  1. Jun 18, 2019 at 3:33 AM
    #7801
    Professional Hand Model
    Fred
    Hand Protectors
    Between the blower and the A/C Compressor. Just behind and below the glove box.
  2. Jun 18, 2019 at 3:41 AM
    #7802
    Fred
    Hand Protectors
    Amazing. If I owned one of those shops, I’d call it Vajayjay Nation.
    Hooptytrix[QUOTED] likes this.
  3. Jun 18, 2019 at 8:07 AM
    #7803
    Hooptytrix
    Hooptytrix Squeaky Chicken
    Dirty South
    2000 AC 4x4, 2001 AC 4x4 Sold. 2005 DC SR5 2WD
    I was thinking more like Deadliest Snatch
  4. Jun 18, 2019 at 8:15 AM
    #7804
    :rofl::rofl::rofl:
    :hattip:
  5. Jun 18, 2019 at 10:08 AM
    #7805
    Fred
    Hand Protectors
    Couple of things today.
    1) Aired back up from 35psi to 40psi. Much better. Less jiggles.
    2) Fueled up a full tank of gas and took some measurements from ground to bottom of wheel well.
    A) Drivers side is 1/2” lower on the rears.
    B) Drivers side is 1/4” lower on the fronts.
    3) Should I start a turd gen thread complaining about such issues?
    because_wumbo-truck likes this.
  6. Jun 18, 2019 at 10:17 AM
    #7806
    Fred
    Hand Protectors
    The ‘Throttle Cable Bracket Mod’. Guarantees 7 more horsepower (kidding). Add a zip tie (see pic) in the gap to tighten up the 3/16”+/- free play in the line.
  7. Jun 18, 2019 at 10:46 AM
    #7807
    Fred
    Hand Protectors
  8. Jun 18, 2019 at 10:50 AM
    #7808
    I don't understand why Toyota recommended such low PSI on our trucks. My door jamb says 26F 29R. That's ridiculous. I'll check today and see what Discount Tire filled these up to.
    I've been wanting to do the chalk test but I'm too cheap to buy it and none of my friends have kids or I'd just steal a piece.
  9. Jun 18, 2019 at 10:54 AM
    #7809
    Fred
    Hand Protectors
    Smaller factory tires need less air?
  10. Jun 18, 2019 at 1:56 PM
    #7810
    because_wumbo-truck
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    35psi has always been what I run. ~18psi off road
  11. Jun 18, 2019 at 3:09 PM
    #7811
    Hooptytrix
    Dirty South
    This guy would need medication if he owned either of the last 3 Tundras I have owned.
    IMO it ain't yours till you put your mark on it.
  12. Jun 18, 2019 at 3:35 PM
    #7812
    Fred
    Hand Protectors
    I’m assuming many of these 3rd Gen guys are on Ritalin or were when they were younger. They talk about how they have OCD and complain about stupid stuff. Yet, when you tell them about how important changing transmission fluids is for a vehicle they all jump together in unison, ‘No earlier than 100k miles and its a waste of money!’
    Next thread they’re buying new exhaust at $1500 or new lifts for more $.
  13. Jun 18, 2019 at 3:38 PM
    #7813
    Hooptytrix
    Dirty South
    That sounds about right.
    I don't get the thought process but hey.... To each his own.
  14. Jun 18, 2019 at 3:40 PM
    #7814
    Here are some better shots of the new wheels and tires. I went ahead and removed the mudflaps to sand them down.
  15. Jun 18, 2019 at 3:43 PM
    #7815
    Hooptytrix
    Dirty South
    I likey
    NUDRAT and FirstGenVol[QUOTED] like this.
  16. Jun 18, 2019 at 3:49 PM
    #7816
    imDementeD
    imDementeD New Member
    2003 Tundra Limited 4x4 Trd Supercharger
    Rims and Tires were meant to deliver today but only tires came in.
    You know how they say "Go big or Go home", probably should have just went home. Will make it work though!
  17. Jun 18, 2019 at 3:51 PM
    #7817
    Nice! Did you go 285/75/17? I chickened out and went 285/70 but no regrets yet.
  18. Jun 18, 2019 at 3:53 PM
    #7818
    imDementeD
    ^ yea, went 285/75/17. The offset of the rims are -12 so they will push out quite a bit so I think I should clear UCA/Frame. The front bumper is also getting replaced with bruteforce so I guess my biggest concern is the pinch weld but if it requires cut/weld I'll get it done!
  19. Jun 18, 2019 at 4:55 PM
    #7819
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    Those wheels are hot. Seeing your score the other day made me start looking for wheels. Not that I need to spend more money while building my suspension, but the pro comp rockwells really did it for me. The silver or bronze wheels are really cool though.
  20. Jun 18, 2019 at 6:20 PM
    #7820
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    Installed new stickers and wired up the truck for an incoming brake controller.
    TX-TRD1stGEN and Darkness like this.
  21. Jun 18, 2019 at 8:05 PM
    #7821
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Moved most of my garage shit
  22. Jun 18, 2019 at 10:41 PM
    #7822
    SCRunner12
    SCRunner12 New Member
    Robert
    Santa Cruz, CA
    2015 SR5 Crewmax
    Picked up a set of used Level 8 mk6 to replace the stock wheels, ordered longer u bolts, and the last of my audio components. Currently sleeping in the Tepui for my daughters horse riding overnight.
  23. Jun 18, 2019 at 11:07 PM
    #7823
    because_wumbo-truck
    Jon
    Houston, Texas
    Can't wait to see it. I was torn between your tire size and mine, 295/75r16. So I really wanna see how yours looks. Which wheels did you go with?
  24. Jun 19, 2019 at 4:35 AM
    #7824
    imDementeD
    Going with the fuel d666. You can see them like 2 pages back from my Amazon order list. :)
  25. Jun 19, 2019 at 4:48 AM
    #7825
    SoCalPaul
    SoCalPaul New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
    Nice. They look similar to some I was looking at.
  26. Jun 19, 2019 at 4:48 AM
    #7826
    trailbikerider
    trailbikerider New Member
    Blake
    Kalamazoo, MI
    2006 Tundra DC SR5
    Those wheels look killer on anything. My old 4Runner had them, and I wish I would've kept them for the Tundra.
    [​IMG]DSC_1064 by Blake Nichols, on Flickr
    [​IMG]DSC_1074 by Blake Nichols, on Flickr
    [​IMG]DSC_1076 by Blake Nichols, on Flickr
  27. Jun 19, 2019 at 5:04 AM
    #7827
  28. Jun 19, 2019 at 5:09 AM
    #7828
    trailbikerider
    Blake
    Kalamazoo, MI
    2006 Tundra DC SR5
    Ugh I know, I miss that thing all the time. :(
  29. Jun 19, 2019 at 5:32 AM
    #7829
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    nice leveling block.... ;-)
  30. Jun 19, 2019 at 8:44 AM
    #7830
    SCRunner12
    Robert
    Santa Cruz, CA
    2015 SR5 Crewmax
    Had the Ray 10’s and 285/75/17 Falkens on my old tundra. Loved that combo, although the falkens were super heavy.
    Haha right? Worked perfect.
