Simple Suspension
Discussion in 'Suspension' started by cdkenne, Nov 19, 2016.
  1. Nov 19, 2016 at 9:07 PM
    cdkenne
    cdkenne [OP] Toyota Master Technician
    Corey
    KS
    2002 Tundra SR5 TRD Offroad
    285/70R17, '15 4Run Trail Wheels, Westin Shopping Cart Basher, SnapOn license plate cover that adds >50 HP
    After reading some positive remarks about Bilstein 5100s, I decided to price them out. Seems a frugal idea, so I'm probably going to pick them up.
    My question is, are there any suggestions for an add a leaf? Brands etc I'm not really sure where to start.
    2002 SR5 TRD Offroad
  2. Nov 19, 2016 at 9:30 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    Are you adding a leaf to raise the rear, or to prevent squat when carrying? If to raise the rear, I suggest you go with coach builder shackles instead. If to prevent squat, consider airbags. Airbags will be inert when not pumped up, preserving your factory rise quality, but they are there when you need them. Do not use airbags to lift your suspension. That is not what they are designed for.
  3. Nov 19, 2016 at 9:36 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Why do you want an add a leaf? Are you gonna be frequently carrying a lot of weight? Maybe, if it's just for lift, you'd be better off with shackles?
    joonbug likes this.
  4. Nov 19, 2016 at 9:37 PM
    cdkenne
    Corey
    KS
    I was just looking to bump up the rear a bit. The 5100s are supposed to be ok for 1" in the rear.
  5. Nov 19, 2016 at 9:39 PM
    cdkenne
    Corey
    KS
    I was thinking add a leaf because I don't really care for blocks. I haven't done anything with aftermarket shackles so that's new to me.
  6. Nov 19, 2016 at 9:46 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    The shackles, Toytec or Coachbuilder will retain the factory ride quality. An add a leaf will make your ride harsh.
    NewImprovedRon and T-Rex266 like this.
  7. Nov 19, 2016 at 9:50 PM
    bobeast
    Bob
    Hollister, CA
    2008 DC
    Yeah then coach builder +2 shackles will give you about an inch up in the back, and will work fine with the 5100s. Don't forget the carrier bearing drop (also from coach builder). We have 2 piece drive shaft and lifting the rear will mis-allign the two shafts which can cause an annoying vibration on acceleration.
    NewImprovedRon likes this.
  8. Nov 19, 2016 at 9:50 PM
    cdkenne
    Corey
    KS
    I'm not sure that harsh would bother me but I'll look in to the shackles.
  9. Nov 19, 2016 at 9:52 PM
    Unless you're towing, just go with a block or shackles...and if you are towing...one of the above + airbags
  10. Nov 19, 2016 at 10:46 PM
    AaronK
    AaronK New Member
    Aaron
    2002 White Tundra AC SR5 4x4
    You'd have to do a shackle flip to get any lift using shackles.
  11. Nov 19, 2016 at 10:50 PM
    bobeast
    Bob
    Hollister, CA
    2008 DC
    Not if the shackles are longer than factory.
  12. Nov 19, 2016 at 10:56 PM
    AaronK
    AaronK New Member
    Aaron
    Longer shackles would lower the ride height.
    cdkenne[OP] likes this.
  13. Nov 19, 2016 at 11:12 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    bobeast is right. You get lift 'cause the shackles are longer. I just added longer toytec shackles to my truck. The toytec shackles are cool 'cause you get a choice of 1" or 1.5" of lift.
  14. Nov 20, 2016 at 11:08 AM
    AaronK
    AaronK New Member
    Aaron
    First gen tundra has inverted shackles..
  15. Nov 20, 2016 at 11:20 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    What to Expect: TUNDRA REAR LIFT LEVELING KIT !
    *REAR * robotic welded , powder coated 1.75" lift shackles *
    *Powder Coated for lifetime , with Polyurethane hi performance bushings *
    *May be Red or Black Bushings *
    *Made in USA , rolled steel , Robotic precision welded *
    *Easy direct bolt in , no welding or cutting or modifications *
    *Must have 2.5" wide leafs !! *
  16. Nov 21, 2016 at 5:13 AM
    cdkenne
    Corey
    KS
    Like @AaronK said, my leafs are on top of my shackles. If I install longer shackles, I will raise the leaf which will lower the truck.
    Do you know how much lift?
  17. Nov 21, 2016 at 6:37 AM
    AaronK
    AaronK New Member
    Aaron
    There's a company who just came out with a shackle flip bracket. Reusing factory shackles I want to say gets you about 0.5"-1". The brackets are adjustable. They also make longer shackles that go with their flip bracket..
  18. Nov 21, 2016 at 6:40 AM
    AaronK
    AaronK New Member
    Aaron
