Sirius Radio problems
Discussion in 'Audio & Video' started by Drew C, Sep 11, 2019.
  1. Sep 11, 2019 at 5:44 PM
    Drew C
    Drew C [OP] New Member
    I have a 2018 Tundra, to put it mildly mine SUCKS. Any overhanging tree and the signal drops, hell - any tree with 50-100' of the vehicle and the signal drops. It's pretty much impossible for me to listen on the local roads. I drive 95 (in CT) for about 7 miles and even there I routinely lose the signal. Trees are not close to the road and don't overhang.
    Anyone else's sat radio do this?
  2. Sep 11, 2019 at 5:55 PM
    redryder
    redryder New Member
    Ryder
    Louisiana
    2018 Limited Cement CM
    Mine does the same thing.
  3. Sep 11, 2019 at 6:05 PM
    Drew C
    My wife's vehicle (range rover) has zero issues. It works all the time and every location.
  4. Sep 11, 2019 at 6:22 PM
    XDevilboiX
    XDevilboiX New Member
    2019 Tundra Limited TRD Off Road Silver
    I lose signals here in the burbs too. Reception sucks but when I’m in the city, there’s no problem at all
  5. Sep 11, 2019 at 6:36 PM
    Jerry70
    Jerry70 New Member
    Lakes region NH
    2019 Limited CM OR CAValry blue
    TRD exhaust, TRD rear sway bar
    Mine does the same thing!! Annoying AF! I have been reading it is a software issue or something to that nature? Hopefully Mama Toyo comes up with a fix.
  6. Sep 11, 2019 at 6:41 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Mine does the same , also.
  7. Sep 11, 2019 at 7:30 PM
    robz
    robz New Member
    Rob
    2015 Platinum 2WD
    Full interior LED lights. Bed cover. OEM LED Headlights and Fog lights
    Reception for satellite radio sucks, period.
    Go under an overpass, loose signal, tree branch loose signal, thick clouds loose signal.
    This is due to the spectrum in which the signal is transmitted, it is not good at going through objects.
  8. Sep 11, 2019 at 7:33 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I hit a few minor dead spots that last a second or so. Other than that I only lose signal in u turn lane under one bridge if going slow and it is brief.
  9. Sep 11, 2019 at 8:12 PM
    My new to me 14 only loses the Sat signal going up Clear Creek Canyon here in CO. Wall to wall rock cliffs, otherwise zero Sat acquisition issues.
  10. Sep 12, 2019 at 8:03 AM
    panicman
    Eric
    2018 SR5 CM TRDoffroad MGM
    I get a strong signal everywhere EXCEPT on my morning and evening commute in a 3 mile stretch, it’s really bad.
    In the morning I am heading north and I have a steep tall hillside to the east. It cuts out severely, and for at least :30- 1 min.
    In the evening, same place. Headed south and that big hill is to my left.
    I am imagining that the satellite(s) signal is coming from generally east (I am in Oregon, about as far west as you can go without changing to a boat).
  11. Sep 12, 2019 at 8:34 AM
    18" TRD Off Road Wheels
    My reception only tanks if there is something that can block the "view" of the antenna. Canyon wall, tunnel, etc. If you are having issues without anything being at least moderately close or above you, it might be due to interference from other sources. Electrical lines and even storms can create enough interference to cause problems, and that doesn't even begin to scratch the surface of other radio/signal broadcasting and receiving equipment in the area. The FCC regulates signals and frequencies for a reason. They are limited and not hard to mess up.
  12. Sep 12, 2019 at 8:56 AM
    Toyokuhl
    Toyokuhl New Member
    aaron
    SWFL
    2018 Cav Blue CM OR
    Any specifics?
  13. Sep 12, 2019 at 12:14 PM
    Ely010606
    SPARKS, NV
    Almost the same as everyone, when i go under a bridge, trees, and the odd one is when i drive by the side of the building from my gym it cuts off and when i park on the other side its fine.
