12volts Plug & Play remote start groupbuy!
Discussion in 'Audio & Video' started by T-Rex266, Jul 31, 2019.
  1. Aug 24, 2019 at 3:40 PM
    #391
    Alaska
    Alaska New Member
    2017 Tundra TRD 4x4 ~Quicksand~
    Baja Designs Squadron WC fogs
    Quoting my own stupidity... I was hitting the button too fast. 3 slow locks and it started. 3 more and it will shutoff. The doors stay locked on mine when I turn it on. I DO have the factory alarm but WITH OUT the glass break sensor. Everything was plug and play! Thanks James!
    TheBeast likes this.
  2. Aug 24, 2019 at 3:53 PM
    #392
    TheBeast
    TheBeast The Beach
    yeah it says 3 times for locking so it should do what it is designed for imo.
  3. Aug 24, 2019 at 6:33 PM
    #393
    nowayout
    nowayout New Member
    NY
    15 Dbl
    Does this work if you hold the lock button down for a few seconds? You know instead of pressing it 3 times.
  4. Aug 24, 2019 at 7:05 PM
    #394
    AZTundra
    Paul
    Phoenix, AZ
    Installed and working correctly aside from a small issue with the app for the carlink. I'm trying to figure that out here shortly. Just ran out to grab some pizza and wings. Oh yeah, and this too....I deserve it after 108 temp or whatever it was this afternoon during the install.
  5. Aug 24, 2019 at 7:09 PM
    #395
    AZTundra
    Paul
    Phoenix, AZ
    Here's some pics of the module installed. I tucked it in the back and zip ties to two holes that were almost a perfect fit for the module. The carlink was installed flat right above the air bag.
    20190824_180651.jpg 20190824_180631.jpg 20190824_180641.jpg 20190824_181100.jpg
  6. Aug 24, 2019 at 7:20 PM
    #396
    paradox2311
    paradox2311 New Member
    Pretty easy install! Had to email James and instantly he told me what to do. Tech12volts gets 2 thumbs up for excellent customer service
  7. Aug 24, 2019 at 7:26 PM
    #397
    teamtlr
    teamtlr New Member
    Denver Colorado
    2020 Sequoia TRD Pro
    Is anyone getting the horn honking after pressing the key fob 3 times? Mine is acting very inconsistent and seems like the 3 presses is very sensitive.
    Can you just hold down one button instead?
  8. Aug 24, 2019 at 7:38 PM
    #398
    biebs96
    PA
    Mine does and it is a fortin “brain” as well.
    nowayout[QUOTED] likes this.
  9. Aug 24, 2019 at 8:22 PM
    #399
    Pbear1454
    Pbear1454 New Member
    NorCal and SoCal
    2010 Tundra TRD
    Bilsteins SPC RCI Steel Bumpers
    Looks like you were anxious to install no matter how hot it got
    AZTundra[QUOTED] likes this.
  10. Aug 24, 2019 at 8:51 PM
    #400
    AZTundra
    Paul
    Phoenix, AZ
    It's not cooling off anytime soon, but at least my truck will be cool now. :yes:
    Pbear1454[QUOTED] and jewsNbrews like this.
  11. Aug 24, 2019 at 8:53 PM
    #401
    AZTundra
    Paul
    Phoenix, AZ
    So I just emailed james. I was able to get past the issue I had with the carlink app and put it in test mode. I tried lock, unlock, and starting the truck from the app which worked perfectly. I then stopped the truck through the app and the factory alarm started to go off. Not sure how to solve that one. Any ideas?
    Edit: James said I'll need to connect the black/white wire to correct this.
    Yep connect the white/black stripe wire. Your factory alarm is being set off ad it thinks the truck is timing out
    I'll try this in the morning, otherwise all is good!
  12. Aug 24, 2019 at 9:47 PM
    #402
    J.A.T.O.
    J.A.T.O. New Member
    Hawaii
    2013 Tundra SR5 Crewmax 4x4
    Bud Built skid plates, Fox TRD Pro suspension, Nitto terra grapplers
    I’m in the the middle of install and my 2013 is DOA.
    Why do the instructions refer to plug “5” when there’s no plug for it!(second pic)
  13. Aug 24, 2019 at 9:50 PM
    #403
    YsoSeRiouS!
    YsoSeRiouS! A good day...for a good day
    NorCaL
    2019 White Platinum CM
    I wish I could help but my year is different and has different instructions but it looks like it has the same pins as the module
    J.A.T.O.[QUOTED] likes this.
  14. Aug 24, 2019 at 10:00 PM
    #404
    J.A.T.O.
    J.A.T.O. New Member
    Hawaii
    Thank you! That makes sense on pic #1.
    Any idea why the instructions refer to “plug 5” on the BCM in the second pic?
  15. Aug 24, 2019 at 10:06 PM
    #405
    AZTundra
    Paul
    Phoenix, AZ
    Plug 5 is where the black/white wire for the key sense would connect, although most will not need to do this.
  16. Aug 24, 2019 at 10:08 PM
    #406
    J.A.T.O.
    J.A.T.O. New Member
    Hawaii
    Thank you! So assume I leave this plug alone?
  17. Aug 24, 2019 at 10:11 PM
    #407
    AZTundra
    Paul
    Phoenix, AZ
    Correct. You wont need this connection. Also, I believe the other question was answered regarding the other plug. That plug should connect into the remote start module.
  18. Aug 24, 2019 at 10:13 PM
    #408
    J.A.T.O.
    J.A.T.O. New Member
    Hawaii
    You guys are a lifesaver!
    Swing by Hawaii and I’ll buy you a beer or 10!!
  19. Aug 24, 2019 at 10:45 PM
    #409
    TheBeast
    TheBeast The Beach
    I will install mine on my 2012 tomorrow so I will see where it goes ...or not...;)
  20. Aug 24, 2019 at 11:37 PM
    #410
    YsoSeRiouS!
    NorCaL
    Hmm...man I wish I could help if I had the same year. Since I have different instructions I don’t want to give you wrong info
  21. Aug 25, 2019 at 1:02 AM
    #411
    J.A.T.O.
    J.A.T.O. New Member
    Hawaii
    I gave it one last try and I finally got a flashing blue light...
    However, my truck will crank for about 5 seconds without starting then it shuts down. Then it tries again, over and over multiple times. I couldn’t stop it.
    I tried pressing every button on the remote to stop it and I also pressed the brake pedal and cycled the key in the ignition multiple times with no luck.
    The truck seamed possessed.
    I took a video because I knew no one would believe me.
  22. Aug 25, 2019 at 8:32 AM
    #412
    Alaska
    Alaska New Member
    That looks like the Main plug that goes into the module unit.
  23. Aug 25, 2019 at 9:14 AM
    #413
    Alaska
    Alaska New Member
    I attached my module to a metal frame, left of the wiring harnesses and below the air vents with 3M adhesive backed strong Velcro. There is clearance in the back for the wires and no issues when reinstalling the dash. The remaining wires were tucked up and under the dash and secured with zip ties.
    jewsNbrews and AZTundra like this.
  24. Aug 25, 2019 at 9:33 AM
    #414
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    Email James and let him. He is super helpful.
    To me sounds like module is not taking the encryption from you key during programing.
  25. Aug 25, 2019 at 9:59 AM
    #415
    TheBeast
    TheBeast The Beach
    from James email: (I have a 2012)
    You will see a White with black stripe wire in the diagram also. This is the key sense wire and you do not need it all. make sure all connections are made with battery disconnected and before you hook the battery back up remove all connectors from the remote start unit . if you ordered 2 way remotes or the MYCAR option do not program or plug them in until you have the remote start working with the factory key fobs .
    Make sure when your programming it that you get the correct color lights and be quick with programming as you can time out . If that happens start over. if you do not get the correct the lights on the 2nd try CHECK YOUR WIRING . do not try to install from video only. use video and the wiring diagram together
    If you need help call me 912 288 5875
  26. Aug 25, 2019 at 11:03 AM
    #416
    Jwood562
    Jwood562 New Member
    2013 Tundra 4x4
    King 2.5s custom gold rock warrior wheels 2020 sequoia LED headlights
    So it looks like the price is still good for $200.
    I want to place my order ASAP but have a quick question about the extended range remotes.
    Do the extended range remotes replace the factory key fob? Like it will lock and unlock my doors or do I have to carry both remotes.
    2013 BTW
  27. Aug 25, 2019 at 11:05 AM
    #417
    AZTundra
    Paul
    Phoenix, AZ
  28. Aug 25, 2019 at 11:36 AM
    #418
    TheBeast
    TheBeast The Beach
    Quick install. got mine done in 45 min and all plug and play. I don't have factory alarm.
    2012 Tundra. 3 press on lock will start truck and lock doors 5 to 10 sec after. This is nice and now I look like the cool guys with new trucks ;)
    AZTundra and jewsNbrews like this.
  29. Aug 25, 2019 at 11:37 AM
    #419
    paradizecityz
    paradizecityz New Member
    Richmond, TX
    2022 Tundra TRD Off Road
    Just did mine as well. Took about 35 min. Longest part was the TPMS splicing but I’m also getting the issue where it doesn’t lock after starting. Did someone get a fix for that?
  30. Aug 25, 2019 at 12:07 PM
    #420
    chinadog
    chinadog New Member
    Knoxvegas
    2018 Midnight Black Metallic 1794, 2013 Black Platinum
    Did the install on my 2018 1794. Read through the instructions and went through the video a couple of times. I got to the point where I had to connect the ground and I didn't have a long 10mm socket, so off to home depot I went. There's a joke in there somewhere.
    Anyway, got everything connected, did the splice and tried it. Here's what happens.
    1. Vehicle unlocks the door (expected).
    2. Starts the truck.
    3. Does not look the truck. Now, this is not a big deal to me since I'd doing the regular key fob thing, not the long distance options.
    4. When I get in the truck and put the key in, it does not recognize the key to telescope.
    5. Turn the key to ignition, hit the pedal and remains on. Steering wheel still no telescoped. I have to shut off the truck, but the key and restart.
    Anyone else have the same issue? I'll shoot an email to James, but wanted to check her first.
    The only thing I didn't do during the isntall, was have the red/white, green/white wires (red) connector connected to the Fortin box when I programmed it. I left it off because I wanted to twist it up, The programming went fine, but in James instructions is says "Insert remains connectors" before you click the button ten times. Granted these just had the two wires gangling off the connecter to be spited later. Not sure if that makes a difference and may try it again later (trucks back together already).
    Edit: Now that I think about it, after I did the red/blue step and release, I might have done the 10 times push before connecting any of the connectors. Can't recall. Guess I'll have to try it again.
