Clunk Noise at Low Speeds
Discussion in '1st Gen Tundras (2000-2006)' started by simonmiles, Aug 16, 2019.
  1. Aug 16, 2019 at 6:27 PM
    simonmiles
    simonmiles [OP] New Member
    This is something that worked for me for those who might have a clunk or creaking noise when stopping, accelerating from a stop or turning at low speeds. I replaced some front suspension components mainly because it needed it anyway but also hoping that this noise would be taken care of. Unfortunately it did not. I found a TSB 0067-09 from 2009 that supposedly helps with this. Lo and behold all it took were 4 bolts to fix a problem that had plagued me for 1.5 years. I guess the original bolts that joined the rear transmission mount and the frame crossmember had fallen out as all 4 were missing.
    I know this is probably old news for most but I thought it might help someone who overlooked this TSB. It seems to only apply to 2005-2006 2WD Tundras and 2005-2007 2WD Sequoias.20190816_194815.jpg 20190816_194913.jpg 20190816_195503.jpg
    bmf4069, georgiey22 and FirstGenVol like this.
  2. Aug 16, 2019 at 7:15 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    And all you were experiencing was a clunk?
    Wow.
    I had one single bolt come out from the bottom once on my 99 Tacoma. The other 3 had just started working their way loose. Didn't notice any strange driving conditions. Then again my Tacoma makes too many other sounds and feels so who knows.
  3. Aug 16, 2019 at 7:20 PM
    simonmiles
    Actually most of the time it was just a groaning or creaking noise when I would accelerate from a dead stop. Never heard it during normal driving once I was in motion. I've read from others that there would be loud popping sounds during acceleration or going over bumps. It drove me crazy anyway and all it took were 4 bolts. Just glad the noise is gone. :)
  4. Oct 29, 2021 at 5:45 PM
    tesnus
    tesnus New Member
    2006 Tundra
    This seems to have worked for me as well! I just checked my Tundra and all four bolts were in place but loose. Once they were tightened, I took it for a drive and the clunking noise I’ve heard for months has vanished!
    Desert Dog and bmf4069 like this.
  5. Dec 15, 2022 at 4:44 PM
    Jordanhorne
    Jordanhorne New Member
    Radiator, thermostat, spark plugs, ignition coils
    What kind of bolts did you need to do this? I’ve been dealing with the dreaded clunk at low speeds (found the TSB article too) and yep, all 4 bolts are missing.
  6. Dec 15, 2022 at 5:39 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Pull up the TSB it includes part numbers for the cross member and the bolts I believe.
  7. Dec 15, 2022 at 5:42 PM
    artsr2002
    'Yonder
    Here you go. From the TSB.
    Bolt w/Washer (P/N 90119-08895)
  8. Dec 15, 2022 at 5:54 PM
    Jordanhorne
    Gotcha, thanks
    artsr2002 likes this.
  9. Dec 15, 2022 at 7:52 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Don't forget the blue loctite.
    Jordanhorne[QUOTED] likes this.
  10. Dec 15, 2022 at 8:03 PM
    artsr2002
    'Yonder
    This
  11. Dec 29, 2022 at 8:47 AM
    AV8R4AA
    AV8R4AA New Member
    Greg
    Justin Texas
    2005 Tundra XSP
    Thank you so much.
    I am having the exact problem. Found out my 4 bolts were not tightened up.
  12. Dec 29, 2022 at 10:38 AM
    Double-check your crossmember carefully for hairline cracks.
    2006Tundra likes this.
  13. Dec 29, 2022 at 1:34 PM
    AV8R4AA
    AV8R4AA New Member
    Greg
    Justin Texas
    2005 Tundra XSP
    My cross member has 1 crack. My regular shop has a welder. They are going to fix it.
    shifty` likes this.
  14. Dec 29, 2022 at 6:25 PM
    2006Tundra
    2006Tundra Financially Irresponsible
    Lou
    Long Beach, CA
    2006 Toyota Tundra Double Cab SR5, 4.7L V8
  15. Jan 3, 2023 at 3:42 PM
    Jordanhorne
    Put the bolts on, no more clunk. Oh and a happy wife. Thanks again
  16. Jan 3, 2023 at 4:13 PM
    AV8R4AA
    AV8R4AA New Member
    Greg
    Justin Texas
    2005 Tundra XSP
    As with the other Tundramen, I’m all fixed up now. With 4 new Sachs shocks, no more clunking.
    Totally new ride. Even my Wife said: night and day difference.
