DIY: Unistrut Bed Rails - Cheaper option than OEM
Discussion in 'General Tundra Discussion' started by csuviper, Jun 8, 2015.
  1. Jun 4, 2019 at 5:37 AM
    #151
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    No problem at all :thumbsup:
  2. Jun 4, 2019 at 7:22 AM
    #152
    Topherwv
    Topherwv New Member
    Nice, is this what you used?
    BillT likes this.
  3. Jun 4, 2019 at 9:08 AM
    #153
    Savagebass
    Savagebass New Member
    Brandon
    MICHIGAN
    2019 TRD Sport
    Front and rear leveling kit Front window tint DIY bedrails Blackout badges
    Mine is the same with the factory installed bedliner. How did you find the predrilled holes? Did you use anything special to clean them.out?
  4. Jun 4, 2019 at 9:45 AM
    #154
    phabej
    phabej New Member
    Washington
    2018 Platnium
    Yes! These go into the rails of my Chevy I traded in but just remove the back plate and use the m6x1.0 screw, easy. pretty secure.
    I'm thinking about using 3m double sided table on the mounts won't move around but it seems very secure so.. we'll see.
    Topherwv[QUOTED] likes this.
  5. Jun 4, 2019 at 9:48 AM
    #155
    phabej
    phabej New Member
    Washington
    2018 Platnium
    I did a feeler test used a screw driver you'll feel it depress a little. It's quite soft, I just use a drill bit to press in and then proceeded to use a razor blade to gently cut into it. I didn't remove all the material, I was able to thread the m6x1 screw into it without any issues.
    I will probably replace the screw with black screws in the future so it'll match better.
    Savagebass[QUOTED] likes this.
  6. Jun 4, 2019 at 10:10 AM
    #156
    jeffw6236
    jeffw6236 New Member
    Jeff
    San Antonio
    2019 MGM CrewMax 4x4
    Installed these in my first tundra. A cheap easy and really functional mod. Just got a new tundra and the holes had a little of the bed liner spray in the hole. I took one screw to be a sacrificial lamb. Got the grinder out and cut a little notch across the first few threads. That gave the threads in the screw a little biting edge. Worked great to clean out the screw holes once you locate them.
    phabej and vq35721 like this.
  7. Jun 4, 2019 at 11:14 AM
    #157
    shhernandez74
    shhernandez74 New Member
    Samuel
    2017 Barcelona Red Tundra 4x4 SR5
    FRAC Driver side handle TRD Sway Bar Pop Lock Led Lights Seat Warmers Katzkin Bumper Step
    That interesting. Mine has bedliner in the holes too and was thinking about how to do it. Can you post a picture once you cut out the notches?
  8. Jun 4, 2019 at 11:36 AM
    #158
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    Wonder if they will slide in the SuperStrut without the bolt :confused:
  9. Jun 4, 2019 at 12:13 PM
    #159
    jeffw6236
    Jeff
    San Antonio
    Sure. I used a M6 x 1.0 x 16 screw. I just hit it once with a cutting blade. Screw it into the hole and it cuts the paint. Go slow. May back to back it out and try again. But it worked great.
  10. Jun 4, 2019 at 1:22 PM
    #160
    phabej
    phabej New Member
    Washington
    2018 Platnium
    I haven't tried it.. LOL I was at lowes and had the anchor in my pocket and didn't try it. :rolleyes:
    Guess I was thinking of not using the superstruts.
  11. Jun 4, 2019 at 2:21 PM
    #161
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    Yes you were right there! Hahaha . Love the Mod. Thank goodness for the OP, saved me some money lol. I’m using mine for my rack and RTT.7DD12C41-70C6-4C18-88CA-47984D855947.jpg
    Squatting Pigeon likes this.
  12. Jun 4, 2019 at 4:25 PM
    #162
    Midnite72
    Midnite72 Anything DIRT !!
    Northern MD
    18 SR 5.7 4x4
    2” level P&P sliders
    Great write up @csuviper !!
    Yea a little late to the party on this one
    :facepalm:
    Going to definitely do this DIY mod after I get back on my feet from foot surgery happening in two weeks !
    Thx again :bowdown:
  13. Jun 4, 2019 at 5:03 PM
    #163
    Savagebass
    Brandon
    MICHIGAN
    2019 TRD Sport
    Thanks Phabej! I had no idea the material was so soft. Your instructions worked great. Posting a couple pics in case it will help the next guy with a bed liner. Mine was factory installed and they appeared to have stuffed paper into the holes prior to spraying in the liner to make this a lot easier... gotta love Toyota.
  14. Jun 4, 2019 at 5:04 PM
    #164
    aRabidLunatic
    aRabidLunatic Professional Hobo
    Central Texas
    2015 Tundra SR5 Black
    Probably taped over the holes
  15. Jun 4, 2019 at 7:58 PM
    #165
    phabej
    phabej New Member
    Washington
    2018 Platnium
    Awesome that's all I did too. I've seen videos where they can just rip out the entire spray on liner after cutting it with a razor blade. Peels off like an orange.
    Glad you got it working. Thanks for updating the thread with photos.
    In the future I may add the superstrut, and add brackets so I can put a basket on top of my tonneau cover for camping and traveling trips.
  16. Jun 6, 2019 at 12:08 PM
    #166
    mroughton
    mroughton New Member
    Someone previously asked for idea attachments instead of using the over priced OEM cleats. You could fabricate something better using a 1/2" spring strut nut, 1/2" bolt and a d-ring tie down anchor (1,000lbs break point) from Amazon (https://tinyurl.com/y3wf6tyj).
    vq35721 and mlucas555 like this.
  17. Jun 12, 2019 at 1:59 PM
    #167
    Savagebass
    Brandon
    MICHIGAN
    2019 TRD Sport
  18. Jun 12, 2019 at 2:03 PM
    #168
    Savagebass
    Brandon
    MICHIGAN
    2019 TRD Sport
    20190612_165359.jpg Velcro strap from Menards... storage for my tow strap for pulling Chevys out of the ditch.
  19. Jun 13, 2019 at 4:46 AM
    #169
    Savagebass
    Brandon
    MICHIGAN
    2019 TRD Sport
  20. Jun 14, 2019 at 7:15 AM
    #170
    ZTundra
    ZTundra New Member
    ZACK
    Knoxville, TN
    2021 MGM Nightshade
    Would you happen to know what the length was of the M6 x 1 bolt that you used?
  21. Jun 14, 2019 at 7:24 AM
    #171
    jeffw6236
    Jeff
    San Antonio
    I used M6 x 1 x 16
  22. Jun 14, 2019 at 7:26 AM
    #172
    shhernandez74
    Samuel
    I picked up a set of OEM rails for 20 bucks!!! I just had to provide my own screws
  23. Jun 23, 2019 at 6:19 AM
    #173
    New2Tundra
    New2Tundra New Member
    Darryl
    Barcelona Red 2017 DC SR5 4x4
    Has anyone had any experience with bed covers that leverage the rail kit? Will using the DIY method work for those bed covers?
    Thanks!
    Randy Morton likes this.
  24. Jun 23, 2019 at 7:41 AM
    #174
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    Yes you should be able to make it work. I have a smittybilt trifold cover and I just had to add washers to the backside of the mounts for it to work
  25. Jun 23, 2019 at 8:04 PM
    #175
    Randy Morton
    Randy
    Deepinahearta, Texas
    What if you spaced out the rails and used some plywood sheets to make the top? I've been toying with this idea/hair-brained-scheme.
  26. Jun 25, 2019 at 5:02 AM
    #176
    shhernandez74
    Samuel
    I was going to go this route, but I found a set of OEM rails on Facebook for $20!
    4D4E487D-2E63-44B1-AEDB-421319167B81.jpg 4C85D03B-13F7-4026-BB5F-0052C7E36DBD.jpg
  27. Jun 25, 2019 at 5:03 AM
    #177
    Squatting Pigeon
    Holden
    North Texas
    It may work! Might have to mock it up with cardboard or something to see. :notsure:
  28. Jun 25, 2019 at 5:05 AM
    #178
    War Machine
    War Machine SSEM # 5 3MW
    For you guys in Houston and other Texas cities, I can hook you up with a good price on the unistrut if you want to try this.
  29. Sep 21, 2019 at 7:19 PM
    #179
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    Bumping the thread. I used some low profile unistrut and eye bolts to add some more tie points in my bed. I forgot that I ordered the centering style unistrut plates and man they are awesome for this. Night pictures because I need a win today haha
  30. Sep 21, 2019 at 7:23 PM
    #180
    Squatting Pigeon
    Holden
    North Texas
    Looks good! :thumbsup:
    KarmaKannon[QUOTED] likes this.
