Suggestions for airbag suspension systems
Discussion in 'Suspension' started by Jlb04, Feb 11, 2018.
  1. Mar 7, 2019 at 4:29 PM
    Markman
    Markman New Member
    Mark
    Utah
    2019 limited cement cm
    Tint airbags daystar cradles Elka suspension bushwacker flares
    I installed the airlift bags and the wireless one compressor helped a lot with heavy loads. Only problem the truck rode much stiffer in the rear installed the daystar cradles which helped a bunch.
    monaco730 likes this.
  2. Mar 24, 2019 at 2:11 PM
    jtdunc
    jtdunc New Member
    2014 Tundra Double Cab - Magnetic Gray
    Okay, I'm going to install some Firestone Ride-Rite air bags on my Tundra. Towing a 22' travel trailer. Loaded @ 5,500 lbs.
    My Tundra is my occasional commuter and my towing rig for that trailer. No lift kit on my Tundra.
    Not 4-wheeling with this rig. Only tame fire roads in the PNW.
    Will the DayStar cradles offer me any real benefit?
  3. Mar 27, 2019 at 6:55 PM
    Markman
    Markman New Member
    Mark
    Utah
    I would install them for the cheap price and the improved ride quality I believe it's worth doing
  4. Aug 17, 2019 at 11:22 PM
    AndyRodagin
    AndyRodagin New Member
    2016 Tundra Crew Cab
    Timbren
    So glad to have found this group. Got a 2016 Tundra Crew Cab in April and Lance 650 camper and have horrible time with back and forward rocking (some call porpoising). I'm looking for a scale to find out the weight to see if I blew it and overloaded this rig but Lance and Toyota reps assured me this would be a good fit. Maybe just salesmen sweet talking me.... So I'm reading good things about the Firestone Ride Rite with Daystar cradle but I didn't see anyone claiming the same problem as me as the reason and solution for that purchase. Any and all credible input appreciated.
    BTW lots of people on a generic truck camper forum thought I was talking about sectioned highway with regularly spaced expansion joints but I haven't even come across that situation. My problem is almost continuous with typical road unevenness. A larger bump actually sent the cabover down onto the cab roof! THAT's some rockin' and rollin'.
  5. Aug 18, 2019 at 8:47 PM
    Joek
    Joek New Member
    Joe
    San Rafael
    2018 TRD
    I went with the airlift set up with the internal bump stops. Stock truck and run 0psi when not towing. I don't have any ride quality issues but consensus here is to go the other route. I run 50psi when towing a 7k trailer. Whichever way you go it's a must on stock springs.
    Rebel Tundra Man likes this.
  6. Aug 20, 2019 at 12:41 PM
    Corr2626
    Corr2626 New Member
    Corey
    2014 Tundra Limited
    Looking for advice on where to start in terms of PSI in my bags. Picking up my first trailer tonight and curious to what some of yall would recommend. I'm thinking 40 but maybe 50 since the trailer is on the heavier side and I have a 4.5 lift, so not stock. Also, I should start with the air before doing my WDH set up right? TIA
  7. Aug 21, 2019 at 7:02 AM
    Joek
    Joek New Member
    Joe
    San Rafael
    2018 TRD
    Hook the trailer up and add air till it's running level. Then set the bars.
  8. Aug 21, 2019 at 8:26 AM
    TorinWallace
    TorinWallace Yota Addict
    2020 TRD Pro, DoubleCab, Army Green.
    CB Shim + Shackles | 305/70r18 KO2's | 18" Method NV's | Firestone Airbags | Tow Mirrors | Marlon Sleddeck | Spyder smoked taillights.
    As many other have said, get the Firestone’s over the airlift’s.
    I’ve tried both, Firestone is superior in ride quality.
    I use them religiously for both trailering and for hauling my snowmobiles. I run the airlift wireless one compressor, it’s fairly cheap and gets the job done for me.
  9. Sep 7, 2019 at 10:58 AM
    nautiqueguy
    nautiqueguy New Member
    Aaron
    2017 Cement TRD Pro
    2019 OEM LED headlights 295/70-18 Nitto Ridge Grapplers
    I love your stance. What tire size are you running? Obviously spacers, what size? And what additional lift?
    Tia
  10. Sep 10, 2019 at 3:57 AM
    TorinWallace
    Thanks man. Running 285/75/18 Duratracs with 2" spacers. Lift wise just running two CB shims on either side up front, and CB +2" shackles in the rear.
    nautiqueguy[QUOTED] likes this.
  11. Sep 10, 2019 at 5:01 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I installed them on my lifted T100 for towing and hauling heavy loads, and I installed them on my lowered '07 Tundra to keep the bottom of the bed from striking the drive-shaft when carrying a heavy load. The remote air control is a great add-on, if for no other reason because the bags will contract overnight when temperatures drop.
  12. Sep 10, 2019 at 5:07 AM
    Fiesta346
    Fiesta346 New Member
    PA
    2013 Rock Warrior
    Air lift
    Rex Kramer likes this.
  13. Oct 1, 2020 at 7:49 PM
    garrambide
    garrambide New Member
    2010 Tundra
    none
    I had 2007 dbl cab with 6’ bed. I filled the bed with misc stuff an ARE commercial AL. cap and towed a heavily loaded trailer cross country. After about 2 days driving straight with that load the truck had a permanent squat to it. I traded it in for a 2013 4x4 dbl cab long bed. The first thing I did was install the Firestone air bags. I have not regretted it at all and they are going on 4 plus years. And multiple trips cross country 2400 miles one way. With no sagging at all. I had limited tools and still was able to install them with the help of my Son.
  14. Jun 15, 2021 at 6:33 AM
    COelkhunter84
    COelkhunter84 New Member
    What is your lift & wheel/tire setup? looks great!
    monaco730[QUOTED] likes this.
  15. Jun 15, 2021 at 6:38 AM
    monaco730
    monaco730 New Member
    16 Inferno Tundra
    Fox shocks, TRD Exhaust, TRD grill, TRD shift knob, weathertech floor/bed liners, ARE topper, FrontRunnerOutfitters cargo rack, Relentless cargo bars, color matched front bumper/side mirrors, fuel wheels, nitto RGs, K&N intake
    Thanks! 295/70/18 ridge grapplers. +20 fuel vectors. 2.5" fox coilovers in front. 2" fox reservoir in rear. firestone bags. 2" shackles.
  16. Jun 15, 2021 at 6:41 AM
    COelkhunter84
    No major rubbing issues with 295s on a 2.5" lift? or do you have shims on top?
  17. Jun 15, 2021 at 6:59 AM
    monaco730
    16 Inferno Tundra
    Not a 2.5" lift. 2.5" diameter shocks in front, 2.0" diameter shocks in rear. Lift is roughly 3.5 in front and idk what rear is. I had rubbing in front. Removed mud flaps in front and cut the black trim on inside of front bumper end cover
    COelkhunter84[QUOTED] likes this.
  18. Jun 17, 2021 at 7:24 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    This is not the correct method for setting up a WD hitch system.
    set trailer level, unhooked.
    Measure top of coupler height.
    Set bags (if you have them) to level truck without trailer attached.
    adjust hitch (not the airbags) so top of ball is same height as the top of coupler.
    Measure front fender height from ground.
    Hook up trailer, without WD bars. measure front fender again.
    attach WD bars and measure front again. front should come back down to at least half way to unloaded height.
    mid it doesn’t come most of the way back down, put more tension on the bars by either raising the trailer end of them via bracket adjustment or by adding more spacers to alter the hitch head (and bars) angle.
    reattach bars and check front fender measurement again.
    Repeat till you get it set. Do not adjust your airbags after this, as moving the rear of the truck up will reduce the amount of torque on the bars and decrease the amount of weight being redistributed to the front axle and trailer axles.
    To make that a lot shorter, if set up correctly, a WD system doesn’t benefit from bags. It’s just important to do all of the setup with the trailer and truck loaded as it will be when you head out to camp.
    that said, you can certainly run both together, but need to recognize how one system affects the other!
    now, in response to the OP, I love my Firestones with Daystar cradles, and use an Airlift Wireless One compressor system to air up/down. Fantastic system.
  19. Jun 21, 2021 at 4:36 AM
    jeller75
    jeller75 New Member
    Joshua
    NC Mountains
    2017 CC Platinum Pro 4wd
    It seems like you've been down this road already but I'm trying to fully understand this before moving ahead. I'm currently running a 2.5-inch spacer lift in the front and a 1-inch Eibach block in the rear. We just purchased a 23-foot travel trailer roughly 5000lbs loaded and as such I am now in the market for firestone air bags to provide a level and better ride along with better control. I already have a weight distribution hitch which helps but it needs more attention for sure. It appears that I'll need to leave the 1-inch blocks and add the air bags and possibly the daystar cradles for the best combo? Or do I need to remove the blocks and level with the air bags/cradles? I'm not really sure they're designed for that or which option to choose.
    Anyway, forgive me if I'm missing something or just not reading deep enough.
    Thanks for any advice and sharing your experience with a newbie to airbags.
  20. Jul 29, 2021 at 6:31 PM
    #50
    Fyshhead
    Fyshhead New Member
    Mark
    Folsom
    2021 Tundra Limited MGM TRD Off Road DC
    Vehicle Modifications:
    Ok, it’s talked about but need to clarify. My 21’ is sagging due to truck shell and decked system. I put the 6112’s up front set at 1.9” and now leaning towards the Firestone ride rites with the day star cradle. I will be getting a potential travel trailer as well. Just to clarify, I do not want a rough ride in rear end such as add a leaf ..etc. Will the rear of my truck be rough riding with just the ride rites set to keep truck level not towing? I will also be adding the bilstein 5100 or 5160 to the rear
  21. Aug 22, 2021 at 11:53 AM
    #51
    Mediumrarepls
    Mediumrarepls New Member
    2019 Tundra SR5 TRD Offroad Crewmax Quicksand 4x4 5.7
    Resurrecting this old thread. I'm curious if you still had full articulation with the pro shocks and airbags. Thx
  22. Aug 22, 2021 at 12:43 PM
    #52
    anthonygan
    anthonygan New Member
    2017 Cement TRD PRO
    7in BDS lift, Spyder Smoked Taillights,
    I have a 7 inch lift on my truck! What’s the best way to run air bags with this setup? I’m guessing I’ll need a spacer of some sort? Thanks
  23. Aug 22, 2021 at 12:50 PM
    #53
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    What kind of lift do you have in the back? Lift blocks are going to cause a ton of spring wrap when towing. Consider ladder bars or roadmaster active suspension
  24. Aug 22, 2021 at 12:54 PM
    #54
    anthonygan
    2017 Cement TRD PRO
    I actually don’t have any lift blocks! I’m using an icon RTX leaf pack, while cb +3 shackles.
    Hbjeff[QUOTED] likes this.
  25. Aug 22, 2021 at 12:55 PM
    #55
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    nice setup. Call icon and make sure those longer shackles are safe with their springs, under flex you could invert them
  26. Aug 22, 2021 at 1:00 PM
    #56
    anthonygan
    2017 Cement TRD PRO
    I didn’t even think about that okay thanks! I think I have noticed under a heavy load 6k trailer it definitely puts a lot of strain on them.
  27. Aug 23, 2021 at 6:02 AM
    #57
    TRDProLife
    TRDProLife LETS GO BLUES
    St.Louis
    Barcelona Red Metallic TRD Pro Tundra
    Window Tint, ICI Magnum Steps, firestone spring helpers for towing, 295/70R18 Atturo Trsil blade X/T's
    Yes, that was the entire point behind this choice. I did not want to change the way my truck drove when not towing.
  28. Mar 30, 2024 at 5:33 AM
    #58
    MikeComo
    MikeComo New Member
    2019 SR5 Tundra
    Stock + Leer Cap
    Im also looking into Firestones for my tundra but I cant help but look at the knock off air bag systems. Firestones are $699cnd and the off brands are $250cnd. All the hard wear and brackets appear to be identical and the airbags look to be the exact same minus a sticker.
    Has anyone tried the off brand air bags?
  29. Mar 30, 2024 at 5:54 AM
    #59
    bgdv1
    bgdv1 New Member
    Dave
    Butler,Pa
    2019 Limited CMSB
