2nd Gen Backup Cam Upgrade
Discussion in '2nd Gen Tundras (2007-2013)' started by mbn225, Jul 7, 2019.
  1. Jul 7, 2019 at 1:25 PM
    mbn225
    mbn225 [OP] New Member
    Louisiana
    2008 Tundra Crewmax TRD
    Rock Warrior Bits Flowmaster exhaust 3/1 Lift
    Ok so I have an 08 limited cm and it has the jbl system with factory backup cam mounted in the tailgate handle displaying in the head unit. It is very dated quality, is almost useless in low light, and lacks backup lines that would help out a lot on a huge truck. I went to the local audio shop to talk about a head unit upgrade and about backup cam upgrade options. They said there isn’t an upgrade option that can replace the stock one and I would have to mount another one below leaving me with two cams, one of which would be non operational. Does anyone know of something I can use to directly replace and upgrade the stock cam and if not what are your suggested backup cams to upgrade to?
  2. Jul 7, 2019 at 3:00 PM
    sf319
    sf319 New Member
    Utah
    2014 CM Barcelona Red SR5 5.7
    Dash Cam|PowerStop Z36|DIY bed rails|DIY Pop-n-Lock|LED interior
    I spliced into the harness just under the roof console, where they mount the screen. I have heard there is a point just behind the upper glove box that is closer, but the roof console is obvious. I am trying to find the schematic, maybe someone else will have it readily available before I can find it.
  3. Jul 7, 2019 at 4:00 PM
    mbn225
    Louisiana
    I was really wanting a replacement that I could remove the actual camera from the tailgate and splice there.
  4. Jul 8, 2019 at 9:08 AM
    minter66
    minter66 2007 TSS CrewMax
  5. Jul 8, 2019 at 9:16 AM
    mbn225
    Louisiana
    Yeah that looks like the stock one, I’ll bet the backup lines are coming from the radio itself. How is it at night?
  6. Jul 8, 2019 at 9:24 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    2007 Tundra 5.7 L Double Cab TRD 2WD
    TSS 20's with Cooper ATP ll's, N Fab 3 Step Nerf Bars,, Pioneer AVIC-8100NEX, Masters Tailgate Replacement Latch with Camera, 1" Maxtrac Shackles, LED Interiors/Brake/Reverse/Cargo/Fog Bulbs, Fumoto Drain Valve, Toyota Aluminium Oil Filter Housing, TRD Shift Knob, Courtesy Door Projector LEDs with Toyota Emblem, Console Tray and Lower Divider.
    I have used the masters tailgaters camera latch and it worked great as well. This was with an aftermarket HU install.
    I believe there may be a voltage supply difference 12 volts vs. 24 volts (or vice versa), stock vs. aftermarket. Make sure any new camera is the same voltage requirement as existing one.
  7. Jul 8, 2019 at 9:28 AM
    minter66
    Switches to black/white but I can see down the driveway in reverse with just dim brake / reverse lights.
  8. Jul 8, 2019 at 3:42 PM
    Dr_Al
    Dr_Al New Member
    Al
    The lines are in both the camera and the aftermarket head unit. On the tailgate there's a wire you can cut that will disable the lines so if you want to use the ones on the head unit you can. I think someone said that the stock camera isn't 12 volts so you may have to get power for the aftermarket camera from somewhere else. What I did is tap into the reverse light so the camera would only come on when the reverse lights came on. Since I didn't have a camera I ran both the wire for the camera and the wire from the hot side of the reverse light back to my Kenwood head unit so it would know when I was in reverse. There's several different places in the cab you can also get "reverse" power from.
    If the reverse monitor is in the factory head unit I would use the factory wires. But if it's in the overhead console I would just run new wires but taking advantage of the factory plug at the tailgate so if I ever wanted to remove it I could. Under the rear seats on the double cab are a couple rubber plugs. I made a small hole in one of them to get the wires inside of the cab without drilling steel. I would think the CM would also have these.
  9. Jul 8, 2019 at 4:58 PM
    chinadog
    chinadog New Member
    Knoxvegas
    2018 Midnight Black Metallic 1794, 2013 Black Platinum
  10. Jul 9, 2019 at 7:34 AM
    mbn225
    Louisiana
    I’ve read a few reviews that say the upgraded head units improve the quality of the stock camera and the head unit will add the backup lines so I think I will just add a front camera and just see how the stock one looks for now.
  11. Jul 10, 2019 at 9:40 AM
    jtaco11
    jtaco11 New Member
    Aftermarket camera $10+ are just as good as stock or even battery.
  12. Aug 9, 2019 at 3:15 PM
    tundraatx
    tundraatx 2008 Limited Double Cab, 5.7L
    Austin, TX
    1) Bought with 225k miles on it, a Westin bullnose bumper, and OEM tundra steps 2) Current Mileage 238k Mods: 1) Dirty Deeds BA Mufflers 8 inch with resonator (as of Feb 2021) - Had the 10 inch with resonator - Prefer the 10 inch without resonator - deeper sound hear it more in the cab 2.) Ranch Hand Summit Front Bumper/Guard 3) Ranch Hand Summit Bumper 4) Billstein 5100s all around 5) TRD front and rear sway bars 6.) Rough Country wheel to wheel steps 7) Pioneer 8400 NEX Wireless ApplePlay 8) Backup Camera: e-raptor 9) LED white lights replaced in headlights, fog lights, inside cabin, and exterior lights 10) Linex (unbranded by Central Texas Truck Coatings) 11) OEM Toyota side panels and generic panel on tailgate Maintenance/Repairs: 1) Valve covers, belt tensioner, alternator belt - $415 2) Evaporation fuel canister and filter replacment $1547 *This was a Toyota TSB for 07-08 AFAIK. Toyota covered in first 3 years of ownership. Mine failed after 13 years of daily regular driving use. Not bad at all. 3) Pioneer Unit - had to ship to Pioneer to replace Output IC - $45 (shipping) free under 1 year warranty fix 4) Pioneer Unit - Electrical feed back coming through speakers when accelerating. Fix was to check all wiring/tighten up/ make connections good again $42. 5.) Rear passenger door actuator replaced. Part was $287 with tax on ebay from Toyota dealer free shipping. 6.) Rack and Pinion, tow mirrors, shocks install, lifetime alignment - $1884.36
  13. Aug 10, 2019 at 7:57 PM
    Fozzy360
    Fozzy360 New Member
    Hunter
    Virginia
    2010 Tundra Crewmax Limited
    Stock
  14. Feb 17, 2021 at 11:05 PM
    greg52673
    greg52673 2010 Toyota Tundra double cab 4.6 with
    Greg
    Saint Augustine FL
    Reverse license plate camera
    Bought license plate reverse camera and got power fron the reverse tail light. Got power from red wire with purple line in it and the black wire for negative coming out of the reverse light bulb itself, also attached the red wire that come on the yellow RCA plug to the same power wire I hooked the camera to. I started from the back of my Kenwood DDX276BT head unit plugged yellow RCA into the camera in on the head unit and attached the red wire that's in the same line as the yellow RCA plug to the purple reverse wire on back of stereo. Ran RCA wire under the passenger carpet through a rubber plug the pushed the rubber plug back in and it was snug with RCA wire going through the side of rubber plug. Then put 3/8th pvc heat shield around the 20 ft or so RCA wire ranit to the back and attached wires accordingly as stated above. Also zip tied the wire tho existing wires under the truck along the frame rails to passenger rear reverse tail light bulb for 12v power and so the camera will only go on when reverse is engaged. Hope the pictures helped
  15. Mar 4, 2021 at 2:30 AM
    Texas_Cowboy
    Texas_Cowboy New Member
    2011 Tundra Limited Platinum
    XB LED Headlights, 1k lumen reverse lights
    I'm also looking to replace the stock camera in my 2011 platinum. My main concerns are will it fit in the handle where the stock one now resides, good quality, and how the heck can I splice it in at the handle/tailgate
  16. Mar 7, 2021 at 12:49 PM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
    Yup. Went with this $10 one. It's $16 right now. Comes with a little hole saw to make the hole in the OEM handle.
    Dalandshark likes this.
  17. Mar 8, 2021 at 12:47 PM
    idiggplants
    idiggplants New Member
    PA
    2013 DC 4wd
    5100 fronts middle setting 5100 rears 3rd gen offroad wheels softopper ditch lights
    thats the one i got. works well cause you can point it to where it needs to be pointed, but holy hell it was the most difficult to point camera cause there is no mark on it to indicate what goes up, and its hard to rotate the inner camera without making it go out of focus. second thing i really dont like is the guidelines. they cant be turned off. fine if they happen to be in the right spot, but that will never be the case. and putting them up high on the tailgate not quite centered, they arent even close. so now i have lines on my aftermarket radio that i have adjusted for the exact use, but ive got these really distracting lines that are so far off its silly. looks kind of garbage having to deal with 2 sets of lines.
    word to the wise for folk on here... everyone wires their cam to be powered by the reverse signal. the reverse signal is actually supposed to just trigger the head unit to switch to the camera. the cam should be powered by the trucks acc wire. that way you can switch to the camera manually in the head unit. i dont need that often, but its nice to double check that my trailer chains are still connected. or that i did, in fact, close the tailgate, lol.
  18. Mar 8, 2021 at 1:58 PM
    Texas_Cowboy
    @BlueCrushSC16 can you link it?
  19. Mar 8, 2021 at 1:59 PM
    idiggplants
    PA
    2013 DC 4wd
  20. Mar 8, 2021 at 2:00 PM
    Texas_Cowboy
