VF Tuner 3UR Support - Development Tools
Discussion in 'Performance and Tuning' started by OVTune, Apr 25, 2019.
Thread Status:
Not open for further replies.
  1. Sep 11, 2019 at 7:33 AM
    #931
    OVTune
    OVTune [OP] New Member
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    Some other nannies yes. Like SAI throttle limits and that junk.
    Could *probably* make any gauge do anything but it has to be practical.
    Mountun Goat and theraven like this.
  2. Sep 11, 2019 at 7:36 AM
    #932
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Oh cool, I wasn't to clear on the map switching part or what my tow haul button did anymore other than locking the gears, which is also does in drive. It would certainly be nice to have the option of an 87 octane tune, just in case...
  3. Sep 11, 2019 at 7:38 AM
    #933
    Jbtaco2002
    Jbtaco2002 Almost a Tundra
    San Diego
    nothing cool
    Much needed info, probably should be in the 1st post.
    Ok guys, no more questions please, I sent Matt my config and he's building my tune... Please let's not distract him for a bit :annoyed:
  4. Sep 11, 2019 at 7:38 AM
    #934
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    sry, whats sai
  5. Sep 11, 2019 at 7:41 AM
    #935
    osidepunker
    Alex
    2013 Tundra DC 4x4
    @OVTune question on the map switching with tow haul button:
    Does it remember which map you have set every time you turn off/on the truck??? If I have map 1 for 87 and map 2 for 91, I wouldn't want it to default to a particular map every time I start the truck. That could be bad haha
    theraven likes this.
  6. Sep 11, 2019 at 7:43 AM
    #936
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Thank you for the clarification on features that come turned on. My last comment to avoid clogging this thread, is it possible to make the stock transmission temperature gauge (and engine temp gauge) actually show accurate temperature readings? My biggest annoyance is I need my phone to monitor the ATF temp even though I have the stupid stock gauge that never moves. Can that be set to something like low is 120F and high is 320F or something?
    4firemandan and OBXTundra like this.
  7. Sep 11, 2019 at 7:45 AM
    #937
    roy2015
    roy2015 Waterproof
    Houston
    Super White = Super Fast
    This is awesome. I’m waiting for my tune now and didn’t know I needed to specify. What would I need to do for map switching.
    Also, what all choices do we have for the map switch tunes?
    EDIT: although nap switching sounds nice
  8. Sep 11, 2019 at 8:06 AM
    #938
    coTony
    Tony
    Montrose, CO
    Having a compiled list of standard features in all, optional features and then definitions of what each does would be a huge, huge, huge help to those new to Tundra tuning.
    roy2015, snivilous and Danimal86 like this.
  9. Sep 11, 2019 at 8:11 AM
    #939
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Would you be able to have the battery gauge work normally for one tune, and press the tow/haulass button switching to another tune and then the battery gauge turns into afr meter? That would be bad ass.
    Would also be cool to have the second tune turn off all the nannies also (true beast mode). But still be able to turn traction control on in case you are actually towing.
    roy2015 and HulkSmurf14 like this.
  10. Sep 11, 2019 at 8:33 AM
    #940
    KevinK
    Back in Arizona. Again.
    Tundras to Sedona
    Disabling nannies by default at vehicle start may be a slippery slope for a tuner. If the vehicle isn't "safe" when it's turned on, there could be liability issues. They may be able to make it a single button press to accomplish all nannies off, instead of making you do the button dance. But then the issue is, suppose you do want auto LSD or Atrac to work - how do you get to that?
    The ECU determines E% through calculations based on the O2 sensors and either adds or reduces fuel and spark in order to keep AFR "correct". It's a pretty horrible solution overall and they should have just put an E% reader in the fuel line.
    Most ECU as far as I know don't have a persistent KAM in order to 'remember' the last setting. Typically you choose a base value that the truck starts with every time, and then make an adjustment after the key is on if you want something other than your base value. Basically the truck is gonna start in 87 map every time, until you press the Tow/Haul (or use the cruise control stalk if we can talk them into that switching method).
    What app are you using to read trans temp on your phone? I've only seen the trans temp run on the CANBUS and not on the OBDii.
  11. Sep 11, 2019 at 8:36 AM
    #941
    roy2015
    roy2015 Waterproof
    Houston
    agreed this would be epic
  12. Sep 11, 2019 at 8:38 AM
    #942
    TruckyTruck
    Gary
    @OVTune
    Could you clear this up?
    Is the 93 tune I have already set up this way or is this something different? I'd like to have the option to switch to 87, but not at the expense of having more power in the current 93 tune that I have for towing.
    From your site under towing:
    That means all new fuel controls ,all new ignition tables, lock up(if desired) and much more.
    Independent VVT Tables that are setup specifically for TOWING and pulling weight.
  13. Sep 11, 2019 at 8:49 AM
    #943
    KevinK
    Tundras to Sedona
    Yeah, this is where fuel type switching with cruise control would be nice. because then the tow/haul button could still be a tow/haul button and just change the vvt tables for towing.
    TruckyTruck[QUOTED] likes this.
  14. Sep 11, 2019 at 8:49 AM
    #944
    osidepunker
    Alex
    2013 Tundra DC 4x4
    wth is a KAM???
    Why would I want my cruise control to mess with the settings??? What wrong with the tow/haul button???
    TruckyTruck likes this.
  15. Sep 11, 2019 at 8:52 AM
    #945
    snivilous
    SW UT
  16. Sep 11, 2019 at 8:55 AM
    #946
    KevinK
    Tundras to Sedona
    Sorry, KAM is Keep Alive Memory. it's like RAM in your computer - it's information the ECU is using while the engine is running, but it goes away when you turn the key off.
    The benefit of using the cruise control to change fuel types is that the Tow/Haul button can still be used to change fuel and timing curves independent of fuel type so that there are still unloaded and fully loaded options (keeps the Tow/Haul button's original functionality).
    basically with the cruise control stalk, you could pull and hold towards you until the tach needle jumps to show you what map you're on (default at sstartup is 1). then move the cruise stalk up and down to move through the map selections (probably 1 and 2, unless he expanded to like 4 different maps) and the tach will show you which map you're on 1, 2, 3, or 4. Pull toward you once to set that map as the one you want to use.
    theraven, Vr0ck and OBXTundra like this.
  17. Sep 11, 2019 at 8:55 AM
    #947
    osidepunker
    Alex
    2013 Tundra DC 4x4
  18. Sep 11, 2019 at 8:56 AM
    #948
    KevinK
    Tundras to Sedona
  19. Sep 11, 2019 at 8:57 AM
    #949
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Way too complicated. I dont want to be driving a SNES and have to press series of button just to enable a easter egg
  20. Sep 11, 2019 at 9:02 AM
    #950
    snivilous
    SW UT
    Well if they're not accurate the more reason to inquire about the dash gauge being made functional. So far they show realistic numbers for me, but that's not saying much.
    KevinK[QUOTED] likes this.
  21. Sep 11, 2019 at 9:03 AM
    #951
    Danimal86
    Daniel
    Sacramento, CA
    It's a lot simpler than you think.
  22. Sep 11, 2019 at 9:10 AM
    #952
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    I will update the main post with all current options, setup, etc
  23. Sep 11, 2019 at 9:36 AM
    #953
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Got my tuning package...just waiting on my registry code! Yeehaw!!
  24. Sep 11, 2019 at 9:44 AM
    #954
    KevinK
    Tundras to Sedona
    Is that your car? Our FRS tune is exactly where the idea came from. We ran the ECUTek from Crawford.
    @osidepunker it's super easy, the explanation is more convoluted than the actual use.
    Pull and hold, up, pull.
    papasmurf and ryanwgregg like this.
  25. Sep 11, 2019 at 10:19 AM
    #955
    TruckyTruck
    Gary
    This is what I'd like to see with my truck. Before I send an email to zendesk, could you tell me if it is possible.
    While in D:
    *Starting the truck each time -93 with expanded vvt/holy moly power mode.
    * Press tow haul - 87 octane map. Again, as best as that octane can perform.
    * Battery gauge shows battery
    S mode:
    automatically goes into gear lock without pressing tow haul and forces the truck back to 93 octane/vvt goodie, Dyno day power.
    While in S:
    *Upon moving to S mode- map switches to 93 octane like it's set up in D
    *Pressing tow haul - does not switch to 87 octane, but stays in 93 octane and expands the 93 map for towing setup.
    * Battery gauge shows afr
    I'd like the option to run 87 if that's all I could get as a fuel source, but also would like the tow haul button to function as a tow map only under S mode and only for 93.
    Is this possible and am I off track with any of it?
    Edit: of course, I may need to wait to request anything, due to any additional options you have coming... :notsure:
    ryanwgregg, roy2015 and Wynnded like this.
  26. Sep 11, 2019 at 10:40 AM
    #956
    Danimal86
    Daniel
    Sacramento, CA
    No, I just remember seeing what you were talking about on a supercharged frs build on YouTube.
  27. Sep 11, 2019 at 11:32 AM
    #957
    KevinK
    Tundras to Sedona
    That could get pretty confusing pretty quickly.
    I'd propose:
    Cruise Control for fuel switching
    Tow/Haul for Holy Moley Power
    S mode for gear lock
  28. Sep 11, 2019 at 11:43 AM
    #958
    coTony
    Tony
    Montrose, CO
    I like that Kevin, I keep thinking what I am giving up by taking over the Tow Haul button and the scenario you have here would be nice.
    The Nannies I have under control with TR7 switches that I have wired up with a button to turn it on/off. I have the button turned off at all times for normal factory mode. When I turn the button on the TR7's are on when the ignition is turned on and they do the button pushing for me. At the time I want granularity I have full control.
  29. Sep 11, 2019 at 11:43 AM
    #959
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    Technically yes this is possible simply by using a several branch statements in code that correspond to option criteria ( go here if X is enabled, go here if X and Y enabled, go here if X Y and Z, etc)
    However..this isnt something we'd likely do, due to it being a 1 off custom coded job that would likely never be used or requested by others.
    We could do it but custom coding outside of features we create I would have to charges for dev time :(
  30. Sep 11, 2019 at 11:44 AM
    #960
    TruckyTruck
    Gary
    I could get on board with that...
    Cruise control shifts between 87, 89, 93
    I'd want the truck button to start out with holy moly power though.
    Then when tow haul is pressed, it's set for towing.
    You are on to something:hattip:
    Mountun Goat, ryanwgregg and Wynnded like this.
Thread Status:
