Replace Tundra headlight bulb by removing Fender Liner
Discussion in 'General Tundra Discussion' started by CamaroSsToTundra, Sep 2, 2019.
  1. Sep 2, 2019 at 6:24 AM
    CamaroSsToTundra
    CamaroSsToTundra [OP] New Member
    Ohio
    2018 Tundra
    FCF0BA77-0228-4CBF-B9FA-7C9D12A4BA34.jpg I have been watching YouTube videos from last 2-3 months to learn how to replace headlights bulb. And they all talks about remove Grill and blah blah. I was not feeling comfortable to do that because of TSS sensor in grill. If you mess up with it then tons of lights turns on. Then I saw somebody comment to one of those videos about fender liner in owners manual. I checked the manual and it says you just need to remove Fender liner to replace headlight bulb. Finally I am going to replace my yellow headlight bulb and update you☺️
    Mountun Goat likes this.
  2. Sep 2, 2019 at 6:27 AM
    cmiller219
    cmiller219 New Member
    Nashville, TN
    2018 Cement CM Tundra
    Sounds like a great alternative. But just a heads up the TSS is pretty hard to mess up I have removed my grill and moved and unplugged my TSS and never had any issues. If people are they are dropping it or something crazy I would imagine.
    CamaroSsToTundra[OP] likes this.
  3. Sep 2, 2019 at 6:29 AM
    CamaroSsToTundra
    Ohio
    2018 Tundra
    Yes, i prefer to remove 4-5 screws and remove fender liner instead of removing grill and tons of other things before accessing to headlight.
  4. Sep 2, 2019 at 7:00 AM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Very easy to break. In fact a have the replacement piece sitting in my console after breaking one earlier this week. $40 CAD from the local dealer!
  5. Sep 2, 2019 at 1:02 PM
    Batel
    Batel New Member
    2019 Tundra SR5 TRD Offroad
    I just went through this with my 2019. I wanted to change side marker lights to LED and went with what the owners manual said, through the fender well. When I got to the right side I discovered what appears to be a filter system for the A.I.R. system blocking access. Neither me nor my wife could get to the plug. I could see it, just couldn't access it. I admit we're older and I have limited strength and feeling in my hands due to CMT. I put it back together and a couple of days later I pulled the grill and headlight. 35-40 minutes taking my time and it was done. I think going in through the grill is much easier access, although more fasteners and one plug to the sensor in the grill.
  6. Jul 10, 2024 at 5:32 AM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    Looks like i will be installing new bulbs this weekend.
    I previously tried the grill removal and that was a no-go.
    Couldnt get the grill to release, so i just paid a shop to it.
    Cant imagine its that difficult and i surely dont want to pay a shop to do it again.
  7. Jul 10, 2024 at 6:03 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    You can pull the grill and headlights and put it back together in less than 15 minutes.
    There is no way I'd blindly search, beat up my knuckles, and feel my way through that fender liner opening..
    2 screws and 2 clips, the grille pulls right off, don't be afraid of it.
    2 screws from the fender liner and a couple more clips removes the extension panel.
    2 screws on top and a side bolt pull the headlight out.
    Change your bulbs, I'd replace all of them, and put It back together..
    https://youtu.be/COmW6j2A1EU?si=BgZdo8gAS0WnriiP
    purplenova likes this.
  8. Jul 10, 2024 at 6:19 AM
    Reddawg1100
    Reddawg1100 New Member
    FL
    21 SR5 Midnight Black DC, AKA: Bat Truck
    Custom rims, front leveling spacers
    I just did the LED headlight swap and was a little aprehesive about removing the grill, etc. Turns out, it really isn't a big deal at all and the improved performance and appearance are well worth the small effort. Also took the opportunity to plastidip/spray can the chrome bumper ends as a trial before spending $$ on bumpershellz.
    1lowlife likes this.
  9. Jul 10, 2024 at 6:32 AM
    purplenova
    Tom
    Ohio
    Nice
    Reddawg1100[QUOTED] likes this.
  10. Jul 10, 2024 at 12:22 PM
    Cegraham
    Cegraham New Member
    North Carolina
    2020 Black Tundra SX
    Nice.... Where did you get your LED headlights from?
  11. Jul 10, 2024 at 1:40 PM
    Reddawg1100
    FL
    I was able to get a great deal on a used set from a sport trim through the marketplace on this site.
  12. Jul 14, 2024 at 12:42 PM
    purplenova
    Tom
    Ohio
    Thru the fender liner is a bunch of crap. Still couldn't reach the bulbs. Ended up pulling grill since I could easily reach the lower grill tabs and press them down. Grill popped right off. Changed out the fogs since one was out anyway. Good times...
    Reddawg1100 likes this.
  13. Sep 19, 2024 at 7:15 AM
    Ridgerunner607
    Ridgerunner607 New Member
    2015 Tundra TRD
    I just replaced both headlight bulbs on my 2015 Tundra TRD. For the first replacement I used the fender well access and it was a very tight fit to reach the bulb, remove the components and reassemble them. I was able to get it done but it was a PITA job. For the second one I removed the grill and side panel as shown in the video above. For me it was a way easier way to get to the headlights and if I had done this the first time I could have changed both at once. It's fairly easy to remove the parts with this video for a guide and then put it all back in place. All you need is a 10 mm socket and a small flat head screwdriver for tools. I don't have the TSS sensor so that probably made it a lot easier.
