Lift Options and Wheels
Discussion in 'Wheels & Tires' started by COelkhunter84, Aug 8, 2019.
  1. Aug 8, 2019 at 1:22 PM
    COelkhunter84
    COelkhunter84 [OP] New Member
    Hey guys -
    New Tundra owner, second one actually, had a Ram 2500 in between because of heavy towing.
    Picked up a 2019 SR5 TRD last week - white. Sweet truck!
    I have literally been reading these forums and Facebook groups since the day I signed the paperwork.
    I have a few options for wheels and lift and I'd like your guys' opinion that have "been there, done that".
    I'm going with Ridge Grapplers 285/70R18 (34x11.5)- I really like this 'in between' size.
    I've seen a lot of guys run these on the TRD PROs 100% stock and they work great!
    Obviously, my Tundra and the PROs have different suspension components (and the 2" lift).
    I'm a Colorado guy, avid hunter and camper, so I am on some decent off-road stuff, nothing crazy. 90% of the time I'm a commuter and kid hauler.
    I ordered the 6112 Bilsteins preset at 2.5" (top)
    I ordered 3 CB shims, I'll run the DS one for sure.
    I ordered adjustable shackles 1-1.5"
    My thoughts are to run the Bilsteins at 2.5" (add my one DS shim) and run 1" lift in the rear. This SHOULD be no issue - technically it's more lift than the PROs.
    Now, wheel offset plays the biggest role in what rubs and what doesn't rub.
    I could run OEM TRD wheels and probably not rub. I do like a little wider stance - so I could run SpiderTrax 1.25" spacers as well.
    OR I can get some Fuel wheels pretty discounted with a +20 offset.
    I've seen a lot of guys also run 3/1's and 3/1.5's - I could easily do this by adding the CB shims to both sides and bumping the rear up to 1.5" (I do like a little rake, often have a decent load in the bed) .
    If you guys were me - what setup would you go with having all those options??
    I also question jumping from 2.5" to 3" if I need UCAs (I know they help regardless). Also, jumping from 1" to 1.5" in the rear on the adjustable shackle?
    Please let me know your thoughts from people who have been there, done that.
    I appreciate it in advance!!
    Black Wolf and Primalbryan like this.
  2. Sep 4, 2019 at 12:35 PM
    Primalbryan
    Primalbryan New Member
    2019 Limited Tundra Off-Road TRD- White
    TRD dual exhaust
    Please post photos if you do this! I’m looking into progressive AAL and a leveling kit to run the 285/70r18s.
  3. Sep 4, 2019 at 12:46 PM
    MAGDADDY
    MAGDADDY TTC #280
    JON
    Houston TX
    18 Platinum CM MGM
    Leer 100XL, Bedrug, Go Rhino running boards, LED int/ext lighting, Bilstein 6112/5100 1/2”shims up front, Coachbuilder +3 shackles, CB drop, TRD front/rear sway bar, 275/65/20 Michelin LTX M/S 2, sequoia painted mirror cap/door handles, Rago Fab low pro ditch brackets, Baja Designs S2 sports ditch lights. Baja Designs S2 sport rear flush mount pod
    As for wheels I haven’t much to say since I kept mine stock. However I am running the 6112 at top setting with 2 cb shims on ds and one on pass. The rear is 5100 shocks along with the coach builder +3 shackles. I went ahead and got some JBA HD UCAs for alignment. I gained 3.25 up front and close to 2” out back. You can see my truck sits a touch nose high but since I lifted it seems to have settled a tad but still a tiny bit nose high. So you might be good only running one shim on ds to keep it more level. Good luck and make sure to update us with pictures!E22C9915-C07B-48F3-9A39-DB3174582909.jpgE2340D65-B30C-49D4-904E-4160705B5680.jpgFD94D6CD-3A54-4374-886B-3FE5CA981386.jpg
  4. Sep 4, 2019 at 1:27 PM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    Bak Revolver, BedRug, Undercover Swingcase, PopLock, Bilstein 5160(rear), Firestone RideRite, TRD rear sway bar, Coachbuilder +2 rear shackles, Andersen 5” aluminum adjustable hitch, TRD dual exhaust, VLEDS interior leds including the footwell kit, TundraTex FRAC mod, VLEDS LPR backup tag mount led, Husky X-Act mats, Color matched cup holder bezel (silver), Ceramic 20% tint all around, 50% Ceramic windshield, Color Matched door handles & mirror caps, The “Stubby” antenna, AMP Research steps, VLEDS 6”step lights, ToyTec/5100 Bilstein coil overs, 700lbs red ToyTec springs (2.75” lift), 20x9 +18 Method 306 custom painted and custom fit center caps, Gorilla spline lugs, Bridgestone Revo 3s 285/60R20, TRD skid plate, RaptorLiner “Red” tow hooks, 19 Pro black LED headlights, VLEDS Triton V6 turns, Rigid SAE D series fog lamps, 19 TRD hood scoop, 2019 TRD Pro grille, Coachbuilder bumper shims, X-Pel protect under mud guards, Opti Coat Ceramic, Opti Coat Sealed. And some snakes and sparklers, because they are my favorite!
    Did you keep your stock wheels because you can’t find anything you like? That’s the problem I’m having, about to order set #3.
    Rica25 likes this.
  5. Sep 4, 2019 at 6:47 PM
    MAGDADDY
    MAGDADDY TTC #280
    JON
    Houston TX
    18 Platinum CM MGM
    Damn that sucks! Built mine for road trips so I was trying to keep it more on the efficient side. But I’m sure later on I’ll find some wheels I can’t live without.
    Rica25 likes this.
  6. Sep 4, 2019 at 6:51 PM
    Rica25
    Ricardo
    Tulare
    I have same set up just last week
    Black Wolf and Tundraman1000 like this.
  7. Sep 4, 2019 at 7:25 PM
    Primalbryan
    TRD dual exhaust
    @Rica25 what wheel/tire setup did you end up with? Can you post some pics of the final/current result as well?
    Rica25 likes this.
  8. Sep 4, 2019 at 7:26 PM
    Primalbryan
    TRD dual exhaust
    Also how much did this setup run you guys for parts/labor or time if you installed it yourself?
    Rica25 likes this.
  9. Sep 4, 2019 at 7:31 PM
    Rica25
    Ricardo
    Tulare
    I have 275 65 18 Michelin Ltx at2 with Blak Rhino glamis wheels with +12 offset.....I ordered from wheelers offroad and with discount from forum with new KYB top hats was about 1050.00 out the door or close to that......labor was cheap for me I work at the dealer so my buddy did the front for me and alignment.....I did the rear my self and took about 1.5 hrs
    Black Wolf likes this.
  10. Sep 4, 2019 at 8:13 PM
    zcarpenter92
    zcarpenter92 Yotas and Yellow Jackets
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Rica25 and Black Wolf like this.
  11. Sep 4, 2019 at 8:19 PM
    zcarpenter92[QUOTED] and Rica25 like this.
  12. Sep 4, 2019 at 8:28 PM
    Rica25 likes this.
  13. Sep 4, 2019 at 8:28 PM
    Rica25
    Ricardo
    Tulare
    Sup Bro
  14. Sep 4, 2019 at 8:31 PM
    Spent half the day at court filing paperwork to get custody of my grandson. $225 filing fee. Other than that....a normal day in my life.
    Rica25[QUOTED] likes this.
  15. Sep 4, 2019 at 8:33 PM
    Rica25
    Ricardo
    Tulare
    Wow that must be a tough situation bro...hope every thing turns out well
  16. Sep 4, 2019 at 8:33 PM
    I like your new setup Ricardo!
  17. Sep 4, 2019 at 8:33 PM
    Rica25
    Ricardo
    Tulare
    Me to....see how it does off road
  18. Sep 4, 2019 at 8:34 PM
    It's all good!
  19. Sep 4, 2019 at 8:41 PM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    King 2.5 coilovers Nitto Exo Grapplers
    I say to keep the stock wheels; they'll fit a 285mm wide tire and if you mess one up they're always easy to find cheap replacements for.
    Rica25 likes this.
  20. Sep 5, 2019 at 10:10 PM
    ZE_TRUCK
    ZE_TRUCK Never ending build Always ending money
    2018 Tundra SR5 Sky Metallic
    king shock 3.0 Lift SS built bumper and third brake light 35" Toyo Open Country MT Black Rhino Arsenal Matte black 18” Nfab Side Steps Venom 250 Black widow muffler blacked out exhaust tip grabbinasshandles shifter LED Headlights LED interior lights LED Blinkers AFE Intake AFE Throttle spacer 32" Light bar Cali raised GG lighting Ditch lights 2 12” subwoofer box rear seat Upgraded all speakers 1200 watt kicker amp Locked off-road bump stops Kc hilites 3rd brake light
    I’m running 35x12.5x18 on king 3.0’s with LSK UCA’s. Both front and rear have adjusters
