I admit it... I have garage envy
Discussion in 'Off-Topic Discussion' started by Snoman181, Aug 10, 2019.
  1. Aug 10, 2019 at 6:05 AM
    Snoman181
    Snoman181 [OP] New Member
    Reg
    Ottawa, Ontario
    2017 Toyota Tundra
    I joined the forum a few days ago, and as I have been perusing the various build and mod topics one thing struck me... Some of you guys have some enviable garage setups!
    I've become pretty adept at swatting mosquitoes while laying on my back under various projects through the summer, and in the winter, everything goes on hold until the annual Great Thaw.
    How about you guys post pics of some of your man caves? Eventually I hope to build a retreat of my own... Any ideas on must have features?
    For now I will just continue dreaming, planning, and drooling...
  2. Aug 10, 2019 at 6:23 AM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    Welcome to the forum! If your a person who likes to wrench. Look into overhead or wall mounted retractable extension cord reels. Very handy and great to keep your garage clean. You can mount an air compressor tank and run a retractable hose line for any air powered tools. You can install garage storage over your garage doors. This is a space most people don’t use and it can make for a lot of room to put storage bins. 741D920D-58E4-4C91-BD66-19BC7E4CF9E9.jpg
  3. Aug 10, 2019 at 6:29 AM
    Outbound
    Aaron
    Northern Alberta
    That overhead storage rack is an awesome idea. I can't believe I never thought about putting one there.
    Mountun Goat and 1UPPER[QUOTED] like this.
  4. Aug 10, 2019 at 6:42 AM
    1UPPER
    TEXAS
    Flux capacitor!
    I’ve done those racks a few times for my family and friends.
    If you want a few suggestions for the install. Locate all your studs on the ceiling first. Then check your clearance with the garage door all the way up. Make sure your storage bins will fit. You can build the rack system on the ground and lift it overhead with a drywall hoist or extra help. This makes the install a lot easier and faster. 970057D9-7D66-4896-9F60-A66A28D04D38.jpg
  5. Aug 10, 2019 at 6:49 AM
    Outbound
    Aaron
    Northern Alberta
    Thanks for the tips! Any other cool ideas you've done or seen in you line of work?
    I'm going to keep watching this thread. We just closed on a house and setting up my new garage is a big priority for me. Right now the walls and ceiling are drywalled. I'm thinking of removing the drywall, adding a ton of electrical outlets, installing a welder plug, putting in LED lighting, installing a slop sink with a hose connection and then sheeting the walls with OSB that I'll probably paint an off white.
    Sunnier and 1UPPER[QUOTED] like this.
  6. Aug 10, 2019 at 6:54 AM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    I need to tag this thread , mine is a pigsty, this thread will help me get some ideas. I like that overhead storage.
  7. Aug 10, 2019 at 7:19 AM
    Shark Bait
    Shark Bait Not new anymore
    2019 Platinum
    However big you think you need, build bigger.
  8. Aug 10, 2019 at 7:22 AM
    1UPPER
    TEXAS
    Flux capacitor!
    I’m a big fan of a work area with a work bench, metal storage cabinets overhead and below. I like to have an outlet bar above my workbench area.
    If you want storage bins for small or medium size containers. You can install a track channel panel system similar to shown above. You can buy 4x8 sheets that have the track channel on them. Look up Gladiator storage systems for some ideas on this. They are typically carried by Lowe’s and sold online.
    If you do a welder plug you want a dedicated circuit. Before you remove drywall for electrical outlets. Do you have insulation behind the drywall? If you can fish the wiring in between the joist, rafters or studs this will make the install a lot easier. If you may be able to do drywall patches or cover the drywall with a different finish material after your electrical rough in is done. If you are located in the cold look into a dedicated circuit for a garage heater in the winter time. If you have hot summer months a porta cool unit is always nice to have. If you have in insulated garage doors you can install insualtion to the garage doors to help keep your garage better insulated. An epoxy floor is always nice to have. I’m a fan of install a rubber floor system around my work bench area. This is a lot easier on your feet when your standing for long periods of time.
    I would plan out your garage layout first. Think of things like work areas & cabinet storage. Then plan your ideal locations for outlets, lights, fan & storage. I would do you electrical & air hose rough in work first. Then do your drywall or finish walls next. If you do air lines they may be best to leave them exposed so you can get access to them for any leaks or adding additional fittings. You can do you wall and ceiling painting next. I would cover the concrete floors before paint. If you do an epoxy floor you want the concrete to stay clear of dirt and debris. I would do your floor system after all the rough in work and painting have been done. Then you can do any cabinets & storage areas after the floor is completed. I’m a fan of having the epoxy floor system return up the lower wall if you have a concrete curb. If you have drywall then you can look into having the rubber cove molding done. This is inexpensive and easy to install. I could go on and on with more ideas. Sorry if I just spent your money on more garage ideas. Lol
    :spending:
  9. Aug 10, 2019 at 7:35 AM
    Ely010606
    SPARKS, NV
    Damn, that’s two times bigger than my house.
  10. Aug 10, 2019 at 7:51 AM
    Outbound
    Aaron
    Northern Alberta
    All great ideas. Thanks alot. Feel free to keep spending my money. :D
  11. Aug 10, 2019 at 9:19 AM
    kjkeats
    kjkeats New Member
    Rendon, TX
    15 CM SR5 MGM 4x4 5.7L
    This is my man cave and my garage. Gets a little warm in the Texas summer, but no place I’d rather be.
    I legit don’t have a garage, converted to a living room by previous owners. And no man cave inside. With 3 daughters though, the quiet outside is very nice, regardless of weather. Haha.
    Kn4x2, koditten, drobb and 3 others like this.
  12. Aug 12, 2019 at 10:00 AM
    eharri3
    eharri3 New Member
    2021 F150 Powerboost
    I am also jealous. I have a little tiny 60 year old one car that could barely fit a mid sized sedan before I filled it with junk, that will need to be freshened up with a new roof and trim in a few years if it remains standing. When we started looking for a home we had all these grand visions of huge 2 car garages and master suites and all this other awesome stuff.
    Then we found something in good shape for about 50K less than we were planning to spend, with low property taxes that is 2 minutes from the highway we both use to commute, and a block away from the kindergarten, middle school, and high school our son will eventually go to if we stay. So pretty much all the other stuff went out the window. I was lucky enough to at least get an attic converted to a living space for a 3rd floor man cave. I hope to build a better garage in a few years.
    I don't regret this house but I'd like to do the stuff I originally wanted one day, such as a big garage. Best I got is a canvas carport for my Challenger, other vehicles sit un-protected for now. Wife used to make a big deal of keeping enough space in the garage for a car, then started parking outside because she got tired of maneuvering.
  13. Aug 12, 2019 at 10:14 AM
    BlackSheep
    BlackSheep ol’ Reliable
    Scott
    Kansas City, MO
    2010 Black DC 5.7L 4x4
    2.5” shocks, 3/1 level, 37s, 5.29s, air locker, on-board air, bed cap, bed stiffeners, roof rack, steps/sliders, spare carrier, under seat storage bins, window tint
    Oh man. I didn't need to see this thread. Another way to spend the money I don't have :smack:
    aperezsh and Darkness like this.
  14. Aug 12, 2019 at 10:36 AM
    vl184009
    vl184009 Cheers Boys!
    Vicky
    Southern, Ca.
    2016 MGM CM SR5 4x4 w/Tow Pkg
    Not much of a man/woman cave, but it's clean and organized. It houses my Tundra and Sonata sport just fine w/room to walk on all sides. Still waiting to hook up my flat screen and oscillating fan.
  15. Aug 12, 2019 at 10:43 AM
    Deuxlatch
    Deuxlatch AirBus
    Chris (Latch)
    Tomball, Tx./Lafayette, La.
    2010 Super White Tundra CM
    TRD Supercharger, TRD Big Brake kit, MotoMetal wheels, Undercover Tonneau with dual swing out saddle bag tool boxes.
    I built one of those from wood and lag bolted it to the cross beams in my garage. You wouldn't believe the weight it could hold for just under $100
    Mountun Goat likes this.
  16. Aug 12, 2019 at 10:54 AM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Not much of an inside pic cause dirty life. Lots of ideas in there tho. Made a pretty handy canoe hang. Garage is my favourite place in the world :)
  17. Aug 12, 2019 at 11:25 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Garage envy I am used to having. Now I also have shed envy...
  18. Aug 12, 2019 at 11:40 AM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    Bak Revolver, BedRug, Undercover Swingcase, PopLock, Bilstein 5160(rear), Firestone RideRite, TRD rear sway bar, Coachbuilder +2 rear shackles, Andersen 5” aluminum adjustable hitch, TRD dual exhaust, VLEDS interior leds including the footwell kit, TundraTex FRAC mod, VLEDS LPR backup tag mount led, Husky X-Act mats, Color matched cup holder bezel (silver), Ceramic 20% tint all around, 50% Ceramic windshield, Color Matched door handles & mirror caps, The “Stubby” antenna, AMP Research steps, VLEDS 6”step lights, ToyTec/5100 Bilstein coil overs, 700lbs red ToyTec springs (2.75” lift), 20x9 +18 Method 306 custom painted and custom fit center caps, Gorilla spline lugs, Bridgestone Revo 3s 285/60R20, TRD skid plate, RaptorLiner “Red” tow hooks, 19 Pro black LED headlights, VLEDS Triton V6 turns, Rigid SAE D series fog lamps, 19 TRD hood scoop, 2019 TRD Pro grille, Coachbuilder bumper shims, X-Pel protect under mud guards, Opti Coat Ceramic, Opti Coat Sealed. And some snakes and sparklers, because they are my favorite!
    Mine is a work in progress, doing it all myself
  19. Aug 12, 2019 at 12:02 PM
    BlackSheep
    Scott
    Kansas City, MO
    You guys are inspirational. I should have some time tonight when I'm the only one home in my family. I may take advantage and do some cleaning up and organizing in my garage. It won't compare to any of yours, but I'd like it to be at least functional again.
  20. Aug 12, 2019 at 12:16 PM
    neirbot
    neirbot New Member
    I've had garage envy for a long time, now I'm in the process of satisfying it. Just a few more weeks until it's done.
  21. Aug 12, 2019 at 12:19 PM
    TundraPro2019
    TundraPro2019 New Member
    Barthold
    Western Slope, CO
    2019 Tundra TRD Pro
    Car lift, best tool I ever bought! (Yes the Tundra fits under it, just no need to drive it forward that far)
  22. Aug 12, 2019 at 1:06 PM
    JH5370
    JH5370 Member
    Josh
    Eastern WA
    2017 White DC TRD PRO
    I'm in the middle of designing a house with a 3 car garage. I like pretty much everything I see here..
    Rica25, 1UPPER and Mountun Goat like this.
  23. Aug 12, 2019 at 1:32 PM
    1UPPER
    TEXAS
    Flux capacitor!
    I’m a big car guy. So you can’t tease me without showing what sports car is under that car cover. :curls:
    YardBird likes this.
  24. Aug 12, 2019 at 1:41 PM
    Ynot_tonY
    Ynot_tonY Merciful
    Tony
    Baby mods doo doo doo doo doo doo
    Audio/Lift/Tires
    Im going to guess Z06 with the big wang
  25. Aug 12, 2019 at 2:07 PM
    Omohundro
    Jody
    McMinnville TN
    Yes, I want to know also :burnrubber:
  26. Aug 12, 2019 at 2:28 PM
    TundraPro2019
    Barthold
    Western Slope, CO
    2019 Tundra TRD Pro
    Nope, try again :) It is not a US car.
  27. Aug 12, 2019 at 2:33 PM
    HappyGilmore
    HappyGilmore Ex 1st Gen Member
    Trent
    Lakewood CA
    2018 White Limited TRD 4x4
    I was thinking a Lotus?
  28. Aug 12, 2019 at 2:42 PM
    TomC843
    TomC843 The wheel weaves as the wheel wills.
    Tom
    Charleston, SC
    16, 4X4, 4U3, Katzkins, Flowmaster, ARE MX, Swing cases, TRD skid plate, Volant CAI....
    Just sighed contract on a free-standing stick built 30x30 2 car garage. The one big difference we did is because wifes small car will leave us some elbow room we are getting a third garage door in the back for the golf cart and what not. Wont need to walk between the Truck. Also upgraded to 9x8 doors
    1UPPER likes this.
  29. Aug 12, 2019 at 2:50 PM
    Capt J-Rod
    Capt J-Rod New Member
    Ohio
    2018 Cement TRD Off Road Crew Max SR5 Tundra
    Husky Floor Mats, Diamond back lid, Coverking seat covers, More gas.
    JH5370 and Shark Bait like this.
  30. Aug 12, 2019 at 4:09 PM
    Ynot_tonY
    Ynot_tonY Merciful
    Tony
    Audio/Lift/Tires
    You got me. I want to say 370 or some kind of AMG.
