What do you TOW with your Tundra?
Discussion in 'Towing & Hauling' started by T-Rex266, Jan 29, 2014.
  1. Aug 15, 2019 at 7:17 PM
    #1501
    thearborbarber
    thearborbarber New Member
    SoDak
    2018 Tundra SR5
    You always have friends when you have a dump trailer
    Casper3, Watt maker and Prostar 190 like this.
  2. Aug 19, 2019 at 9:27 AM
    #1502
    HappyGilmore
    HappyGilmore Ex 1st Gen Member
    Trent
    Lakewood CA
    2018 White Limited TRD 4x4
    Headed to the Sierras. Borrowing my folks trailer.
    D3Tundra, Cement4WD, Casper3 and 8 others like this.
  3. Aug 21, 2019 at 7:52 PM
    #1503
    nuclearlemon
    nuclearlemon New Member
    wyoming
    2012 dc
    tundra is getting a lot of tow time in lately. the 20' enclosed trailer was very loaded and i've never seen my fuel gauge go down so quick. 20190805_065138.jpg 20190820_171318 (1).jpg 20190818_064322.jpg 20190810_174232.jpg
  4. Aug 21, 2019 at 10:35 PM
    #1504
    Patriot
    Patriot Member
    Western NC, “Boondocks”
    Our 2020 Intech Flyer Pursue ultralite camper -all aluminum frame, 1550# empty 2200# max loaded.
    In the elevations of the NC Blue Ridge Mountains.
  5. Aug 27, 2019 at 5:52 PM
    #1505
    Pariverpirate
    Pariverpirate New Member
    Rich
    2015 Tundra TRD Off Road
    Non yet
    Thinking of upgrading the camper now that I have the Tundra
  6. Aug 28, 2019 at 9:55 AM
    #1506
    nowayout
    nowayout New Member
    NY
    15 Dbl
    @WZ KTM do you have build sheet for this? It looks really nice.
  7. Aug 29, 2019 at 7:06 AM
    #1507
    mscribellito
    mscribellito New Member
    Michael
    2006 White Regular Cab Tundra
  8. Aug 29, 2019 at 8:54 AM
    #1508
    G2G
    G2G New Member
    Chicago
    2018 White Platinum Tundra
    New/used trailer I bought for motorcycle racing. 20190801_202600.jpg 20190801_202600.jpg
  9. Aug 29, 2019 at 9:08 AM
    #1509
    CourtJester
    CourtJester New Member
    Alabama
    2019 Tundra TRD Pro, 2015 Tacoma
    Scooter racing??? Who with? I raced with CCS for seven years. Stopped reversal years ago. I just tow around an R1 for street riding now.
  10. Aug 29, 2019 at 9:32 AM
    #1510
    G2G
    G2G New Member
    Chicago
    Did CCS/WERA for 10 years on big bikes the last 10 years I have been doing supermoto racing, one off races like Pikes Peak, and also AHRMA as they have a Motard class.
  11. Aug 29, 2019 at 8:45 PM
    #1511
    Misplaced Texan
    Misplaced Texan New Member
    VA
    '17 Silver Sky TSS 4*4 CrewMax
    I GOT PLANS!.... Implementation is another topic.
    I have a small TT and our big one we bought to live in for a few months when we moved
  12. Aug 29, 2019 at 8:46 PM
    #1512
    Misplaced Texan
    VA
    I have not got to pull this that often. Want to get it out more, been pretty chaotic since the move.
  13. Aug 29, 2019 at 8:51 PM
    #1513
    NR-J
    NR-J New Member
    Justin
    2015 white tundra
    I tow a custom offroad dump trailer made by a local fab shop called Knuckle Busters. We use it to remove trash from wilderness and recreation areas across Arizona.
    D3Tundra, superdenk, JH5370 and 12 others like this.
  14. Aug 30, 2019 at 4:36 PM
    #1514
    Patriot
    Patriot Member
  15. Aug 30, 2019 at 6:28 PM
    #1515
    CourtJester
    Alabama
    Working on painting the upper floor of the house. Damn thing’s heavy as shit. Managed well through the hills though.
  16. Aug 30, 2019 at 8:23 PM
    #1516
    Delta Pop
    Delta Pop New Member
    Northeast Wisconsin
    2019 White Tundra
    Tundra pulls this without breaking a sweat.
  17. Aug 31, 2019 at 4:06 AM
    #1517
    AnthonyC
    AnthonyC TAKE IT EASY WHILE YOU"RE GOING FAST
    Anthony
    Virginia Beach, VA
    2010 Tundra SR5 TRD DOUBLE CAB
    TRD DUAL EXHAUST, FIRESTONE AIR BAGS
    To all of you, THAT IS AWESOME!I love the video. I won't be towing anything quite that heavy, I ordered a 7X16 enclosed for my motorcycle/two 4 wheelers. I'll have the motorcycle and one 4 wheeler, or just the two 4 wheelers. I hope to pick the trailer up in two weeks. The trailer when finished will be in Willacoochee, Georgia. It's about 10 hours from the Virginia Beach,VA area. Not a big deal for me, I use to drive and repair the big trucks. I had the inside finished with the rubber coin flooring, ramp and all. The walls and ceiling are finished in white aluminum, easy to keep clean. I also ordered the Dexter torsion axles along with alloy wheels. I think it will be just fine.
  18. Aug 31, 2019 at 5:50 AM
    #1518
    Misplaced Texan
    VA
    Pulling the little Winnie drop is the same way, almost forget it is there....I have to remind myself when pulling it that I have a trailer behind me.
    AnthonyC likes this.
  19. Aug 31, 2019 at 6:19 AM
    #1519
    sea_weathered
    sea_weathered New Member
    Pacific Ocean
    2018 DC Adventure Chuck Wagon
  20. Aug 31, 2019 at 10:41 AM
    #1520
    Toyokuhl
    Toyokuhl New Member
    aaron
    SWFL
    2018 Cav Blue CM OR
    1983 starcraft islander all set up for big lake salmon. Only 300 hours on the motor
  21. Aug 31, 2019 at 2:05 PM
    #1521
    AnthonyC
    Anthony
    Virginia Beach, VA
    I'm not sure what your trailer weighs, a rule of thumb is. 10 to 15% of the trailer weight will be on your drawbar. 1,100 lbs sounds like an awful lot on the drawbar. Double check you calculations. A lot of folks tow with a 4X2, but a 4X4 is the way to go. Backing a trailer in on an incline can be tough at times, without that low gearing from the 4X4. The transmissions tend to get warmer much faster without low range. Always keep an eye on the transmission when maneuvering at a slow pace. There will be no difference between the two on the open road, other than the final gearing.
    Anthony C
  22. Sep 1, 2019 at 5:01 PM
    #1522
    Devi8
    Devi8 New Member
    Dave
    2017 crewmax limited
    Iron cross steps, weather techs, rain/big guards, access cover, tracrac with cantilever
    No there not, Pro just has soft ass suspension
  23. Sep 2, 2019 at 5:10 PM
    #1523
    ntg
    ntg New Member
    2016 TUNDRA TRD
    Topper, Drawer System / Bed Platform,
    I like the Airstream!!
    AnthonyC and Midway like this.
  24. Sep 4, 2019 at 3:35 PM
    #1524
    Tony v
    Tony v Member
    2017 SR5 CrewMax
    Cool trailer. What brand and model is that.
  25. Sep 4, 2019 at 3:46 PM
    #1525
    Tony v
    Tony v Member
    2017 SR5 CrewMax
    IMO, you should know your hitch weight before you commit, typically it will be between 10% to 15% of the trailer dry weight. Have you considered weather or not the trailer manufacturer has a light version or line up? Again, IMO you are pushing the weight limit and you may be able to find something similar in a lighter model. As an example, Take a look at the Highland Ridge Open Range Ultra light models
  26. Sep 4, 2019 at 3:50 PM
    #1526
    Delta Pop
    Northeast Wisconsin
    2019 White Tundra
    The Trailer is a TAB 400
  27. Sep 4, 2019 at 4:58 PM
    #1527
    ntg
    ntg New Member
    2016 TUNDRA TRD
    That looks AWESOME!.. So many adventures to be had with that thing! :cheers:
    - tundra looks good too btw
  28. Sep 4, 2019 at 5:23 PM
    #1528
    Tony v
    Tony v Member
    2017 SR5 CrewMax
  29. Sep 4, 2019 at 5:50 PM
    #1529
  30. Sep 4, 2019 at 5:57 PM
    #1530
    Jtundra81
    Jtundra81 Just a member
    Joe
    2019 cement tundra crewmax
    Tony v[QUOTED] likes this.
