Supercharger Boost Fluctuating
Discussion in 'Performance and Tuning' started by snivilous, Jul 30, 2019.
  1. Jul 30, 2019 at 7:46 PM
    snivilous
    SW UT
    300k+ Supercharged 2008
    When I floor it, my boost is all over the place. Peak boost is pretty consistent, but from what I've heard it should sit at peak boost the instant you floor it, it shouldn't ramp up and it certainly shouldn't be everywhere. I'm at altitude so my peak boost is around 5.5psi, when I floor it it'll go 2, 3, 4, 3, 4, 5, 4, 3, etc. Should it not just hit 5.5 and stay there until I let off or it shifts?
    And if not, is this a boost leak or something else?
  2. Jul 30, 2019 at 9:36 PM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    Black '14 CM SR5 w/ SC; 40s on 17s; 5.29s
    What are you using to measure your boost?
  3. Jul 30, 2019 at 9:39 PM
    snivilous
    SW UT
    Innovate digital boost gauge to the driver side boost port
  4. Jul 31, 2019 at 7:26 AM
    dirtydeeds
    Keith
    USA
    more than I can list here
    Either the gauge is bad, or there is a boost leak.
  5. Jul 31, 2019 at 8:05 AM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    check for a vacuum leak. check the fitting where the boost guage gets T'd off at.
  6. Aug 6, 2019 at 12:24 PM
    snivilous
    SW UT
    Got a $10 analog gauge off Amazon and the boost is solid at 5.x psi. The digital gauge I have is an innovate AFR/Boost gauge, so either it's updating so fast and seeing fluctuations due to the tube and sender geometry or is just jacked up, the peak boost it measures matches the analog gauge. I'll talk to innovate, my guess would be the analog needle just can't react enough to see any random blips from the hardware setup but the digital can and displays it without smoothing out the information.
  7. Aug 6, 2019 at 12:42 PM
    TXTundra2722
    2015 Black Tundra
    Good catch, usually the cheapest option is to get another gauge and you've already figured this part out.
    Watt maker likes this.
  8. Aug 6, 2019 at 7:05 PM
    19greysport
    19greysport New Member
    2019 crewmax sport
    Check the bypass valve and. Make sure ur belt isn’t slipping.
  9. Aug 6, 2019 at 7:15 PM
    Spvrtan
    Kris
    San Diego, CA
    Anyone have a photo of where they spliced their T-fitting when installing their gauge?
  10. Aug 7, 2019 at 9:13 AM
    snivilous
    SW UT
    Is there a reason to splice it? I just plugged straight into the boost port on the rear driver side, was that supposed to connect to something else?
