Thanks!
Discussion in 'New Member Introductions' started by TSF, Jun 18, 2019.
  1. Jun 18, 2019 at 10:25 AM
    TSF
    TSF [OP] New Member
    07 Tundra 4.7
  2. Jun 18, 2019 at 10:25 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    :wave: Hiya and welcome from SoCal!!!
    Y0TA PR0 likes this.
  3. Jun 18, 2019 at 10:33 AM
    Thanks! Welcome from CO. Pix of that 07???
    Pinay likes this.
  4. Jun 18, 2019 at 10:35 AM
    Welcome from NY.
  5. Jun 18, 2019 at 10:39 AM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    WELCOME
    GNTundra likes this.
  6. Jun 18, 2019 at 10:45 AM
    Welcome from
  7. Jun 18, 2019 at 11:43 AM
    GNTundra
    Gino
    2013 White
    Welcome
  8. Jun 18, 2019 at 11:44 AM
    GNTundra
    Gino
    2013 White
    :eek: :D
  9. Jun 18, 2019 at 11:56 AM
    SNOOCHIE BOOCHIES
    OR18TRD and GNTundra[QUOTED] like this.
  10. Jun 18, 2019 at 12:03 PM
    She looks cold!!
  11. Jun 18, 2019 at 12:03 PM
    Welcome from Ohio
  12. Jun 18, 2019 at 12:05 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from CO
  13. Jun 18, 2019 at 12:06 PM
    Blueknights75
    Ron
    Clayton, NC
    Looks a little nipply outside.
  14. Jun 18, 2019 at 12:11 PM
    Lol. Either that or the turkey's done.
  15. Jun 18, 2019 at 12:11 PM
    TSF
    TSF [OP] New Member
    07 Tundra 4.7
    Thanks for welcomes! I'm new to you forum so be patient with me. Here we go. I bought my dream truck about a week ago. Paid $700 for 07 Tundra SR5 double cab with the 4.7 engine with about 200,000 miles. The seller told me the timing belt broke as he was coasting down his street going about 20 mph. For $700 I could buy another engine IF I had to. The engine cranks but doesn't start.
    I tried starter fluid and got nothing. I turned my focus to spark. Since the previous owner said it was the timing belt I took off the covers and saw the timing belt was not broken. I took off a plug wire, inserted a spark plug, grounded the plug, and tried to start the motor. I got no spark.
    I believe, but not fully convinced yet, that I have a spark problem. I know to check the fuses but am not sure which ones are important. When I put the truck on the computer I get and error message. It literally says "error" and tells me to try again. Can you give me some ideas of what to check AND an order to check? PLEASE!
    My two or three thoughts are these.
    1. The ecu (computer) is bad and I don't get a spark.
    2. The alarm (anti theft) is disabling the engine and I don't get spark. The owner gave me one fob and two keys. Sid the fob works but "one of the keys is shot." I have tried starting it with both keys and if doesn't seem to matter.
    3. A fuse or relay is bad.
    4. It's not a spark problem at all. This is my first Toyota and I'm getting used to the nuances of Toyota. For example... I had to buy a batter just to take it out of park. Never had a vehicle that required power to take it out of park. So... maybe there's some kind of Toyota trick I don't know about.
    HELP! Please. Love this truck and want to drive it! Thanks!
    georgiey22 and OR18TRD like this.
  16. Jun 18, 2019 at 12:22 PM
    TSF
    TSF [OP] New Member
    07 Tundra 4.7
    While I'm on the subject of ecms. I have replaced a Chevy and a Saturn ecm. Both needed to be programmed based on the VIN. When I price ecms on places like eBay they seem to require you to send yours in and they take a month to repair and return it. Is this typical or can you get another ecm programmed for my Tundra?
  17. Jun 18, 2019 at 12:33 PM
    AZTundra
    Paul
    Phoenix, AZ
    Welcome from AZ.
  18. Jun 18, 2019 at 1:15 PM
    Blueknights75
    Ron
    Clayton, NC
    Save the neck for me Clark!
  19. Jun 18, 2019 at 1:28 PM
    G10dra
    G10dra Not a New Member
    battery and or alternator :notsure:
  20. Jun 18, 2019 at 1:36 PM
    Randy Morton
    Randy
    Deepinahearta, Texas
    I'd find a friendly locksmith and see if he can program a new key. If a new key starts the truck, you're good to go. If he can't program the key, the ECU's shot and you can go from there. If he can program the key and it still won't start, the security system's hosed and you'll need a lot of in-depth troubleshooting to find the actual problem. Overall, the price of the locksmith service call will tell you where to start. If you know a locksmith personally, the price of a six pack of his favorite imbibement could save you some appreciable cash.
  21. Jun 18, 2019 at 1:52 PM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Welcome to the party!!
  22. Jun 18, 2019 at 7:14 PM
    markg
    markg New Member
    Mark
    NC
    2007 TRD
    Welcome from NC,
    I think you're on the right track, narrowing it down is the task.
    Start with the less expensive and easiest first.
