Largest tire you can run stock for all generations
Discussion in 'Wheels & Tires' started by T-Rex266, Jan 9, 2017.
  1. Apr 15, 2019 at 10:16 AM
    #181
    taco supreme
    taco supreme New Member
    16 white CM 1794
    i searched all over for an answer to this: can i fit a 285/75/17 with Rock warrior wheels on a stock 16 cm?
  2. Apr 15, 2019 at 10:39 AM
    #182
    Tundra$
    Tundra$ White Trucks Matter
    Las Vegas
    2018 SR5 4x4 off-road CM 5.7 Super Fast White
    3/1 readylift, 35x11.5r20 ridge grapplers, 20’ fuel wheels, bakflip revolver bed cover, console safe, N-fab side rails, mini antenna, 2019 TRD Pro grill, color match hood bulge, front bumpershellz, baby car seat, to be continued...
    I have a 3/1 ready lift leveling kit
    These are the tires I’m using
    LiftMeUp[QUOTED] likes this.
  3. Apr 15, 2019 at 11:27 AM
    #183
    LiftMeUp
    LiftMeUp New Member
    Perfect!
  4. May 17, 2019 at 9:45 PM
    #184
    Smiley
    Smiley New Member
    08 Tundra TRD
    Why is the most popular tire for our trucks not included in this list?? (295/70 R18)
    splitfuse likes this.
  5. May 17, 2019 at 9:47 PM
    #185
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    2016 Toyota Tundra SR5 TSS Off Road
    TTC MEMBER #0193 2.5 Bilsteins struts (front) JDMstar led lighting inside Lazarstar spot lights Auxbeam LED headlight bulbs Auxbeam LED fog light bulbs 1.25” Spidertrax wheel spacers OEM fender flares
    Becuz we want to save money lol
    Smiley[QUOTED] likes this.
  6. May 18, 2019 at 7:12 AM
    #186
    Smiley
    Smiley New Member
    08 Tundra TRD
    How so?
  7. May 18, 2019 at 11:27 AM
    #187
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    Becuz I want to keep my rims I actually love them. Wouldn’t want to spend 1,500 on a new set of rims ..keeping the 20s saves me money. Only need the taller tire.
    LiftMeUp likes this.
  8. May 18, 2019 at 3:52 PM
    #188
    Smiley
    Smiley New Member
    08 Tundra TRD
    I get that, but many of us have 18's and the 295/70-18 is quite popular on our trucks.
    KELZ84[QUOTED] likes this.
  9. May 29, 2019 at 11:56 AM
    #189
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    I have a 3" lift and just installed 275/65/20 tires on the OEM TRD Sport wheels. OD is 34.2". They rubbed on the front small mud flaps (Which I then removed) and rubbed on the skid plate at full lock (which I hammered in with a rubber mallet about 1/2"). No rubbing. I was driving on a construction site through swales and rough graded areas with no problems or concerns.
    SHAKA U F4KA, TRDblvd and kgb4187 like this.
  10. May 29, 2019 at 12:42 PM
    #190
    k9shag
    k9shag New Member
    Tony
    Midland, NC
    2017 Tundra DC SR5 MGM
    @Smiley Are you running thus size. Do you have pics ? what lift? any trimming?
  11. May 29, 2019 at 2:12 PM
    #191
    Smiley
    Smiley New Member
    08 Tundra TRD
    I'm not, yet. Currently I'm on 275/70-18 with the 6112's in the front at the top setting (2.5") 5160's in the rear with toytec shackles at 1.5".
    My mudflaps were gone when I bought her.
    I have 18" x 8 wheels with an unknown offset.
  12. May 29, 2019 at 2:15 PM
    #192
    Smiley
    Smiley New Member
    08 Tundra TRD
    equin and LiftMeUp like this.
  13. Jun 8, 2019 at 2:15 PM
    #193
    effect
    effect New Member
    I have a 2019 Tundra Tundra Double Cab SR5 stock with P275/55R20 on right now. I was wondering if I would be safe from rubbing if I went with P285/70R17?
  14. Jun 8, 2019 at 6:24 PM
    #194
    Welcome from NY.
  15. Jun 10, 2019 at 3:04 PM
    #195
    Boerseun
    Ferdie
    Sarasota Florida
    @effect , the 285/70/17 is a 32.7" tire, less than an inch bigger than the OEM 275/55/20. You can go up to 1 inch taller on OEM suspension, so it should be good. The little bit wider 285 vs 275 should not be a problem.
    Spitfire and equin like this.
  16. Jun 11, 2019 at 3:56 PM
    #196
    flinky14
    flinky14 If I'm the wife, who says no to new mods?
    Genna
    Alberta
    2019 Tundra CM Platinum 4x4
    -TRD Dual Exhaust - 3m - UV front window tint/rear limo tint -TRD Oil Cap -Toyota Bed Mat - TRD Pro Grille - ARE canopy (sliding Windoors, pop down sliding front window, headliner, rack rails) -OEM Toyota Remote Starter -Baja Designs Sport Fog Lights -TRD door sill protectors -Ronin Factory short antenna
    Interested to see the 2nd 3rd gen options for 17” wheels. I see more and more people picking them and will probably go with them when I finally get the moooolaaaa to upgrade.
  17. Jun 14, 2019 at 9:25 AM
    #197
    windwarrior65
    windwarrior65 New Member
    One of my coworkers just came in to let us all know he passed a truck with the tire off and the wheel spacer being the cause. SPACERS are DANGEROUS!!!! Just get the proper wheel offset to avoid spacers.
  18. Jun 14, 2019 at 9:28 AM
    #198
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    If your wheel comes off with a quality hub centric spacer, it would have come off anyways. It wasnt properly torqued.
    A quality wheel spacer is tight to the hub bore, you install, torque down. Then check it 50 miles later, then check wheel torque 50 miles after that.
    KELZ84 likes this.
  19. Jun 15, 2019 at 11:57 PM
    #199
    Trd-Tunfra-Oz
    Trd-Tunfra-Oz New Member
    Osie
    Bay Area
    2017 Tundra 1794
    Thanks for all the info
  20. Jun 16, 2019 at 11:57 PM
    #200
    mgates32
    mgates32 New Member
    Mitch
    2018 Toyota Tundra
    Looks nice! Did you put any lift in the rear or is it just 3" in the front? Also when hammering in the skid plate, were you able to do it with the tire on or do they need to be removed?
  21. Jun 17, 2019 at 4:31 AM
    #201
    Boerseun
    Ferdie
    Sarasota Florida
    @mgates32 , the kit is a 3/1.5. My rake was just over 1.5", so it is a perfect balance.
    When hammering the skid plate I just turned the wheel all the way to the right to bend the right side and vice versa the left side. That gave more than enough room. I used a rubber mallet and hit it at an upward angle to roll the bend that is already there over by about 1/2" or so. It did not take much. I also had to take off the small mud flap thingies in the front - they were rubbing more than the skid plate.
  22. Jun 17, 2019 at 5:33 AM
    #202
    mgates32
    mgates32 New Member
    Mitch
    2018 Toyota Tundra
    Awesome. Thanks for the info.
    Boerseun likes this.
  23. Jun 21, 2019 at 6:41 PM
    #203
    Bigbird57
    Bigbird57 New Member
    Not a fan of wheel spacers. I am doing a 6112 Bilstein on 1.9" setting. CB shim on drivers side. 5100's on rear and a CB 1" shackle lift. Looking to run 285/70-18 tires.
  24. Jun 21, 2019 at 7:14 PM
    #204
    Icematt
    Icematt Toyota4life
    Black 1794 TRD
    Fuel wheels
    6112's set to 1.3" with 5100's on the rear. 285/60-20 Falken AT3. 20x9 35mm offset on the wheels.
    fedorachef likes this.
  25. Jun 21, 2019 at 7:19 PM
    #205
    Bigbird57
    That's a fine setup
  26. Jun 21, 2019 at 7:42 PM
    #206
    Icematt
    Icematt Toyota4life
    Black 1794 TRD
    Fuel wheels
    Thanks
  27. Jun 25, 2019 at 11:27 AM
    #207
    LiftMeUp
    LiftMeUp New Member
    Bout to install new front coilovers at 3" and measure. Hoping to fit 285/65/20 on stock wheels with stock UCAs and no spacers. WE SHALL SEE.....
    KELZ84 and Boerseun like this.
  28. Jun 27, 2019 at 7:34 AM
    #208
    cart99
    cart99 New Member
    Russ
    2016 Tundra Platinum CrewMax
    Fab Four front bumper
    awesome post thank you!
  29. Jul 3, 2019 at 12:34 PM
    #209
    wayoutwanderer
    wayoutwanderer @wayoutwanderer
    Austin, Texas
    2019 Tundra Limited CrewMax 4x4 in Cavalry Blue
    So, question...if I'm doing this a bit at a time, wheels, tires, and suspension, would doing a 3" lift on the stock Limited 20s for a while look completely goofy?
    I'm probably going to go back to 18s, but don't want all of that at once. I ran 285/65/R18 on my '08 stock TRD with no rubbing, etc., and was thinking about going the same route, but with the lift. I might go 285/75/R18 if it will fit under the lift without too much effort.
  30. Jul 3, 2019 at 12:45 PM
    #210
    Boerseun
    Ferdie
    Sarasota Florida
    It does look a bit goofy, often referred to as "skipped leg day" look. But, if it works for you and it is only a limited time, then who cares - go for it if you know that there is a different goal at the end.
    285/75/18 will work, but needs a little adjustment, mostly the front mud flap and fender liner, depending on your new wheels' offset. 285/65/18 is not much bigger than stock - might still look like skipped leg day with a 3" lift. Just kidding, it will be okay. 18" wheels actually helps. It is more so the 20" wheels with low profile 55 sidewalls that looks goofy with the lift.
