Floor Jack Point on Skid Plate
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by DC1947, Jun 18, 2019.
  1. Jun 18, 2019 at 12:49 PM
    DC1947
    DC1947 [OP] New Member
    Oklahoma
    2019 Tundra TRD Pro
    None
    Have yet to do an oil change yet on my 2019 TRD Pro. Anyone know if there is a floor jack point on the skid plate. Looks as though there is a frame supported point just aft of front bend in plate. Can not as yet find any reference to it in manual.
  2. Jun 18, 2019 at 12:53 PM
    mt95
    mt95 New Member
    Ohio
    2017 Tundra Crewmax-White
    I usually place my floor jack under one of the lower control arms to raise the truck up high enough to get my jack stands under the frame up near the front tow hook attachments. Gives full access to allow the skid pan to be unbolted and dropped out. If you place jack under the skid pan, you won't be able to remove it!
    Just did an oil change on mine an hour ago
    Boerseun likes this.
  3. Jun 18, 2019 at 1:04 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Manual says circle indentation on bottom of skid is meant as a jackpoint
    dgtulsaguy[QUOTED] likes this.
  4. Jun 18, 2019 at 1:05 PM
    DC1947
    Oklahoma
    2019 Tundra TRD Pro
    None
    What page on manual?
    Tundyfundy likes this.
  5. Jun 18, 2019 at 1:06 PM
    Stumpjumper
    Stumpjumper New Member
    Fate, Tx
    2017 Tundra TSS 4x4
    Don't need to remove plate on a Pro. They should all have access panels. Some freaking idiot at Toyota made it exclusive to Pros
    Tundradrenalin likes this.
  6. Jun 18, 2019 at 1:44 PM
    DC1947
    Oklahoma
    2019 Tundra TRD Pro
    None
    Saw the circle on skid plate, location looks to be frame supported. It's clear skid plate does not need to be removed for oil change. There is removable access panel for filter housing which utilizes same tool as my Lexus. Oil pan drain plug is easy to get to. Had plans to install same Fumoto valve for future changes. Have used Fumoto valves on three previous vehicles, slower drains but much cleaner.
    AZTundra and CMB like this.
  7. Jun 18, 2019 at 3:31 PM
    Tundyfundy
    Bay Area, CA
    I meant the paper work included with the skid plate. Toyota calls it the “customer care card” the circle is reinforced with a large box spacer to distribute the weight. It’s meant to be a jack point although I couldn’t find that card anywhere. I have it in my files and can pull it when I’m home but no luck online.
    Skid plate works on all models not just pro. I bought the 2019 TRD pro plate and it fits my 16 sr5. Same with all the pro parts.
  8. Jun 18, 2019 at 5:44 PM
    TRD423
    TRD423 New Member
    Chattanooga
    17 SR5 TRD 4X4
    -20% tint all around and over factory -2” ToyTec leveling spacer -275 70 18 BFG KO2 -TRD duel exhaust -TRD Pro skid plate -TRD Pro grille -TRD sway bar -TRD performance air filter -vinal wrapped front bumpers -Xenon Vision led head/ fog lights and interior lights -AJT Design billet shift knob
    I jack my truck up from the designed lift point on the TRD skid plate when i need to lift the front. Check these two pictures out. The skid plate picture where the blue circle is where i place the jack.
    TreeCat, 619Tundra and Tundyfundy like this.
  9. Jun 18, 2019 at 6:37 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    The big black Rhino plastic ramps. Rated at 12,000 lbs. Boy they are easy. $39 for a pair at Walmart. I will also put jack stands under the frame for safety.
    Migraine, Tundradrenalin and Bprose like this.
  10. Jun 18, 2019 at 7:03 PM
    Taco-Blender
    Taco-Blender Old Guys Rule
    AZ
    2010 DC 4x4
    Jack it up for an oil change?
    My '10 has the stock TRD suspension with zero lift and I can crawl right under there with no problem.
    a_double, 15whtrd and Beep88 like this.
  11. Jun 18, 2019 at 7:16 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    My wifes car is a little lower than my tundra. I only needed a little bit of room so I layed two short pieces of 2x4 under the tires. 1.5 inches of lift! Easy
  12. Jun 19, 2019 at 3:26 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    +1, never jack up for oil change. With 6112s I can even drain straight in to 5gt jug. Just have wait for first 3 then switch jugs
    619Tundra likes this.
  13. Jun 19, 2019 at 7:52 AM
    DC1947
    Oklahoma
    2019 Tundra TRD Pro
    None
    Found skid plate install instructions online for gen 3 TRD Pro. Does not mention the "circle" as a jack point. I've sent a email to Toyota Tech Support. Although I won't need to jack up for oil change, plenty of room to get to stuff. If you need to jack stand all four it would simplify the process to utilize that area as a jack point. BTW its a damn nice truck, have been a Ford guy for a long time....but the VooDoo Blu, has to have one!!
  14. Jun 19, 2019 at 12:14 PM
    Tundyfundy
    Bay Area, CA
    See above... it’s on the customer care card not the install
    Instructions.
  15. Jun 19, 2019 at 2:10 PM
    DC1947
    Oklahoma
    2019 Tundra TRD Pro
    None
    Saw that, BTW Toyota Customer Support says no. Probably just looked in O&M manual. Might be worth $20 to sign up for TSB and TIS for two days...think I will
  16. Jun 19, 2019 at 2:28 PM
    DC1947
    Oklahoma
    2019 Tundra TRD Pro
    None
    Is there a document number on the Customer Care Card....Like nothing more that to prove "customer support" wrong....
    JohnLakeman likes this.
  17. Jun 19, 2019 at 2:55 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    Like others have noted; you shouldn't need to jack it up for an oil change. Nonetheless, I just installed the '19 Pro skid several months back. I then jacked it up a few times in the last few weeks while installing some upgraded calipers/ rotors.
    I took a piece of treated 2x4 about 12" long... Enough so that I could place it under the back two mounting bolts of the skid... Which are attached to the crossmember you would otherwise place the Jack. Centered the 2x4 on the Jack (of course).
    Depending on your lift height and Jack stands, you may consider using a 4x4.
  18. Jun 19, 2019 at 3:19 PM
    Midnite72
    Midnite72 Anything DIRT !!
    Northern MD
    18 SR 5.7 4x4
    2” level P&P sliders
    Always get all 4 corners off ground on jack stands so I can rotate tires while changing oil!!
  19. Jun 19, 2019 at 3:20 PM
    Midnite72
    Northern MD
    18 SR 5.7 4x4
    I use same jack spot on skid then put jack stands on frame and remove my non- pro plate to access oil housing , pan etc
    TRD423[QUOTED] likes this.
  20. Jun 20, 2019 at 5:46 AM
    Tundyfundy
    Bay Area, CA
    I’ve had no luck finding it online but it looks like somebody above posted an image from the card. I am currently traveling and will return home in two weeks. I have the card there. I’ll post both sides of the card when I get home. Until then, good luck! Ps the reason there is a box spacer at that point is to strengthen it for jacking. You can see it in the install instructions.
  21. Jul 13, 2019 at 11:55 PM
    Tundyfundy
    Bay Area, CA
  22. Jul 14, 2019 at 12:11 AM
    Tundyfundy
    Bay Area, CA
    Document number on the bottom of image 2
    AI0004-001 Rev. 3
  23. Jul 14, 2019 at 10:55 AM
    DC1947
    Oklahoma
    2019 Tundra TRD Pro
    None
    Thanks, I found some other tech docs on the web referencing the front crossmember jack point.
  24. Jun 6, 2023 at 7:31 PM
    singletrack_dad
    singletrack_dad New Member
    Ty
    2014 TRD OR CM
    Thanks for the warm welcomes. I have to say I’m pretty bummed to see how extensive my cam tower leak is. I pulled the engine splash guards and found this drainage / weep. If I would have been diligent to find this I wouldn’t have purchased the truck or I would have bargained for much less than $23,500. My plan is to keep a very keen eye on oil levels right before each oil change. I’ll follow toyota recommended procedure for checking oil level as far as warm up & idle etc. such a bummer but here we are
