2011 5.7 falling on its face.
Discussion in '2nd Gen Tundras (2007-2013)' started by RogueTundra, Apr 14, 2019.
  1. Apr 15, 2019 at 5:39 AM
    MT Madman
    MT Madman Just an ordinary guy
    Hawk Point MO
    2020 Silver Platinum
    TRD dual exhaust TRD Rear Sway Bar SnugTop Hi-Liner
    Experienced this when I had mud tires on, the rubber would flex on a fast lane change or heavy acceleration, went to Michelin ATs and the problem disappeared. I have Toyos now and they pretty much suck if I take off hard. Just to set it straight, I don't even want to spin my tires on take off. It's like why lose rubber and traction, I want to get up go!
  2. Apr 15, 2019 at 5:46 AM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    You mentioned Muffler and Intake delete. What Intake did you delete :confused:
    15whtrd likes this.
  3. Apr 15, 2019 at 6:13 AM
    15whtrd
    15whtrd Mr. Blonde
    Yeah what intake? Never heard of that. Sounds like a really bad idea.
  4. Apr 15, 2019 at 6:25 AM
    CMB
    CMB New Member
    Cecil County MD.
    I can attest to that. Just this weekend my TRD CAI tube came loose from the housing and tripped Track-Control, Check Engine and 4Wheel Low lights. Un-hooked Neg battery cable to re-set everything and truck didn't want to start or stay running. Didn't notice it right away but after reading on here about loss of positive vacuum for the engine, I checked it over again and found the separation. I caused it when chickened-out with how tight I clamped the tube on install. Re-attached and clamped tighter+ I'll add clamps when they're delivered today.
    YsoSeRiouS! and 15whtrd[QUOTED] like this.
  5. Apr 15, 2019 at 9:20 AM
    Dr_Al
    Dr_Al New Member
    Al
    Disabling the trac control is worthless unless you disable the stability control. Trac control is only for going in a straight line. As soon as you even slightly turn the steering wheel the stability control kicks in and acts just like the traction control.
    15whtrd likes this.
  6. Apr 15, 2019 at 9:33 AM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Pulls out MAF... "HAI GUYZ WUTZ HAPPENZ!???"
    15whtrd likes this.
  7. Apr 26, 2019 at 8:03 PM
    RogueTundra
    RogueTundra [OP] New Member
    Tyler
    2011 Limited CrewMax
    7" BDS Lift. 35" RBPs. 20x14 Fuel Mavericks. K&N Intake. Muffler delete.
    I didnt catch that I put intake "delete". It just has a K&N intake. Didnt do anything to the motor other than that. Listen guys im not some newbie kid lol I worked as a mechanic for many years. Im a lineman now so I dont have access to the fancy diagnostic equipment anymore. This though had me a little stumped. Ive thought of all the things you have all listed. I just thought someone might have had this happen before and could point me in a good direction to start.
    15whtrd likes this.
  8. Apr 26, 2019 at 8:07 PM
    Yodder J
    Yodder J New Member
    Northwest Arkansas
    2011 Silver Tundra SR5 4WD DC
    DAP Tune, Truxedo ProX15 bed cover, WildPeak AT3s
    Never push the gas pedal all the way to the floor. Basic driving school 101. You're a mechanic and don't know this? Congrats on frying your tranny...
  9. Apr 26, 2019 at 8:10 PM
    RogueTundra
    Tyler
    Never once had any issues with vehicles from using all the pedal and power the manufacturer gives you. Maybe the fact it has 160K and was used to tow a toy hauler most of its life played a role. Do I think the trans is actually slipping or has issues? No I dont. Doesnt show any signs. I think its something else sensor related.
    15whtrd likes this.
  10. Apr 26, 2019 at 8:14 PM
    Yodder J
    Yodder J New Member
    Northwest Arkansas
    Good luck, whatever it is.
  11. May 25, 2019 at 11:54 AM
    PSYCHO WHITE TUNDRA
    PSYCHO WHITE TUNDRA Still Gonna Send It...
    Jake
    New Mexico
    White 2011 Tundra SR5 TRD (Psycho White)
    Chopped and dumped dual exhaust; 6" fully adjustable ProComp lift w/ FabTech rear shocks, 12.5x20 Pro Comp rims on 37x12.50x20 tread wright mud tires, pedal commander throttle programmer and sound system from hell which consist of Sony double din headunit, 4 Morel Maximo Ultra 603 component door speakers w/ 4 tweeters ran on a Rockford fosgate P500-4 punch amp under drivers seat then the bass comes from a custom 15” 4000rms sub made from a Skar 15” Skar basket and motor with sundown x series components made by Patrick @ Robot Underground in Mesa AZ which is powered by 2 C.A.B. Audio 2000.1D amps strapped together at .08ohm which produces just under 5000rms. Also installed 100sq.ft. 10mil dynamat sound deadening on all 4doors (both exterior and interior chambers) double layer on roof and back wall as well as inside side mirror covers and behind side mirrors
    A81BBDDD-049B-4464-A3C6-8011FDA0F22D.jpg 9B937093-F23F-40A0-8497-E1D23034A720.jpg
    Mine does the same thing but I ran into an old man with the same truck and he mentioned if I ever used race mode. I said race mode? What the hell is that? He said hold your traction control button until one amber light comes on where the tach is then let go and then do the exact same thing again until you have 2 lights on. Now go floor it and see what happens. Every time I get in my truck I turn race mode on. Let me know if that fixes it
    TexasTundra27 likes this.
  12. May 25, 2019 at 11:56 AM
    PSYCHO WHITE TUNDRA
    Jake
    New Mexico
    Try my suggestion
  13. May 25, 2019 at 12:17 PM
    PSYCHO WHITE TUNDRA
    Jake
    New Mexico
  14. May 25, 2019 at 12:27 PM
    15whtrd
    15whtrd Mr. Blonde
    Buahahahahahaha! Who told you that? So you’ve never floored your tundra? What fun is that? Other than basic wear and tear. The manual doesn’t state that.
    LarryDangerfield, equin and landphil like this.
  15. May 25, 2019 at 2:34 PM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    Pretty sure the pcm cuts throttle much longer than it applies the brakes. The latter is over in a second. Then the engine acts like it has a carburetor jet 5 sizes too small for a bit while the computer puts the driver into time-out for 3 seconds for being naughty. It's super noticeable on the narrower 255 width tires.
    Newer vehicles automatically cut throttle during a full-throttle upshift to greatly reduce transmission wear :thumbsup:
    15whtrd likes this.
  16. May 25, 2019 at 4:28 PM
    Racingjohndeere55
    Racingjohndeere55 New Member
    Apparently yall dont have the 4.6...
  17. May 25, 2019 at 4:38 PM
    15whtrd
    15whtrd Mr. Blonde
    Why? What am I missing other than the fact that the 4.6 is smaller. And maybe some different gear ratios in the rear end.
  18. May 25, 2019 at 4:45 PM
    Racingjohndeere55
    It's a v8. That's about it..
  19. May 25, 2019 at 4:47 PM
    15whtrd
    15whtrd Mr. Blonde
    Hahaha you drinking?
    Stainlesst likes this.
  20. Jun 20, 2019 at 7:48 AM
    #50
    PSYCHO WHITE TUNDRA
    Jake
    New Mexico
    For fucks sake. How do you figure he fried his tranny. Mine does the same shit if my tires spin. I’ve beat the crap outta my tranny and zero issues. Plus what Tundra owner doesn’t push there pedal all the way to the floor? I took Driving School 330 cause 101 is for Prius drivers
    15whtrd likes this.
  21. Jun 20, 2019 at 8:00 AM
    #51
    15whtrd
    15whtrd Mr. Blonde
    Right! Wtf kind of response was that? What kind of weirdo never put the pedal to the floor? That’s like never going balls deep with the GF because you might wreck it for the next guy LOL!
  22. Jun 20, 2019 at 9:10 AM
    #52
    Stainlesst
    Stainlesst everybody loves an Inky. Inky Inky. go Inky go!
    going to the big D and don't mean Denver...
    09 trd crewmax, 13 TWReX stage III
    In the "Zone"...
    15whtrd[QUOTED] likes this.
  23. Jun 27, 2019 at 7:44 PM
    #53
    RogueTundra
    Tyler
    I figured out how to disable the torque control. Never knew about holding down the TC a 3rd time. Doesn’t do it now.
    equin and Taco-Blender like this.
  24. Jun 29, 2019 at 7:47 AM
    #54
    Vince
    Vince New Member
    Vincent
    Terre du lac, Missouri
    2011 White DBL cab 5.7
    K&N intake, Air bags
    How do I know if I have that ?
  25. Apr 20, 2021 at 7:36 PM
    #55
    Zpre2116
    Zpre2116 New Member
    Zack
    2010 Tundra
    5100s all the way around
    Anyone ever fix this issue I just installed firestone destination mt2 and have the same issue as the creator of this thread, I have tried a zpc and seemed to fix it a little, also was reading this thread and one guy was talking about mud tires moving on the wheel more then a street tire and I have noticed with windows down on normal acceleration I can hear the tires gripping the road, sounds like a drag slick on some prep and thinking that might be the overall issue.
  26. Apr 20, 2021 at 9:14 PM
    #56
    2turbz
    2turbz New Member
    2011 Tundra Trd 4x4
    Read the post two above yours from the OP.
  27. Apr 20, 2021 at 9:28 PM
    #57
    Zpre2116
    Zpre2116 New Member
    Zack
    2010 Tundra
    I get that but don't want to turn everything off every time I get in the truck.
  28. Apr 20, 2021 at 9:41 PM
    #58
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Whatever it is heavy pedal and downshift sounds like a comp, fuel, air sensor issue. I’m not savvy on the new tech. But unless the new trucks have crazy drive like your holding your coffee mode, sounds like it needs a diagnostic.
  29. Apr 20, 2021 at 9:42 PM
    #59
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    On a similar note, the computer may be preventing unwanted Prius stuck accelerator pedal to keep you from driving into a wall. Forgot what that “feature” is called. If it thinks the brakes are also on it could activate the feature. Maybe something is wrong with the brake pedal sensor or something or you drive with one foot on the brake?. Just a thought, not trying to be rude or anything.
  30. May 9, 2021 at 6:59 AM
    #60
    Vince
    Vince New Member
    Vincent
    9:rofl::bananadead::cheers:
