SMART THERMOSTATS
Discussion in 'Off-Topic Discussion' started by 2010bigdog, Aug 10, 2019.
  1. Aug 10, 2019 at 1:49 PM
    2010bigdog
    2010bigdog [OP] New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
    Looking in to getting a new smart thermostat this week and was wondering what members on here have and a little feedback if possible. I have a Ecobee 3 now and don't really care for it .
    Thanks in advance!!
  2. Aug 10, 2019 at 2:03 PM
    Capt J-Rod
    Capt J-Rod New Member
    Ohio
    2018 Cement TRD Off Road Crew Max SR5 Tundra
    Husky Floor Mats, Diamond back lid, Coverking seat covers, More gas.
    I have run a nest for over 5 years with no complaints... What type of system do you have. It helps to know if it is multi stage or a dual fuel system, like a gas forced air furnace with a heat pump...
  3. Aug 10, 2019 at 2:05 PM
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
    Forced air
  4. Aug 10, 2019 at 2:16 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Been using an Emerson Sensi for 4 years now. It’s not as “smart” as others, but it also isn’t as finicky. It gives me plenty programming options and remote management. That’s all I need it to do haha
  5. Aug 10, 2019 at 2:52 PM
    Mike Tread lightly.
    south carolina
    2003 tundra sr5 4x4 stepside....
    yep bank account is running low from it..
    Ecobee4 here two of them..
    I had the ecobee3 really no problems with it..
    Stay away from nest thermostat unless they have changed the board it will dead short out.
    ColoradoTJ likes this.
  6. Aug 10, 2019 at 3:04 PM
    Fishman57
    Fishman57 New Member
    Wayne
    Bucks County, PA
    I have a Honeywell smart thermostat. Works great. Long battery life.
    YardBird and AZTundra like this.
  7. Aug 10, 2019 at 3:04 PM
    iHacker
    iHacker SW TRD PRO
    Mario
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    I recommend you the Nest 3rd gen but make sure to install it properly that includes adding the C wire if not present to avoid any damage to your main board.
    Most system Or installers leave the C wire tucked into the wire harness and not being used and is just a matter of attaching both sides of the wire and your are done.
  8. Aug 10, 2019 at 6:37 PM
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
    I was looking at that one actually
  9. Aug 10, 2019 at 6:39 PM
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
    It seems like my ecobee3 short cycles and also freezes up a bit
  10. Aug 10, 2019 at 6:39 PM
    Jpneely
    Jpneely New Member
    White SR5 5.7
    check with your electric company, some give rebates and discounts on them. ours gives a free Ecobee 4 and 3 $50 credits on separate bills to switch to smart thermostats through them.
  11. Aug 10, 2019 at 6:48 PM
    BigLoggerhead
    BigLoggerhead New Member
    North Shore of Pontchartrain
    2019 Cavalry Blue Crewmax 4x4 TSS package
    Nest all the way. I’ve had 2 of them, a second gen in my old house and a third gen in my new one. Both performed flawlessly. They’re customer support for wiring is great if you need it.
    Capt J-Rod and Trunk Monkey like this.
  12. Aug 10, 2019 at 6:50 PM
    bsktball55
    bsktball55 New Member
    Missouri
    16 Tundra TRD Pro
    Bakflip MX4 Toneau cover Esp storage Audio system (Helix speakers, JL audio amp and sub) Front windows and windshield tinted LED interior and bed lights
    Just installed one of these a couple months ago. So far it's been nice, but don't have any long term usage on it yet.
  13. Aug 10, 2019 at 6:55 PM
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
    Sometimes on my Ecobee for example I will have it set to 72 in the winter and it will feel cold so I will go look at the thermostat and it will say it’s 72 so at that point I will turn it to 73 (one degree higher) and it will kick on then I check the actual reading a minute later and it says it’s 69 degrees and it will run to the 73 degrees I set it at and it’s warm. It does it all the time so something is wrong with it.
  14. Aug 10, 2019 at 7:36 PM
    TheGreyTundra28
    TheGreyTundra28 New Member
    2018 Grey Tundra Sport
    Dirty Deeds 10 budget exhaust, Roof rack, 52" windshield, Truxedo Tonneau, and Line x Bedliner
    I'm a service tech and have seen most thermostats out. Everything out there has pros and cons, if it was my choice honestly I'd stick with a Honeywell wifi T6. It's got all the functionality of the others for the most part and will out last 7/10 competitors hands down if not more.
    nvrgvup444 and TomC843 like this.
  15. Aug 10, 2019 at 7:38 PM
    TheGreyTundra28
    Also as noted before its programmable for different furnace types. Single and variable stages. heat pump or reg. condenser.
  16. Aug 10, 2019 at 7:40 PM
    gm125800
    gm125800 New Member
    2018 GMC Sierra Denali
    Ecobee or Honeywell. Half of the Nests which I installed had to be pulled. Most manufacturers have their own rebranded ones as well.
    nvrgvup444 likes this.
  17. Aug 10, 2019 at 7:55 PM
    TomC843
    TomC843 The wheel weaves as the wheel wills.
    Tom
    Charleston, SC
    16, 4X4, 4U3, Katzkins, Flowmaster, ARE MX, Swing cases, TRD skid plate, Volant CAI....
    Also a service tech and I recommend people stop f-ing around with their Tstats. Set it and leave it alone. proven long ago that if you are not gone for over 24 hours that its is not worth changing the temps up and down all day. I have TWO digital NON-PROGRAMMABLE t'stats in my house. Probably twice a month one of my guys is wiring in a standard tstat and placing in the return on a commercial RTU because the wifi tstat has shit the bed.
  18. Aug 10, 2019 at 7:56 PM
    BuckWallace
    BuckWallace Ball don't lie.
    Oregon
    Sierra 3500 AT4 L8T
    Just curious, what don't you like about your Ecobee?
  19. Aug 10, 2019 at 8:07 PM
    AKJ78
    AKJ78 New Member
    Aaron
    San Diego
    2016 Silver Platinum 4X4
    3/1.5 lift. TRD sway bar. Bakflip V1 cover. Fuel wheels w/BFG A/T.
    I love the Nest! It was almost free with the rebate my local power company offered. My favorite feature is that I can monitor temps in every room. And I can set the thermostat for any room I choose, not just at the thermostat itself. Through the app I have full control at home and anywhere I go. F76E3620-300E-4AD8-9816-EED070EE6C7A.jpg
    iHacker and BigLoggerhead like this.
  20. Aug 10, 2019 at 8:44 PM
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
    Post #13
  21. Aug 10, 2019 at 9:00 PM
    nvrgvup444
    nvrgvup444 New Member
    KCMO
    2015 Dbl Cab Limited - Blue Ribbon
    Bilstein 5100 all corners, Toytech Shackles, Nitto Ridge Grapplers, Completely new sound system that sounds great but didn't cost an arm and leg, front camera, front receiver hitch
    HVAC tech/teacher here also. I recommend Honeywell all the way. Too many times the electric company or the "Nest" thermostat will try to "learn" and after a long hot day of work you come home to a system that can't catch up. You can change it a few degrees using an app, but I agree with the above tech. Set it and forget it. Your HVAC system conditions your entire house - walls, floors, furniture, air, etc.
    TomC843 likes this.
  22. Aug 10, 2019 at 9:45 PM
    AKJ78
    AKJ78 New Member
    Aaron
    San Diego
    You can turn off the “learn” function of the Nest. You can set it and forget it if you’re into “dumb” thermostats. So really, it’s the most versatile option out there.
    iHacker likes this.
  23. Aug 10, 2019 at 9:55 PM
    TomC843
    Tom
    Charleston, SC
    100 likes. 30 years of different gizmos and gadgets on HVAC. Ask me what I got, single stage heat pump (no gas avail) with a scroll compressor. Mine breaks I can fix today. Your 18 seer woop de doo unit breaks I am ordering parts or retrofitting an old style part to get you running. Just like our trucks, KISS.
  24. Aug 10, 2019 at 10:05 PM
    TomC843
    Tom
    Charleston, SC
    Says the guy that dosn't have to deal with Harry Homeowner and his vast understanding of 24v tstat wiring. Heat pumps can have up to 7 wires and 50's-80's homes with basic tstats did not need to run a common wire. Oh the fun of explaining to the home owner he will need to pull tstat wire with more conductors after Lowes or Amazon told him easy install.
  25. Aug 11, 2019 at 6:42 AM
    Mike Tread lightly.
    south carolina
    Do a factory reset to it and see if that fixes it..
  26. Aug 11, 2019 at 6:44 AM
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
    do you know how to do it ?
  27. Aug 11, 2019 at 6:47 AM
    Mike Tread lightly.
    south carolina
    Go-to settings... Go-to the bottom reset all
    rons23 likes this.
  28. Aug 11, 2019 at 6:54 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Honeywell T6. I have 2. Love the app and devices.
    TheGreyTundra28 and nvrgvup444 like this.
  29. Aug 11, 2019 at 7:01 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Rumor has it that if you paint your thermostat black it works faster.
    :gossip:
  30. Aug 11, 2019 at 4:06 PM
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
    I don't have a c-wire so not all thermostats will work unfortunately
