. They confirmed that this truck does indeed take the 18". When I bought the truck, it currently has aftermarket 16" rims. Decent tires, I can probably get another year out of the rubber, but when the time comes to change rubber, I want to put the truck back on 18" rims as was meant to be on this truck.
    I am having a hard time finding OEM 6 lug 18" rims however, and I dont know how to find the "offset". I dont need fancy rims, just the original rims would be good. I dont need "new" as long as they are in good shape with no curb rash. I'll also need a steel 18" rim for the spare.
    I called all wreckers in area but no one has 18" rims for this truck. I called all the dealerships in the area asking for "take offs" but they want a small fortune for their rims.
    So guys, anyone have any advice? Your thoughts and comments (and pictures) would be valued and appreciated. (Also, what "offset" do I need?)
    RAM
  2. Sep 8, 2019 at 7:30 PM
    Vince
    Vince New Member
    Vincent
    Terre du lac, Missouri
    2011 White DBL cab 5.7
    K&N intake, Air bags
    Rockauto might have what your looking for.
  3. Sep 8, 2019 at 7:30 PM
    BestGen
    BestGen New Member
    Paul
    Haunted Turnbull Canyon CA
    '05 RCLB, 2UZ-FE, 4wd / '88 4RNR XTE 22RE/W56/RF1A
    Fabtech 2.5" coilovers, BFG KO2 34/10.5/17, 17x7.5 TE wheels, add-a-leaves, 4.56 gears, Rhino-lined
    The Darrell Waltrip edition Tundra came with 18"x9" BBS wheels. These trucks are fairly rare. Approximately 2000 were made. I see the rims pop up on CL occasionally, usually for around $800-850 for a set. IMG_3137.jpgIMG_3138.jpg IMG_3139.jpg
    Darkness and because_wumbo-truck like this.
  4. Sep 8, 2019 at 8:12 PM
    RAMTEK
    Randy
    Phoenix, AZ
    no mods
    @Vince: None of the "main line" wheel/tire outlets show the 18". The 1st gens were all shipped mostly with 16" and a few 17". Only the Waltrips were shipped with 18" and NO ONE carries these.
    @BestGen: Interesting to know that only 2000 (or so) were made. If I cant find the original TRD's, then I guess any Toyota rim would work. I found this link on our tundras.com marketplace: https://www.tundras.com/threads/trd-off-road-18”-wheels-and-michelin-tires.43130/. How would I know if these would fit? Dont really want to buy something and have it shipped to find out the patter doesnt match my lugs.
  5. Sep 8, 2019 at 9:18 PM
    BestGen
    BestGen New Member
    Paul
    They won't fit. :smack: Count the lugs. You need 6 lug 6x139.7 pattern. Most of the rims from Tacomas, 4Runners, 1G Sequoias, pre-98 Landcruisers, and all other 1st Gen Tundras will fit. :yawn:
  6. Sep 8, 2019 at 11:26 PM
    SoCalPaul
    SoCalPaul New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
  7. Sep 9, 2019 at 4:31 AM
    But I think OP is asking if he has to put 18" rims and when he called Toyota they made it seem like he does. That can't be right.
    I don't see why he can't go with a 16 or 17" rim. Right?
  8. Sep 9, 2019 at 5:50 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Kinda a confusing question, but is he saying that his truck came with OE 18s but a previous owner sold them? The walltrip whees are definitely badass looking
  9. Sep 9, 2019 at 7:47 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    The 18” wheel is just for aesthetics. The overall tire size will be the same as with your current 16” wheels.
    The 18” wheels will just have a shorter sidewall, and will be MUCH more expensive than their 16” counterpart.
    speedtre likes this.
  10. Sep 9, 2019 at 11:58 AM
    josef
    josef Babe Magnet
    Josef
    Victoria TX 77904
    2002 tundra which I recently sold for $5,500 and bought 2019 limited.
    Are your 16" rims chrome in decent shape. I have a 2002 tundra sr5 and it has very poor looking rims and I would like to go to chrome.
  11. Sep 9, 2019 at 12:50 PM
    RAMTEK
    Randy
    Phoenix, AZ
    no mods
    @FirstGenVol and @Hdjeff: Sorry for being confusing. According to OE specs from Toyota, the truck was originally outfitted from the factory with 18" rims. I bought the truck about a month ago. Somewhere between the time it was sold new, and the time I bought the truck, the previous owner removed the 18" rims and put on 16" rims. I was wanting to go back to the original rim size, because somehow I thought if Toyota built the truck for it, then I'd like to put it back to what it was "supposed" to be.
    @tvpierce: Thanks for that info. For some reason I guess I had it in my head that the smaller rims on the 4x4 would tweak with the speedo, torque, and mpg. If the overall tire size and height of a 16" with rubber and an 18" with rubber are essentially the same, then I can see it basically being an aesthetics issue.
    @josef: yeah, the rims are great shape, but I need to get another set before I can take these off.
    Here's whats on there now:
  12. Sep 9, 2019 at 1:00 PM
    josef
    josef Babe Magnet
    Josef
    Victoria TX 77904
    Keep me in mind
  13. Sep 9, 2019 at 1:08 PM
    RAMTEK
    Randy
    Phoenix, AZ
    no mods
    Here are two more pics of the wheels. The tires on the truck now are 275/70R16. The original specs call fro P275/55R18. Althought I prefer "Light Truck" tires over "Passenger" tires for my 4x4's. I feel better having that extra sidewall. No fun blowing a tire in the boonies.
  14. Sep 9, 2019 at 1:31 PM
    The Waltrip packing was essentially a cosmetic one. I'm not aware of any mechanical differences that would require 18" wheels. There is nothing wrong with running smaller wheels on there. Now, if you wanted to return it to its original look and put the OEM wheels on there that would be cool but you'd likely pay a premium.
    because_wumbo-truck likes this.
  15. Sep 9, 2019 at 1:38 PM
    BestGen
    BestGen New Member
    Paul
    What happened to the red Waltrip badges and stripes? :notsure:
    The only thing that'll fk with your speedo, torque, and mpg is overall tire diameter. Wheel diameter is irrelevant. Taller tires will require a gear change to maintain or improve acceleration performance.
  16. Sep 10, 2019 at 3:36 AM
    josef
    josef Babe Magnet
    Josef
    Victoria TX 77904
    "@josef: yeah, the rims are great shape, but I need to get another set before I can take these off."
    I have good tires but certainly would like better rims. I'm certainly in no hurry just trying to get my dibs in.
    pretty good looking set of rims SoCalPaul found at what I would consider a fair price
  17. Sep 10, 2019 at 4:11 AM
    tvpierce
    Maine
    Your current tire is slightly oversided from stock.
    Stock on an SR5 would be 265/70 R16 -- for a total diameter/tire height of 30.6"
    Your currently setup is 275/70 R16 -- for a total diameter/tire height of 31.15"
    The Waltrip setup is 275/55 R18 -- for a total diameter/tire height of 29.9"
    Strickly from an asthetic point of view (IMHO) 18" wheels on these trucks are too large, unless you're running a lift. If you're not running a lift, those skinny little 55 sidewalls are for sportscars -- they look silly. If you are running a lift, you can go with a larger sidewall tire that is appropriate for a truck.
    To me, 265/75 R16 (one size over stock, 31.6") is the ideal size for a stock truck. It fills the wheelwell nicely without it looking "stuffed". Plus they're available in 10 ply which will make for an incredibly durable tire.
    The sizes mentions above are facts, the rest is simply my humble opinion.
    Hbjeff likes this.
  18. Sep 10, 2019 at 11:21 AM
    RAMTEK
    Randy
    Phoenix, AZ
    no mods
    • @tvpierce: This is GREAT info! I really appreciate it. I agree the thinner sidewalls on a truck look silly to me, but I do see a lot of the low profile tires on lowrider trucks around town. For me, not my style.
    I did find BFG KO2's in both LT275/70R16 (overall height 31.1") as well as LT275/70R18 (overall height 33.2"). I am not a aggressive offroader, but I do hunt and have encounters washouts and streams before. In AZ, the terrain is pretty harsh and Im not sure how well the Michelin Defenders would do once I get them off pavement into jagged rocks and cactus. So for me I feel better with the LT sidewalls and load ratings.
    I called Toyota and they were pretty adamant of staying on the 18" on the Waltrip. I realize its probably aesthetics like you said, and I tend to agree with that, but still the truck was made for 18"s.
    My thought would be to get the 18"s back on the truck, add a bit more sidewall height to the tire, not to increase the overall height of the truck (thats not the point) but to add a bit more cushion to the ride. Moving off Defenders to the KO2's will add a bit stiffer ride, a bit more road noise. If I add a bit more sidewall, perhaps that might take some of the stiffness out of the drive on pavement. Am I totally wrong about this?
    I did a rough mockup of the truck with the current 16" on it (top picture), as well as with the BBS 18"s that came with the truck (bottom pic).
    As always, I am very appreciative of your expertise, thoughts and comments.
    Original:
    with OEM rims:
  19. Sep 10, 2019 at 11:49 AM
    SC T100
    SC T100 New Member
    2005 Toyota Tundra Double Cab 4WD
    Rancho Quicklift/RS9000XLs, Rancho rear 1.5" blocks with RS9000XL shocks in rear, SuspensionMAXX extended sway bar links.
    I'd note your truck wasn't necessarily "made" for 18s. There is no difference in the suspension/brake setup between the 16, 17, and 18 inch wheels that came on the Double Cabs. The dealer likely cannot legally recommend anything other than what the VIN spec says. IMO the 17s look best on the DCs, and provide plenty of sidewall. For a touch taller tire that fits stock suspension, a 265/70R17 gives some additional sidewall, and a little bit of lift, and can be had in P-rated, C-range, and E-range. For your use I'd find a good set of used 17s (either the split 5-spoke or the newer 4Runner snowflake rims) and run C-rated KO2s or some other quality a/t tire in 265/70R17. This size is often cheaper due to it's widespread use.
    tvpierce and FirstGenVol like this.
  20. Sep 10, 2019 at 8:23 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    That explains why I never heard of it. Neat
    BestGen[QUOTED] likes this.
  21. Sep 13, 2019 at 8:02 AM
    ClemsonTundra
    ClemsonTundra New Member
    Will
    2005 DC TRD 4x4
    OME 90005 F/R. F w/ 885 coils
    Have them on my 05. Favorite wheels
    HBTundra and BestGen like this.
