Rear 1" lift that's cheapest and safe for 2005 4wd
Discussion in '1st Gen Tundras (2000-2006)' started by stevechumo, Aug 31, 2019.
  1. Aug 31, 2019 at 1:00 AM
    stevechumo
    stevechumo [OP] New Member
    I'm looking for 1" lift on the rear of my Tundra 4wd. Can you please share the options that's safe and doesn't break the bank? Maybe the links to the retailers will be helpful.
  2. Aug 31, 2019 at 1:06 AM
    SoCalPaul
    SoCalPaul New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
    I did the $159 add a leaf
  3. Aug 31, 2019 at 5:46 AM
    bajaphile
    bajaphile New Member
    Solana Beach, Ca
    2001 4x4 Limited
    Icon Coilovers, Icon AALs, JBA headers, 285/75r16 BFG KO2s
    I installed the Icon 1.5" AAL last month and its great. Ride feels the same (slightly "tighter").
    because_wumbo-truck likes this.
  4. Sep 4, 2019 at 10:12 PM
    allibubba
    allibubba New Member
    PDX
    2003 Access Cab & 2006 Double Cab
    Level kit 33's
    Blocks are super cheap, get them off Amazon with new U bolts for under $50. Easy to install, not the best option, AAL is better, but honestly the ride doesn't feel bad with blocks.
    revtune likes this.
  5. Sep 5, 2019 at 2:35 AM
    stevechumo
    Thanks for your inputs. I'll find the time to install them.
  6. Sep 8, 2019 at 5:02 AM
    SgtNewundies
    SgtNewundies New Member
    Eric
    I would look into shackle lift for the rear.
  7. Sep 8, 2019 at 5:19 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Gen 1 trucks use an upright shackle config. Cant lift them with shackles.
    The icon add a leaf pack is probably your best bet
    OR18TRD and because_wumbo-truck like this.
  8. Sep 8, 2019 at 5:19 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    :rolleyes:
    That would work great if the shackles weren’t inverted.
  9. Sep 8, 2019 at 9:23 AM
    because_wumbo-truck
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    I second this motion.
    The progressive 1.5 AAL is the.best bang for your buck. Just remove the factory overload leafs and replace with the AALs for 1.5 or leave the overload leafs for 2 inches.
  10. Sep 8, 2019 at 9:24 AM
    because_wumbo-truck
    Jon
    Houston, Texas
    First gens have inverted shackles...
  11. Sep 8, 2019 at 9:26 AM
    because_wumbo-truck
    Jon
    Houston, Texas
    I hate that. No idea why Toyota did this to us. The first gen tacos had normal shackles and.as far.as.i know so did all the previous trucks. But 2nd gen tacos on and 1st gen tundras got stuck with the dumbass inverted shackles. They're great if you wanna drop you truck for cheap lol
  12. Sep 8, 2019 at 1:18 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    I was surprised they changed it in the 07+.
    Not complaining though.
  13. Nov 11, 2019 at 11:11 PM
    stevechumo
    Can anyone please show some detailed pictures of your lift, where the new parts are, for the rear?
  14. Nov 12, 2019 at 5:47 AM
    revtune
    revtune New Member
    Dane
    Houston Texas
    2006 Tundra 4.7 AC 2wd
    2006 Tundra: Stock air intake 3 inch catback Magnaflow 13742 2.5 inch front lift 1.5 inch rear blocks 2014 sr5 4Runner wheels (17x7) 1.5 inch hub centric wheel spacers p285/70/17 Nitto Terra Grappler G2 Weathertech floor liners
  15. Nov 12, 2019 at 10:58 PM
    stevechumo
    Do you tow with your Tacoma? I read somewhere that it may cause axle wrap.
  16. Nov 12, 2019 at 11:44 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    It is true that blocks will amplify axle wrap.
  17. Nov 13, 2019 at 4:50 AM
    revtune
    revtune New Member
    Dane
    Houston Texas
    I’ve never had a problem with blocks. In my opinion your good up to a 2 inch block. Otherwise you’ll need the add a leaf or new leaf pack.
  18. Nov 13, 2019 at 4:54 AM
    revtune
    revtune New Member
    Dane
    Houston Texas
    I don’t tow with my Tacoma, but I carry between 300-400 pounds in the bed at all times. Never had any ill effects from the blocks.
  19. Nov 13, 2019 at 1:20 PM
    stevechumo
    When you add 1" block, do you have to change to longer shocks?
  20. Nov 13, 2019 at 2:27 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Many aftermarket shocks can handle an inch. Stock shocks could over extend at full droop
  21. Nov 13, 2019 at 4:09 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
  22. Nov 13, 2019 at 10:55 PM
    stevechumo
    Is it ok to use both 1" block and helper spring together?
  23. Nov 14, 2019 at 5:12 AM
    Fourknights
    Fourknights Goin Coastal
    Georgia/Florida
    2019 sr double cab 4x4 5.7
    Coverking ballistic seat covers, dipped 4x4 emblem, intermittent wiper mod, Toyota bed mat, Toyota rear under seat storage, dirty deeds budget, icon rebound 17”, bfg ko2s 285/70/17, matte black uws low profile toolbox, grill surround painted matte black
    I went with wheelers add a leaf, gave my 06 1.5”
  24. Dec 17, 2019 at 1:14 AM
    stevechumo
    I finally went with EZ Hellwig helper spring and new shocks. It raises the 0.5" for the rear, and the ride is smoother and seems more solid. So far so good.
